Question about Philips 60PP9202 60" Rear Projection HDTV-Ready Television
Philips 60PP9202 60 in. Rear Projection - Convergence Issue; Hourglass Picture
I have a 60PP9202 that initially had a green convergence problem. Thanks to all the great information I was able to replace the two IC's myself. I also replace two open 1W 6.8 ohm resisters. However, when I turned the TV on, the green convergence problem was fixed, but the entire picture is distorted like an hourglass on its side.
Are my IC's bad & not functioning?
Is there a fuse that may be blown that powers the IC's? If so, where would it be located and what does it look like?
  • FastHound Feb 20, 2008
    I will certainly check my solder joints.
    Does anyone have any idea on the location of the Pico fuse that powers the IC's?
    ctf1800 - To ensure that they are not bad, is this a simple continuity test?
    President:
  • 4,402 Answers
Check your soldering and make sure all pins are soldered.
Posted on Feb 19, 2008
  • Cary Farah
    Cary Farah Feb 20, 2008
    they are typically around the high voltage transformer, they look like resisters but no color codes.
  • Cary Farah
    ohm test they should be shorted or close to o ohms
My 52in hd tv wont show a picture and when you cut it on it just light up red but no picture and i cant get to adjust the convergence on the menu.
If the screen is a bright red its indicating an issue with the CRTs could be the red has shorted or the coolant in the blue and green is needing replacement which makes the red Dominate. Looking into the blue and green lenses will verify if its a coolant isssue or not. The convergence issue is most likley failed convergence ICs and the associated 6.8 ohm resistors need replacment.
Aug 20, 2011 | Philips Magnavox 51MP392H Rear Projection...
When you turn the tv on you have a green tint to the picture and the red bleeds like it's glowing
Not able to do auto or manual convergence adjustment.The tv convergence board is dead.The tv convergence board,must be replacing 2 STK convergence ICS and some or all of it resistors too.To fix the convergence board to solved the tv picture convergence problems.The shop,will cost u like $300-$350
Jun 10, 2011 | Philips 60PP9202 60" Rear Projection...
My philips 46pp9302 picture looks green ive lined up the blue and red colors but dont know whats wrong.....help
The tv have a problems known as a convergence problems,it dead.The tv color lines R,G,B mis alignment,have colors shadows pictures or 3D pictures look alike.The tv convergence board have dead parts.The 2 STK convergence ICS and some or all it resistors are dead.These parts on the tv convergence board,must be replaced to solved the tv picture convergence problems.The shop,will cost like $300-350 for parts and labors.
Oct 27, 2010 | Philips 46PP9302 46" Rear Projection...
Colors are off
Thats a convergence Issue, Heres a link to a repair kit which contains instructions on how to install the repair kit
http://servicemanuals.vstore.ca/product_info.php/pName/phillips-dptv-305-dptv345-convergence-repair-kit/cName/convergence-repair-kits
Jun 22, 2009 | Philips 46PP9302 46" Rear Projection...
Sony 53 inch projection screen with hourglass picture
If you are familiar with TV repair, have electronics basic knowledge, good soldering skills and tools then check dry (cold) soldering joints at D board of this TV. Resold all lose connections there and check picture.
Still no joy then you need to replace D board.
Feb 25, 2009 | Philips 60PP9202 60" Rear Projection...
Philips 60PW9363 60 in. Rear Projection Television, red sideways hourglass
You can get the Kit at the following link which contains both ICs and the 12 Convergence resistors plus free instructions on how to do the repair. Its listed under their Convergence repair kit category and its called the DPTV305 - DPTV345 convergence repair kit. Here is the link.
Nov 24, 2008 | Televison & Video
Magnavox 51mp392h
replace the convergence ICs STK392-120 you will need both of them also check the 6.8 ohm resistors right next to the ICs as often 1 or 2 of them burn open. You should be able to notice the discoloration in the center of the resistors.
Mar 11, 2008 | Philips 60PP9202 60" Rear Projection...
Bowing picture
may have blown your convergence, does it look like all 3 colors are hourglass or is it just one. If all 3 are bad and it is on the sides it may be a pincushon problem, I dont think you have an adjustment problem I think you have a part failure. If this set is older than about 5 years old it may be starting to have issues with the CRT coolant and the blue may be getting blury, the blue and green will need to be changed also. I would definitly call someone on this to make sure that you get all your bases covered as Fluid is conductive and can cause all kinds of issues up to fire hazzard. (of course that is if it is leaking, and that could be what caused your hourglass issue.)
Jul 08, 2007 | Philips 60PP9202 60" Rear Projection...
Warped Picture, Separated colors
Each color (red,green & blue) has an amplifier IC (STK-).
When there is a convergence issue,the first step is change both
IC's for reliability. Then check for open fuses devices,usually
pico fuses.Then re-check convergence alignment.......T.
Feb 07, 2007 | Philips 60PP9352 60" Rear Projection...
Philips 60PP9202 60" Rear Projection HDTV-Ready Television Logo
116 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
