Question about Nakajima AE-740 Typewriter
Skipping parts of the letters
When I type, only part of the letters print out or it is really faint. It does not help to type on bold. I've changed the ribbon and that does not help. Do I need a new printwheel?
  • Anonymous Apr 01, 2008
    How do I get the underlining to stop?
More likely than not the type needs to be properly aligned. If it's out of alignment, it can result in the top or bottom half of the character typing faintly. Basically, the typebar is hitting the platen too high or too low. When it is properly adjusted (by a qualified repairman), it will type properly.
Posted on Apr 11, 2009
  • Nakajima Master
  • 3,594 Answers
If the ribbon isn't moving a full space for each letter printed try code . or , this changes yhe spacing.
DickyO
Posted on Mar 12, 2008
My Brother ML100 is not printing what I type
Hammer sticking and typing incorrect letters (and or skipping letters): 1) make sure daisy wheel installed correctly. 2) hold down CODE key & Q (RESET) to reset wheel...if still not corrected 3) WD40 the hammer at the base & joints where moving parts are, keep typing until oil seeps in (this last one fixed it for me)
Typing light and inconsistant-top part of letter okay but bottom too light or not there: to left of hammer (at base) are 2 screws, I losened them and adjusted hammer to different forward and backward spots..finally found the ideal location where full letter printed and had the correct force it needed to print correctly.
Feb 21, 2013 | Brother ML-100 Typewriter
When printing incoming hotmail message, the subject line is printed in very large & bold letters
Click on the 'print' icon to display a print compatible version, then print. If the problem still exists, use google chrome to change the html code of the text to manually change text size
Oct 19, 2012 | Microsoft Computers & Internet
How do i bold print
Bold underlined itallics fontsizes and colours
Type <b> before the writing that you want bold.
End the bold text, type </b> after the part that you want in bold to go back to normal.
Type <i> or <u>, to write in italics, or underline.
Type <center> to center a selected area. When finished, you will need to type</center>
Type <font color="colorcode"> and end it with </font>,to write with different colored fonts.
Type <font fontsize="size">to change the size of the font you would like to use.
hope this helps
Aug 13, 2012 | Microsoft Windows Vista Home Premium with...
How do you change the letters from bold to regular type?
how do i type bold letters when option for bold is not available
Jul 08, 2010 | Dymo LetraTag QX50 Thermal Label Printer
When printing from word 2007 on vista bold type is gibberish
Try re-installing the printer driver(s) first. If no luck, then un-install the printer completely, reinstall and try again. You may also have an issue with an incompatible driver with Office 2007. After reinstalling the drivers, try to print a test page and see what happens.
Apr 17, 2009 | Brother MFC3240 Multifunction InkJet...
Solution for "why is my hp photosmart 8150 printing part of the page in black letters and part in red letters
Check if the cartridges have enough ink for printing.
Perform a print in different colors and see which one comes faint.
Mar 05, 2009 | Office Equipment & Supplies
WPT-61
there is a key that has BOLD printed under the letter on the key, or it may be printed above the top keys on the keyboard, hold down the code key and hit the key under where it says BOLD, or the key that has it on it. to take it off, do the same thing
Jan 08, 2009 | Nakajima AE-830 Typewriter
My black is really faded, when I print a test page by pushing photo and copy, however when I do a print head allignment the black for the allignment paper is sharp and deap, whats going on? Ive tried to...
The PHOTO mode is for printing grayscale photographs. Printed letters using PHOTO mode may appear faint because PHOTO mode is optimized for halftones. See if there is a TEXT or LETTER print mode, and try printing on that setting. If printed letters are still faint, you may have to go into ADVANCED PRINTER PREFERENCES, and see if the TONER SAVE mode is on. If it is, turn TONER SAVE off. Also, try changing the DPI image density, or try other adjustments in the ADVANCED PRINTER PREFERENCES MODE.
Aug 21, 2008 | Kodak Office Equipment & Supplies
Wong letters & numbers
I downloaded the manual from http://www.devicemanuals.com/downloadguide.php and then, following the instructions there, I removed then re-inserted the daisy wheel. This solved my problem. Perhaps it had somehow gotten out of adjustment. At least, it is something to try if you haven't tried it already.
Jul 15, 2008 | Brother GX-6750 Typewriter
Erronous letters or numbers
Under the ribbon there is a motor that drives the print wheel try to get some light oil on the front and rear bearings (wd 40 usally works well) its a little hard to get to the rear one.
hope this helps
DickyO
Jan 29, 2008 | Lexmark Wheelwriter 1000 Typewriter
Nakajima AE-740 Typewriter Logo
336 people viewed this question
Top Nakajima Office Equipment & Supplies Experts
James Cagle
James Cagle
Daniel Thibodeau
Level 1 Expert
Jim Keysor
Are you a Nakajima Office Equipment and Supply Expert? Answer questions, earn points and help others
