Question about Whirlpool Duet GHW9150P Front Load Washer
How do you open a locked door on my washig machine?
  • 39 Answers
Unplug machine from wall. Remove bottom front panel. Reach up inside the right towards the latch assembly. There is a pull down tab at the bottom of the door latch. Pull down on tab, door lock should release. Be prepared to catch any water that may be inside the drum once door is open.
Posted on Feb 03, 2010
Handle broke off
How to open a washing machine door that won't ... - YouTube
? 3:57
https://www.youtube.com/watch?v=-65_eoT6zuk
Aug 22, 2013 - Uploaded by how-2-repair.com
1 The washing machine door handle may have broken. ... 3 The electronic door lock called an interlock ...
Opening a locked washing machine door - YouTube
? 1:30
https://www.youtube.com/watch?v=gSF4JS2B_U0
Feb 25, 2012 - Uploaded by ScottStorm1
How to open a locked washing machine door when the handle / catch is ... How to fix a washing machine door ...
How to open a broken washing machine door. - YouTube
? 0:25
https://www.youtube.com/watch?v=UCJPkc_dTCE
Feb 26, 2013 - Uploaded by Kim Degerth
How to open a broken washing machine door. .... How awashing machine door lock works, how to test ...
How to Fix Washer With A Lid Or Door That Won't Op
Oct 07, 2015 | Splendide 2100 Vented Washer-Dryer
Having trouble with my whirlpool cabrio . . . showing "DU" . . .
The F30 error code (dU) will flash when the dispenser motor cannot be driven to its proper position.
Door Unlock Error
A Door Unlock Error occurs if the door cannot be unlocked.
It will try to unlock the door 6 times before displaying the error.
Door Lock Mechanism broken.
Check Door Lock/Switch Assembly for foreign objects
Check Wire Harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
Door Lock/Switch Assembly Failure
If it is a cabrio:
dU flashes if the following conditions occur:
Excessive force on door lid is preventing lock bolt from retracting.
Wash media buildup is preventing lock bolt from retracting.
Machine/motor control cannot determine if door lid is in an unlocked state.
TEST #8 Door Lid Lock
Perform the following checks if washer fails to lock (or unlock).
1. Perform Manual: Door Switch and Manual: Door Lid Lock tests.
2. Remove the console to access the machine/ motor control assembly. See Accessing & Removing the Electronic Assemblies.
3. Visually check that the P12 connector is inserted all the way into the machine/motor control. If visual check passes, go to step 4. If visual check fails, reconnect P4 and repeat step 1.
4. Check the lid lock motor winding and switches by removing P12 from the machine/ motor control and checking the
resistance values....
Component/Resistance Unlocked/Resistance Locked/Contacts Measured/Contacts Measured:
Motor Winding/35 ±5 O/35 ±5 O/P12-2/P12-3/
Lock Switch - Home/0 O/Open Circuit/P12-1/P12-4
Lock Switch - Lock/Open Circuit/0 O/P12-1/P12-7
Lock Switch - Lid/Lid Closed = 0 OLid Open = Open Circuit/Lid Closed = 0 O Lid Open = Open Circuit/P12-1/P12-5
If resistance values are good, go to step 5. If switch measurements do not match the values shown in the table for unlocked (or locked) conditions, a problem
exists in the door lid lock. Replace the door lid lock.
5. If the Manual: Door Switch or Manual: Door Lid Lock in step 1 failed, then the machine/motor control has failed: Unplug washer or disconnect power.
Replace machine/motor control assembly. Perform the Manual: Door Switch and Manual: Door Lid Lock in step 1 to verify repair.
Thanks for using FixYa!
Jan 07, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
I have a du code that will not go off and the door is locked.
Door Unlock Error
If it is a cabrio:
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 27, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Clean pump
Remove the bottom panelb5a88d7.jpg or access the pump door if yours has one 39e0b0c.jpgand get that pump mess 5b68d36.jpgout is all.
May 29, 2010 | Whirlpool Washing Machines
Du f flashes as code on whirlpooll whasher??
Door Unlock Error
If it is a cabrio:
Nov 02, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Door lock is locked but door is open
take the kickplate of the machine of and put your hand iside by the door lock , fill a round tab there just pull and the door is going to unlock
Jun 26, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore two way tumble action washing machine - shakes, vibrates very loud
sounds like you have a broken stantion on the back of the basket.you can confirm this by opening the door and trying to pull up on the stainless steel basket.if it pushes up and flops back down,that is what you have.if the mach is over 2yrs old,look in your manual under warranty.if it has a 10yr on stainless steel basket and lifetime on tub,you will only have to pay for labor on repair.if it only has 1yr on entire mach,est would be higher than the price of a new one.
Sep 23, 2008 | Kenmore Elite 45986 Front Load Washer
I have a Bendix Autowasher 800 washig machine. The door lock seems to have broken, with a load inside the machine, and I can't open it to get the load out. The cycle has finished. I think I broke it by...
Have the same problem myself.
Remove top panel from washing machine by undoing two fixing screws to rear and sliding panel forward to front of machine.
Door lock is located internally on right hand side, its difficult to reach and I had to loosen the control dial and switches to gain access.
However it may be possible to release the mechanism by touch.
At the back of the lock mechanism the latch protrudes by approx 3 mm if you can see it or feel it you only have to apply some pressure to the projecting end to release the latch.
The broken release lever can then be removed from the door and replaced by a new part which cost about €6.
Jun 29, 2008 | Washing Machines
Hotpoint WD62
try fuse on plug this may be gone, also the door interlock switch, try a light bang with fist near door catch see if this will do it, what i do suspect is the door inerlock is faulty, this is a safety device which locks the door when machine is in washig/spinning mode it aso stops machine working when you open the door, this is also a safety device, good luck al. xxxx
Jan 13, 2008 | Hotpoint WD62 Front Load Washer / Dryer
Whirlpool Duet GHW9150P Front Load Washer Logo
50 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
