Question about Dell Dimension 4600 PC Desktop
Ethernet for my dell 4600 pc
What do I needed todo to be able to connect my pc to ethernet? I have a usb port on the back of my computer and would like to hook it up to DSl which i got fromAT&T. I know there are converters to go from ethernet to usb port but my husband says I needed to install a card?
    Genius:
  • 1,601 Answers
CLS21166,
Your system has an
Integrated Intel PRO 10/100 Ethernet port. You can hook the DSL modem to that.
Posted on Feb 19, 2008
    Sergeant:
    Champion:
  • 317 Answers
No, you don't need a card, as long as you have an Ethernet to USB adapter, you should be just fine.
I need an ethernet controller driver for my dell dimension 4600 desktop
Well that is a problem. You can go to "support.dell.com" to download the drivers, however since you can't connect to the internet you will need to use a friends computer and download it.
Aug 13, 2012 | Dell Dimension 4600 PC Desktop
I am trying to install a printer to in my Dell Inspiron laptop 1545. I have the printer connected to the laptop through the ethernet port. But I can not get it to pull up the printer at all. Is the...
Hi lesstravelro...
No, the printer does not connect to the ethernet port.
Before you hook your printer to your laptop besure to run any softwear that came with the printer.
I would also recommend that you go to the Manufacturer's website for updated drivers for your printer.
Your printer will have a printer port or usb port on the side/back of the printer to plug the printer cable into the printer.
You will plug the other end of the printer cable into a usb port on your laptop.
Please take time to rate me thumbs up
Sep 21, 2011 | Dell Inspiron 1545 Notebook
I can't get my usb devices to work on my dell 4600 series pc. It won't reconise anything I try to plug in to the usb ports.
Try deleting your usb drivers.
Right-click My Computer
Manage
Device Manager
USB Controllers
Delete (Generic USB Hub)
Restart computer
(Windows will auto-install the drivers, on reboot)
Plug your device back in, and see i've it works.
ALSO PLEASE RATE MY SOLUTION
Jun 21, 2011 | Dell Dimension 4600 PC Desktop
I have a 2003 Dell Dimension 4600 and the network adapter is testing fine. However I am unable to access broadband internet and email through a wired USB/Ethernet connection to external modem. Both the...
the hard wired connection to the modem could be a system configuration issue, the cable has gone bad, or the modem is having connectivity issues with the service.
if your optical drives are not working physically, then you can't really fix that. if they just arent responding properly or Windows cant detect that they are there, then you may need to reinstall the driver software for the drives. which can be found on the Dell website or the manufacturer of the optical drives.
yes you can set up a wireless connection with a USB adapter but the modem also needs to have wireless capability in order for you to create the connection.
there are external USB optical drives available. so you can purchase a usb connected CD/DVD drive or burner. they shouldnt be very expensive nowadays.
Apr 22, 2011 | Dell Dimension 4600 PC Desktop
Have a Dell Dimension 4600 series computer. I have made numerous attempts to connect to the internet however shows "network cable unplugged" Checked cable for connection-connected. I did disconnect and...
Check the cable by trying another one if you have not already done so. Before you buy a new ethernet card try downloading the driver for the ethernet card you now have and see if that solves the problem. Go to http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&os=WW1&osl=en&catid=&impid=&SystemID=DIM_P4_4600 If not then any Ethernet 10/100 PCI card should work fine in your Dell.
Jun 24, 2010 | Dell Dimension 4600 PC Desktop
Adding a PCI ethernet card?
One port on the router is an "Ethernet" port -- look closely to see the 8 wires in the socket.
You'll need a similar 8-wire connector on your computer,
and an "Ethernet-cable" that has 8 strands of wire.
Adding-in the PCI Ethernet card will add an 8-wire connector,
so that the Ethernet-cable can be connected.
Be sure to buy a 'PCI' Ethernet adapter, not 'PCI-E', and not 'ISA'.
It may come with a CD-ROM containing software to be installed.
Don't pay more than $20. Or, find a "computer-geek" -- he/she probably will have one or more "spare" PCI Ethernet cards to give to you.
Nov 18, 2009 | Dell Dimension 4400 PC Desktop
Ethernet connection failure
I think you just need to install the right drivers for the hardware:
http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&ServiceTag=&SystemID=DIM_P4_4600&os=WW1&osl=en&catid=&impid=
Go to this link and it has all the drivers you need. If you need further help, let me help.
May 15, 2009 | Dell Dimension 4600 PC Desktop
Usb
Usually with Dell computers you can find the USB port on the back part of it on the bottom part and also on the front where you see a cover the port is located...
Jan 14, 2009 | Dell Dimension 4600 PC Desktop
Computer needs ethernet card for highspeed internet
It depends on your computer and your operating system, but generally if you have USB ports with a Windows-based machine, then you can use a USB ethernet adapter. You plug the adaptor into your USB port, then the ethernet cable into the adapter.
Almost any electronics supply store ie Circuit City, Best Buy, plus Walmart and other big discount stores carry USB Ethernet Adapters. You can also try your local mom 'n' pop computer supply store.
http://www.dlink.com/products/?pid=133
I'm posting a link to a DLink adapter as an example *only.* There are other brand names out there that would probably do just as well.
Hope this helps!
Apr 03, 2008 | Dell Dimension 4600 PC Desktop
Dell 4600 desktop
It is on the rear of the machine, right next to the USB ports.
Jan 11, 2008 | Dell Dimension 4600 PC Desktop
Dell Dimension 4600 PC Desktop Logo
164 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
