Question about Insignia 2.1 Speaker System (3-Piece)
Low volume sound
Controls on speakers and in control panel are to mix but sound is very low; speakers are new. Do I need specific drivers for Sinsignia 2.1 system? I'm running Vista on a new lenevo pc.
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 65 Answers
Your better check the volume control of your computer....i mean the vol contrl on the start menu-accessories........
Posted on Feb 02, 2010
Troubleshooting steps for no sound from the speakers
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administration tools computer management device manager scroll to sound video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to
reinstall drivers
click start control panel sounds and audio volume advanced speakers make sure you have selected the
(appropriate speakers) also audio you will find 3 drop down lists make sure you have the correct settings there
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
if his does not fix the problem
click start control panel sounds and audio devices you can adjust the volume there also select speaker
volume you can change your settings there you can also tick in the box place icon in taskbar for any
further volume control settings you will need to right click on the speaker volume icon system select adjust volume
click start control panel sounds and audio volume advanced speakers select the appropriate speakers
from the drop down list or navigate to the device manager scroll to system devices expand system
speaker right click properties then select use this device (enable) also you might check
the speaker plug/outlets is usually at the back of the computer or if its a laptop on the side
you will have to open up the computer to check the lead attached to the rear of the input plug make
sure the connection is good with no dust as dust causes static electricity
clean your computer of dust using a fine air blower from a compressor making VERY sure that there is
no MOISTURE in the air line specifically around the sound card and the CPU central processing unit
dust causes static to build up in a computer
hope this helps you
Apr 16, 2012 | AcerNote Light 380 Laptop AC Adapter,...
I was listening to music at a low level all sudden sub stopped workin then a week later it worked and just now stopped again
this could be caused by a few things instable drivers ,dust ,bad connections.....
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar for any further volume control settings you will need to right click on the volume icon system select adjust volume
click start control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps you
if you dont have a motherboard disc you will have to download the drivers
Sep 02, 2011 | Logitech Z-5300 Computer Speakers
Almost no volumn on a brand new HP computer
also
hope this helps you
Aug 26, 2011 | Recoton Advent Audio Players & Recorders
Hello please help me!! i have just connected my mikomi speakers to new pc and pc is saying i dont have any speakers installed hence i have no sound!
the sound drivers might not have been installed or have been corrupted
also
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer hope this helps
Aug 17, 2011 | Computers & Internet
No sound
also
Aug 02, 2011 | Compaq Audio Players & Recorders
The speaker system is making a loud rhythmic clicking sound, underneath you can hear the audio at very low volume. The clicking sound does respond to volume control. My drivers are up to date. Don't...
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
also
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
hope this helps
don
Mar 03, 2011 | Bose Companion 3 Computer Speakers
Speakers check ok, sound card ok, but very low sound from speaker even at 100%
you might have to uninstall then restart your computer then reinstall both the sound drivers and the sound card make sure you have both of these devices backed up to a disc before uninstalling
a yellow? question mark means you need to install/update driver to do this
right click to install driver also
also
hope this helps
don
Feb 17, 2011 | HP Pavilion a1730n PC Desktop
Sound is low and garbled coming through both speakers. I have the sound turned up all the way on my computer
click start control panel sounds and audio,volume,advanced,speakers select appropriate speakers also audio you will find 3 drop down lists make sure you have the correct settings there
also
hope this helps
Feb 06, 2011 | JBL Encounter 2.1 Computer Speakers
Only one speaker works and the sound is really low seems like soundbulfer wants to work but its too low and other four speakers dont have no volume at all I think they are completely dead
also
hope this helps
Feb 04, 2011 | Dell ADA745 Computer Speakers
No sound speakers or headset driver install
Firstly check the volume is not low or muted on both windows and the speakers. In windows click the speaker icon in the bottom right of your screen, check the volume is turned up. Then click mixer or advanced and check that all volumes are turned up.
If using a laptop, check that the hotkey control for volume is on. You will see an audio icon on one of your ‘F’ keys, hold the Fn button located near the ctrl and press the volume function key.
Next open Device Manager from Control Panel and check there are no yellow exclamation marks on any drivers. If there are then you need a new driver.
If you are still having issues the sound card may be faulty, this is usually integrated into the motherboard. In a desktop PC you could buy a new PCI soundcard if you have a spare PCI slot in your machine.
You need to goto the manufacturers website, find their support section and there should be a list of drivers for your specific machine. Installing these should resolve your problem. I have a list of links to most manufacturers drivers on my website.
Hope this helps,
www.PuterCare.com
Jul 13, 2010 | Toshiba Portege M700-S7044X Notebook
Insignia 2.1 Speaker System (3-Piece) Logo
123 people viewed this question
Top Insignia Audio Players & Recorders Experts
Alan Matzke
Alan Matzke
jason
Are you an Insignia Audio Player and Recorder Expert? Answer questions, earn points and help others
