Question about Photography
I put new roll of film in the camera and it was sucked back into the film cannister and now can't unroll film to start
  • 2,517 Answers
Well it is not a big problem. Visit a photo studio and tell then to for leaf out of the roll and load it in your camera. You can't take out that starting point of the roll at home. Because you don't have the small machine. After that put the roll back in your camera.
Now i am going to say most important things.
click few (4-5) snaps using a cover in front of your lens. Then click normally for taking photos.
Thanks.
Posted on Feb 02, 2010
Hey so I got a Fujifilm camera for my bday but me being silly pulled out one from the films and the back so is there a way to put it back in and use it again??
you can put it back in again but the film has been exposed so it will be no good
you will need a new film cannister
Mar 18, 2017 | FUJIFILM Photography
Suppose a film roll is said to be useless if at lest 2 defects are found per 80 feet of film roll
dude...really? if it's film for a camera....you need to get digital....I'd say that as for the 2 defect rule....someone has yanked your chain pal. ....
It's 3 defects per 2 inches...If you unroll 80 feet of film meant to be used in a calculator.......a calculator......it must be an MI6 calculator that snaps photos of the user every time he hits the = key......let's say you did unroll 80 feet of film....and you were in a dark room doing it.....there might be a problem rolling the film back up correctly after unrolling 80' of the super 100,000 snap shot roll. Ya think?
Don't take this wrong....it really is a jab to your kidney....
Mar 12, 2015 | Office Equipment & Supplies
Camera keeps sucking the film back into the canister instead of loading it
Check the bottom DX pin in the film chamber. These get bent easily and it is also used for the film detect switch so that the camera knows there is film in the camera.
Dec 10, 2013 | Canon EOS Rebel 2000 35mm SLR Camera
My canon eos 1000 keeps on rewinding the film into the cannister when i put a new film in
The XS normally winds the film completely out of the cassette and then rewinds it back into the cassette as you take pictures
Feb 08, 2013 | Canon EOS Digital Rebel XS / 1000D IS...
Owner's Manual for a Fuji Discovery 400 Tele Plus
Here's the owner's manual (link below) .
NOTE -> the DL-400 extracts the entire roll of film from the canister as soon as you close the back. Just the REVERSE of what you would expect. Then every time you take a picture, the camera rewinds the exposed (single shot) picture back into the cannister. When loading the film, YOU MUST PULL OUT ENOUGH FILM FROM THE CANNISTER TO GO ACROSS THE ENTIRE BACK OF THE CAMERA. There are 7 little notches on the botton of the cover. You won't see them until you open the back. The film MUST be extended far enough to reach the notches.
link
http://www.butkus.org/chinon/fujica/fuji_dl-400/fuji_dl-400.htm
May 09, 2010 | Photography
Film rolls back automaticaly
The camera shouldn't be doing this, assuming you're using 36 exposure (or 24 exposure) film. You may want to set a custom function to prevent automatic rewind -- you would have to rewind the film yourself by pressing the rewind button.
To do this:
1. Under the palm grip, press the 'CF' (custom function) button.
2. Use the main dial to select 'F1' in the LCD. It should show a '0' below the 'F1'.
3. Press the 'CF' button to change the '0' to a '1'.
4. Press the shutter button half way to save the change and exit the custom function setting mode.
If you want to stop the rewind with the film leader still exposed (film doesn't rewind entirely into the cannister), use the same steps but set custom function 'F2' to a value of '1'.
Mar 17, 2009 | Canon EOS-1N RS 35mm SLR Camera
Fuji 35mm Camera (Model DL-400)
Dawn
remove the battery and check that it is good. replace battery and open back door, close the door and it should run the motor / transport. if so, load film up to the drive sprocket being sure film will catch on the sprocket.
or move the latch holding back cover, and open the door fully. check the pressure plate on the door, gently pull the plate up a little to increase pressure on the film. bring the holding lever out toward the latch and close the door to lock the lever back to position.
Jun 11, 2008 | Fuji Discovery 185 Zoom 35mm Point and...
Nikon n75 problem loading film
I have (had) the same problem. I came onto this site to find out what I can do to fix it. It didn't help. I got pissed and almost threw the camera away. So I decided to get a little rough with the camera, (i normally wouldn't do this but i was going to throw it away).
I loaded the film like normal but before I closed the back I manually wound the film around the opposite spool. I guess I fooled the camera into thinking it had already wound the film.
When I closed the back of the camera everything worked fine.
I then snapped off the pics the camera said were left.
After this first role, I loaded the next role like normal. The camera worked like a charm!
By the way...the mirror dropped back down when I manually wound the film around the spool.
I hope this works...if it doesn't make any sense feel free to email me with any questions..
GOOD LUCK.
andy
amasseur at gmail dot com
Oct 03, 2007 | Nikon N75 35mm SLR Camera
The film automatically loads then rewinds when a new film canister is added
Hm. Well, the way this camera works is actually very clever. When you first load a film into it, it winds the entire film out of the cassette and into the camer. As each shot is taken, the film is rewound back into the film cassette. The advantage of this is that if the back of the camera is accidentally opened, the shots which have already been taken are already safely back in the film cassette and will not be damaged by the light ingress. However, your camera is behaving strangely. I would check that the electrical contacts where the film cassette goes in are clean. You can clean them using a cotton bud moistened with methylated spirits.
Apr 13, 2007 | Canon EOS Rebel G 35mm SLR Camera
Photography Logo
81 people viewed this question
Top Photography Experts
Tony
Are you a Photography Expert? Answer questions, earn points and help others
