Question about Zonet ZSR0104CP (zsr0104cp) Router
How di i log into this router? - Zonet ZSR0104CP (zsr0104cp) Router
Point your browser to -> 192.168.10.1
default user and pass is:
user: guest
pass: guest
Posted on Mar 25, 2010
    President:
  • 2,992 Answers
Login information for different models is here on Zonet's site. QSL?
Posted on Feb 02, 2010
  • 4,281 Answers
For that Connect your router to computer with ethernet cable then you can access it with following default link.
http://192.168.0.1
or
http://192.168.1.1
If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it.
If you are still not able to access it then press RESET button for 10 seconds it is in back side of router .Then you can access it with above default ip.
Then it ask for user name and password.
Type user as "admin" and password as "admin" or "password" or blank.
Then you can see configuration page of router.
Let me know if you need further assistance.
Thanks for using FixYa.
I like to add a router to my 2wire system
connect modem to net signal then connect router to modem. log on to modem with router then check settings.
Sep 28, 2010 | D-Link DI 514 Wireless Router (DI-514)
Internet connection always interupted
•Your Windows computers that are connected to the LAN ports indicate "Network Cable Unplugged." If you are using another computer or network device, you will get an indication that the Link has been momentarily broken. (Note: Wireless clients may not detect the interruption.)
•If you are using a DI-5xx/6xx/7xx device that supports NATLIST.TXT (not all do), you can get the uptime by using your browser to retrieve http://192.168.0.1/NATLIST.TXT. Look for the line that says "curr time : 369360" and divide that number by 60. The result is the number of minutes since the last reboot or power up.
•The DI-5xx/6xx/7xx router's log has been reset. Over time, the router's log should grow if the router is not rebooting. The last page will have the oldest entries. If your log is shorter than the maximum, the last entry will be the time your router last restarted. (The maximum log size is 20 pages long on many D-Link routers.)
•The lights flash in a particular pattern that you can learn. Go to Tools / Misc. On that page, one item should be "Reboot." Click that button as you are carefully watching the lights on the router. You can use this method to learn the pattern of the lights when the router is rebooting.
Thanks
With regards priya
Aug 27, 2010 | D-Link DI-604 4-Port Cable/DSL Router...
How do I find out what my d link (DI-524) SSID adress
Using your web browser, log in to your router's setup page (usually 192.168.1.1 or something similar) using a wired ethernet connection. Enter the username and password. Check the setup for your wireless network's SSID.
Feb 15, 2010 | D-Link DI 514 Wireless Router (DI-514)
Can I schedule access to my network for devices in my household?
log-in to your router page. to log-in to your router page, bring up your web browser and type in the router's ip address in the address bar then hit enter. Type in the username and password.
Click on the Advanced tab. Click on Firewall to the left of the page. set it up. click on apply when you're done.
Apr 20, 2009 | D-Link DI-604 4-Port Cable/DSL Router...
Can't log into 192.168.1.1
try with
http://192.168.15.1
or http://192.168.0.1
or if u still not access u have to reset it.
reset button is in back side of router press it for 10 seconds.then it reset to daults.
Apr 06, 2009 | D-Link DI 514 Wireless Router (DI-514)
DI-514
PLEASE RATE ;] you can find out whos accessing your router by logging into it. Usually 192.168.1.1 once your in there is usually an option for attached devices or connected devices it should show you what computers or devices are connected to that router
Feb 06, 2009 | D-Link DI 514 Wireless Router (DI-514)
D-LINK DI-604 STATIC IP
Log into the router and go to the configuration page for your WAN port. Change the connection type to static ip.
Apr 02, 2008 | D-Link DI-604 4-Port Cable/DSL Router...
Configuring security for my router
Hello, Put "admin" in for ID and Password both. Some routers require both. Hope this helps.
Feb 24, 2008 | D-Link DI 514 Wireless Router (DI-514)
D-Link router wont let me go onto the net with the wirless router
At the bottom right hand corner of your screen, you have a wireless connection icon. right click and view available wireless network...if you see your network there. connect to that network, if secured, then call d-link to verfiy what is your network key. if it is unsecure then you can log on right away.
if that wont allow you to connect then upgrade firmware of router.
Oct 13, 2007 | D-Link DI 514 Wireless Router (DI-514)
Open Questions:
Save Your Important Data Getting Lost With Cloud Backup Solution of Dataalign You must be using cloud computing now even if you do not realize it. For doing a simple task like sending an email, uploading a video online, downloading work related files it is nothing but cloud computing that is making it all possible behind the arena. Cloud computing is a big switch from the orthodox way businesses think about IT resources. Many Cloud Backup For Small Business services advertise a lot of features, such as fast upload and download and unlimited backup, but often in real life usage these commitments fall short. As the old saying goes you get what you pay for stands true. For extremely basic file storage or sharing, you may look for a low cost, simpler product. However, if you are looking to get the best for your business, you'll need to consider better solutions like DataAlign. We all have masses of unstructured data scattered across laptops, desktops, and mobile devices and this is an ever-growing pain not only for a business but also for a home user. With time scarcity and insufficient security measures to protect these valuable data assets, we decided to create a competent Online Server Cloud Backup Solution Solutions that can not only assist you to organise your data, but secure it with military-grade encryption. Unlike other business online backup services that does not give optimum functionality, DataAlign provide application and operating system backup, 24-hour support, advanced file versioning, compliance-level security, server and NAS backup and infrastructure-as-a-service IaaS features. Of course, these offerings are simple to use and self-explanatory. With our ever growing and latest technology, Data Align Online Backup Pricing Solutions makes data backup, disaster recovery and business continuity uncomplicated and less extravagant as the is mirrored at multiple redundant sites on our network.
Jul 17, 2018 | Best Computers & Internet
See all Zonet ZSR0104CP (zsr0104cp) Router Questions
Zonet ZSR0104CP (zsr0104cp) Router Logo
263 people viewed this question
Top Zonet Computers & Internet Experts
Prashant M
Prashant M
KG John Justin
KG John Justin
Are you a Zonet Computer and Internet Expert? Answer questions, earn points and help others
