Question about Nintendo Wii Console
Hi Im trying to connect my wii to the internet but it comes up with error code 52130. please help.
    Genius:
  • 1,234 Answers
Error Code: 51030 The only wireless network within range of your Wii console is not configured or is not compatible with the Wii.
  • If you are getting this error after completing a system update, this is usually because the console resets to using the first connection slot after an update. There are two things you can do:
    • If you know which connection file you were using before, you can select that connection file, then select "Use this connection" to change that to the default. You will need to do this each time they download an update.
    • If you don't know which connection file you are using, or if you would prefer not to update the active connection file each time, try to clear, and then re-create your connection setting in slot one before doing the remaining troubleshooting.
  • Check to see if the router you are using is a known to be incompatible. Click here to view our list. If your router is known to be incompatible, we recommend using a different router if possible.
  • Make sure that the SSID (network name) matches exactly to what you have entered in the Wii console's settings. To verify:
    1. Login to your router's settings (click here and select your router, if available, for information).
    2. Look for the section for SSID (typically in the "wireless settings" area).
    3. After you find the SSID (network name), verify in the manual settings of the Wii console that the SSID appears exactly as listed in the consumer's router. This includes making sure capitalization, spaces, or special characters match exactly.
  • Look up your router, if available, in our list of wireless routers, and check for any special notes that may be necesary to get the connection to work properly.
  • The router may not be assigning an IP address to the Wii console, and a connection using the "Manual Settings" may be necessary. Click here for help.
  • Your router may require a firmware update to work properly with the Wii console. Firmware updates can usually be found on the router manufactruer's website; consult the manufacturer for more information.
Posted on Aug 27, 2010
Wii, im getting a error code 52130
This error is caused by a wireless router firewall issue.
To solve this error, try to manually setup the Wii console using your network IP settings.
To do a manual setup of the Wii console using your network IP settings :
  • First, go to your PC, click Start > Run > type CMD and press Enter > type IPCONFIG/ALL and press Enter. On Windows Vista, click Start > type CMD in the Start Search box > click on CMD icon > type IPCONFIG/ALL and press Enter.
  • Locate IP settings and use them to manually set the Wii console.
  • Restart your wireless router by unpluging the power from the wall and plugging it back in. Try to connect the Wii console to the internet.
Hope this helps!
Sep 24, 2011 | Computers & Internet
Have netflix hooked up to wii, have code 52130 what does this mean
Error Code: 52130 Was this information helpful?The Wii is unable to connect to the Internet
Likely cause: The wireless router is incorrectly connected, or the Wii console will need a DNS manually entered.
How to fix: Check the way your router is connected; manually assign a DNS to the Wii.
  1. Check the connections to your wireless router:
      Even if you are able to get a working Internet connection to your computer through the wireless router, if it is not properly connected to the modem, the Wii and other devices may not be able to use it.
    • Most routers have five (5) ports on the back. Typically there is a set of four, with a single port either farther away from the rest, or separated with a different color border or line. This single port is often labeled "Internet" or "INT." Make sure the cable coming out of your modem is plugged directly into this "Internet" port, and not into one of the other four that are grouped together.
  2. Manually change your Wii console's DNS settings. To do this, follow these steps:
    1. Access the Wii system settings (how to), and use the right arrow twice and select "Internet."
    2. Select "Connection Settings," and choose the connection file (1, 2, or 3) that are you are currently using.
    3. Select "Change settings" and click the right arrow 3 times to reach "Auto-Obtain DNS."
    4. Select "No," and choose "Advanced Settings."
    5. Click into the "Primary DNS" field and enter: 8.8.8.8
    6. Click into the "Secondary DNS" field and enter: 8.8.4.4Please note: These are public DNS's provided by Google and are subject to Google's Terms of Service. If you prefer to not use this service, doing an Internet search for "public DNS" will provide you with several other options you can use.
    7. Select "Confirm," and then "Save."
    8. Select "OK" to start the connection test. Once the test finishes, try to download the update again.
  3. If you are still getting this error code after trying the steps above, please call 1-800-255-3700 for further assistance.
Sep 12, 2011 | Nintendo Video Game Consoles & Games
Error code 52130
This is from Nintendo support's website
    6. Click into the "Secondary DNS" field and enter: 8.8.4.4 Please note: These are public DNS's provided by Google and are subject to Google's Terms of Service. If you prefer to not use this service, doing an Internet search for "public DNS" will provide you with several other options you can use.
    Good luck
Jul 19, 2011 | Nintendo Wii Console
Error code 52130 im on internet with m computer but now the wii says im no
Error 52130 is a common error and can be repaired at home within no time with the help of Complete Guide to Xbox Repair. It has all major problems and their solutions so it would be helpful for you in the future as well. I hope this Xbox repair manual would help you repair your problem as soon as possible. Take care and good luck :)
Jul 04, 2011 | Nintendo Wii Console
Code 52130 comes up when I try to stream movies from Netflix
This error is usually caused by a wireless router firewall issue. Try to disable the wireless router security or firewall. Then try again to connect the Wii console to the internet.
Mar 01, 2011 | Nintendo Wii Console
I have error code 52130 on my wii
Hi, the error code you are getting relates to either a firewall or internet connection error you can try the following to solve the problem, if you are unsure what you are doing then please leave it to someone who has some idea of how to set this up for you
  • On a PC, click Start > Run > type CMD and press Enter > type IPCONFIG/ALL and press Enter. On Windows Vista, click Start > type CMD in the Start Search box > click on CMD icon > type IPCONFIG/ALL and press Enter.
You may also try to disable the wireless router security or firewall. Try again to connect the Wii console to the internet.
Jul 20, 2010 | Nintendo Wii Console
Im try to connect my wii online but i get error code 51330 saying unable to connect to internet. im on wierless and have con though connection and his comes up after testing my connection.....what should i...
Error Code: 52130 There appears to be an issue with your wireless router's firewall.
  1. Make sure your router is not listed on our "known incompatible routers" page, by clicking here.
  2. Try a "Manual Setup" with the Wii console (how to), using your network's IP configuration settings. To access these settings:
    1. On your PC, click "Start" and then "Run."
    2. Type "CMD" into the field that appears to open a new window.
    3. Type "IPCONFIG/ALL" and press "Enter" to display a list of internet settings. Locate the settings asked for by the Wii console during the Manual Setup process and enter them.
    4. Power cycle your router and modem by unplugging them both from the wall. Wait a few minutes, and plug the modem back in. Wait a couple of minutes for the modem to initialize, then turn on the router. Try to connect the Wii console online and test for proper response.
  3. Disabling your router's wireless security may help the Wii console's online connection. Consult your wireless router's manual or check with the router manufacturer for more details. Please note Nintendo provides these recom mendations as a resource to our consumers; it is up to each consumer to determine if adjusting their router's security settings are the right choice for their home network.
  4. It is possible that your Internet Service Provider (ISP) is not compatible with the Wii console. For instance, if you need to login with a user name and password when you try to go online for the first time after restrarting your PC, your ISP is likely not compatible. Please contact your service provider for more information.
Feb 03, 2010 | Nintendo Wii Console
NINTENDO WII
Try this link it's nintendo's tech support:
www.nintendo.com/consumer/systems/wii/en_na/errors/index.jsp
Or this slightly less helpful database of errors:
www.wiierror.com/
May 06, 2008 | Nintendo Wii Console
Nintendo Wii Console Logo
80 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
