Question about Mitsubishi WD-52531 Television
What does a blinking orange light on my Mitsubishi WD-52531 mean?
    New Friend:
This man eddie is right.^ it helped my tv!!!
Posted on Nov 11, 2013
5 Suggested Answers
SOURCE:
eddiepeezy
  • 130 Answers
SOURCE: Mitsubishi WD-52531 not working after replacing
Check to make sure the lamp is in correctly and that you've closed everything up properly. If you don't close the cover, the sensors will tell the computer in the TV that the door is open and won't let the TV turn on.
Other than that, could be a bad lamp or bad ballast.
Always buy OEM lamps, or better-than-oem equivalents! Philips lighting is the best lamp manufacturer out there for these TVs. They invented the thing!
Buy from Authorized distributors, and don't buy the "cheap" stuff. savnig 20 bucks will cost you more in the long run--believe me!
Posted on Feb 05, 2010
salt56
  • 373 Answers
SOURCE: the lamp light is blinking
You may have not plugged the lamp in fully or have not put the lamp door back properly. If you have done this properly and have the blinking problem then you are likely to have a bad ballast. This ballast supplies the voltage to light up the lamp. But first look on the front of the set for a small push button that says "system restore/reset". Use a ball point pen to press.
Posted on Jun 28, 2011
blackbear776
  • 14 Answers
SOURCE: What does it mean when the status light is
When the status light is blinking push the device and menu buttons on the tv at the same time and hold for 5 seconds or more. The red light will then blink a code. It will blink like 3 times, pause, then blink like 5 times. That would be a code of 35. It may blink one time long, then two short blinks. That is not a code blink but indicates another problem. Do a search for the service manual for your tv on the internet and look up the code. Sometimes it is as simple as a dirty fan that won't turn any more. But by knowing the codes you will know if you need a technician or if it is something simple.
Posted on Nov 16, 2011
  • 142 Answers
SOURCE: red light mitsubishi wd-52531 what do i do
red light indicates that your tv is getting 5V. supply from power supply. but it does not indicate that microcontroller which is responsible for functioning of tv is working. if you are a technical able person then you can check micro controllers' power supply, its oscillation, its reset voltages, its key matrix, & infrared receiver. so you will be sure where the fault is. or you may call an tv repair expert.
Posted on Oct 25, 2011
Mitsubishi wd-73c9 status light blinking orange won't turn on
may need the lamp replaced pt# 915B403001
Recommend Phillips, OSRAM or Mitsubishi original (as from experience others will not work or will have very short life)
http://www.shopjimmy.com/dlplamps?tv_brands_select=Mitsubishi&tv_models=Mitsubishi+WD-73C9
Mar 08, 2015 | Mitsubishi WD-73C9 73" DLP TV
Bad Lamp for TV
Can't get a reception with my ws-a55 tv
Feb 15, 2014 | Mitsubishi WS-55809 55" Rear Projection...
Flashing orange light on mitsubishi 60737
The orange blinking light means a light bulb needs to be replaced. You should go to a Mitsubishi store and see if you can get one. Good luck
Take the old one with if you can get it out.
Aug 01, 2012 | Mitsubishi WD-60737 60 in. HDTV
Replaced lamp but lamp light still blinks orange
I have a wd-57731 The lamp light blinked orange. i replaced the lamp turned the tv on and the timer blinks green for one minute and then the lamp light blinks orange again. It won't turn on. Can you suggest anything?
Nov 22, 2011 | Mitsubishi WD-57731 57" Projection HDTV
The lamp light is blinking orange and we just replaced the lamp! on model WD-52531
Jun 28, 2011 | Mitsubishi WD-52531 Television
Blinking orangr lamp light
It is time to change the lamp.It is building up internal resistance and it will get to the point it will not come on at all, change the lamp.
May 02, 2011 | Mitsubishi WD-52531 Television
Mitsubishi WD-52531 not working after replacing the buld.
Feb 05, 2010 | Mitsubishi WD-52531 Television
Mitsubishi WD-52531 Television Logo
9,623 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
