Question about D-Link AirPlus DI-524 Wireless Router
Router to Computer connection problem
The router is connected to my modem, when I connect my modem directly to my computer with an ethernet cord to internet works but not when connect to the router. I get a pop- up that says "limited or no connectivity" and cannot connect to any website. I called the D-link helpline and they wanted to charge me to speak to them!
    President:
  • 2,992 Answers
If you're connecting to a cable modem (some other service providers too, but mostly cable), this is usually because the router isn't getting a valid IP address. Most cable modems only work with the connection to the computer originally used to set up the service, and they don't recognize the router as a valid device.
You need to do something called "cloning the MAC address" in your router. The MAC address is a unique address assigned to the network interface in your computer. In the router setup page under WAN settings is where you'll find the clone address function. This copies the MAC address of your computer into the router so that the modem will connect it to the Internet. Once that's done, the computers connected to the router should be able to connect.
D-link's website has an explanation of how to do this on their FAQ page.
Posted on Feb 02, 2010
  • 4,281 Answers
For that Connect your router to computer with ethernet cable then you can access it with following default link.
http://192.168.0.1
or
http://192.168.1.1
If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it.
If you are still not able to access it then press RESET button for 10 seconds it is in back side of router .Then you can access it with above default ip.
Then it ask for user name and password.
Type user as "admin" and password as "admin" or "password" or blank.
Then you can see configuration page of router.
Then you can DHCP there enable it then save settings and restart router.
Then set ip get automatic in your LAN proeperty set ip address get automatic.Then it get ip from router then it works.
Let me know if you need further assistance.
Thanks for using FixYa.
SOURCE:
How to connect a router
It depends on the router but how I did it is
1. Connect the ethernet cable to the router, then the cable that came with the router to the router with one end, then plug the other end into the computer.
2. There should be a disk that you have to install which is the firmware for the router. Once this is done, it will automatically update from now on.
3. It should set up itself!
Oct 25, 2010 | Computers & Internet
Getting ip address, but cannot connect to internet through router. I am connected via an ethernet cord. No problems with modem.
Make sure that your computer is able to go online directly through the modem.
If your computer is able to go online through the modem, that means the modem is working fine.
You will need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for more information about the routers and network
Aug 20, 2010 | Linksys Wireless-G WRT54G Router
I can't get my router to connect to the phone jack
Connect ethernet lan cable to computer and router end.
In router there is LAN port connect lan cable to that port and connect other end of that cable to your computer ethenet lan card.
Then connect phone line jack to router's ADSL Port.
May 07, 2010 | Linksys Wireless-G WRT54G Router
Acquiring IP address and won't connect to wireless
You possibly have your router password protected or have changed the password recently. If you have done either, you will need access the router by the router IP address, then go in and make sure the password you have on the router is the same as the password you have no the computer.
Secondly, make sure that the router is broadcasting correctly. Hard wire(hook the computer directly to the router with a ethernet cable) to see if there is an internet connection flowing thru the router.
Third, ensure that the ethernet cord from your modem to your router is a good cord. Be sure to plug the ethernet cord from your modem directly into your computer to ensure there is a good connection as well.
Reconnect all (modem, router, and computer)
Fourth, power down router, modem, and computer together. Power up the modem first and let all the lights come on. This will renew the connection and refresh the IP address. Once the modem is up, then power up the router til all the lights are powered on the router. Lastly, power up the computer to the desktop and attempt to launch a web browser (internet explorer, mozilla, safari, etc.).
If nothing at this point works, you will have to consult your router manufacturer or a local computer repair shop. Be sure that the technicians working on your issue is certified.
Jan 03, 2010 | Dell Inspiron 6000 Notebook
How can i set up a connection to a network with windows vista basic
There are several ways to do this you can use a router, wireless router or set up a direct connection. With a router all you have to do is connect your modem to the router and computers to the router. For a wireless connection you need a wireless card installed in your computer and a wireless router. You connect your modem to your router and set up your wireless connection with the software that came with your card or through windows wireless service. You can also connect two computers through their ethernet port with an ethernet cord. You plug coonect them with the cord go into control panel open network connections and to the left chose set up home or small office network. You will need to configure the computer with internet access as the host and the other as a guest. You can share any type of connection such as dial up, cable, dsl, and broadband.
Dec 30, 2009 | Microsoft Windows? Vista Home Basic...
How do you connect to internet via Ethernet cord, do you go to computer tower or directly to router modem?
The best thing to do is connect it directly to router modem. If it is too far away then computer tower.
Here you have the instructions on how to set this up:
Dsl Modem and router
Cable Modem and router
You can find all this info here:
PSN
Hope it helped.
Nov 24, 2009 | Sony Playstation 3 (PS3) Console
Trouble connecting netgear wireless router to rca modem DCM425
First try connection the Yellow ethernet cable from the rca modem to your computer's network connection. If you get a connection this way, then your modem will work with a ethernet cable. If not, then call Comcast for help. The modem ethernet out to computer port must be connected to the wan line of the router. Then you can connect an ethernet cable from your computer network connection to one of the 4 ports of the router. For wireless connections you must set up the router and wireless adaptor with the same settings to connect. Follow the routers directions.
Good Luck
Jul 10, 2009 | RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
Still not connected
vhevk your ethernet cable wire.
if u connect router to swithc then use straight cable.
if u use router to computer use cross cable.
Jan 10, 2009 | Linksys Wireless-G Broadband Router
Adapters Compatible with the Westell E90-610014-06 Router?
run the modem to the router with Ethernet cable and then use one of the other Ethernet ports on the router and another Ethernet cable to connect desktop
Mar 04, 2008 | Westell Wirespeed LiteLine 6100...
D-Link AirPlus DI-524 Wireless Router Logo
133 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Mike
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
