Question about Lexmark X2600 InkJet Printer
My printers (Lexmark 2600) intake seems to be broken
My printers intake seems to be broken.The paper rolls in for an inch and then get dragged to the right,then scrambles.I assume the intake rollers are damaged.What can i do?
    President:
  • Lexmark Master
  • 990 Answers
Hello sir; I don't think so, I believed something drop inside the paper tray, therefor, the paper go one side the other side can not move that way skew drag thepaper to pne side, checck it out and clean up!
Posted on Feb 02, 2010
My Lexmark printer 2600 series won't print. It pulls the paper towards the right but won't feed it. How can I fix this?
Leading cause of paper jams is debris/foreign objects that accidentally fell into the paper feed area. Please follow steps below to fix the problem:
1. Remove the sheets of paper from the feeder.
2. Grab a flashlight and look inside the feeder for any debris or foreign objects.
3. If you're willing and physically able, you may also turn the printer over. Any debris should just freely roll out from the feeder.
4. If feeder is clear, place the printer back on the table, open the printer cover and remove the cartridges.
5. Check the cartridge area for any obstructions/debris in the cartridge carrier's path or the paper path.
6. If cartridge area is clear, close the cover.
7. Re-brick your printer. Pull out the power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds.
8. When the printer turns on, reinsert the cartridges and load some paper. Try to print a document again to verify that the problem is fixed.
If problem continues, please contact Lexmark Technical Support Center for additional assistance.
Sep 03, 2011 | Lexmark X2600 InkJet Printer
I have a transfer paper jammed and can't reach any
Try to open the printer where the cartridges are. You might be able to get a better hold of the paper jammed in there. Otherwise, I suggest you contact Lexmark Technical Support for further assistance. Thanks
Jul 16, 2010 | Lexmark X2600 InkJet Printer
Paper keeps jamming. seems tp be pulling to one side slightly.
Usually that is a sign of an object in between the rollers.
Check for paper or other foreign body. It will be located on the side that dragged.
Good Luck!
Tinteiros (Ebay)
Oct 31, 2009 | Lexmark X2500 All-In-One Printer
The paper does not feed properly.
Replace the paper feeder or the rollers on the paper feeder are not rolling ar getting jamed. You need to have this serviced or just get yourself another printer. Lexmark are what I call in my expert advice throw aways the better ones are epson,xerox,HP and so forth. Please leave positive rating and feedback thanks
Oct 09, 2009 | Lexmark X3480 All-In-One Printer
Prnter jam
check in the fuser unit.
Feb 16, 2009 | Lexmark T630 Laser Printer
Paper stops
Check that the rear paper sensor feeler arm is not broken. It is the little black plastic tab that sticks up in the middle of the paper path when your looking at the back of the printer with the cover open. If you can't see it, it's probably broken.
Aug 06, 2008 | Lexmark E234 Laser Printer
Drags the paper in all uneven.
clean the rollers with a little rubbing alcohol.
hope this helps
Jan 09, 2008 | Lexmark Z640 InkJet Printer
Lexmark X83 all-in-one printer
Hi gerby, need to eliminate a few issues to get to the cause. First, check for a jam. Paper jams can be so tiny you can barely notice them. Use a torch and check thoroughly down back of unit in paper feeder, open cover, let cartridge carriage roll left and settle. Now look inside thoroughly too. If no jam, check rollers are even and look same on each side. Post back if no good.
Sep 01, 2007 | Lexmark X83 All-In-One InkJet Printer
Lexmark X2600 InkJet Printer Logo
115 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
