Question about Avocent SwitchView MM2 (4SVPUA20001) 4-port KVM Switch
My wireless mouse is USB and plugged in the front of the KVM but it over reacts and is uncontrollable. What am I doing wrong?
Wireless keyboard and mouse works fine with computer but when I attempt to use it on the f1dh104l switch it does not recognize the mouse or keyboard. it is a dell e6400 laptop that i'm attempting to...
the problem is that most Wireless Keyboard and Mice combos use Composite USB, the KVM however is expecting one signal on each entry port (one for mouse, and one for Keyboard).
replace yoru wireless Combo for a standard Keyboard and Mouse to make this work.
A work around would be using a MS Wireless Mouse and a different brand of Wireless Keyboard using both Wireless receivers and plug them into different ports on the KVM
Jun 05, 2011 | Computers & Internet
Just hooked up the KVM cable and when I switch to the second computer, the mouse and keyboard do not work. Can someone help me with this?
Sounds like there's a bad connection on the second computer, may just have to plug another mouse/keyboard in.
(I sometimes use a wireless usb keyboard/mouse combo)
Jul 03, 2010 | IOGear GCS632U 2-port KVM Switch
Hi . .. I want to use this KVM switch to connect
The GCS632U has keyboard and mouse emulation that may not work with all wireless combos. If your wireless combo is going to work the single USB connection would need to go into the keyboard port as that is the only port that will recognize the hot key switching commands. If the wireless combo still has problems then try using a USB wired keyboard to ensure the GCS632U is working correctly.
Mar 18, 2010 | IOGear GCS632U 2-port KVM Switch
Brought a CS62US and Mircosoft KB with mouse. When USB combo plugged on the left USB, only KB is worked together with switching function. When USB combo plugged on the rigth USB, both KB & Mouse worked...
Unfortunately, this switch has a dedicated port for keyboard that listens for the keyboard keystroke. You MUST plug the keyboard into the dedicated keyboard port on the KVM switch for the hotkeys to work. I recommend putting the mouse that comes with your keyboard to the side, and using another mouse, plugged into the dedicated mouse USB port on the switch. Not the prettiest solution, but some of those mouse/keyboard combos have some funky hardware!
Feb 17, 2010 | Altusen Aten CS62U-2 Port USB KVM Switch
4-port usb kvw switch #GCS634U
The GCS634U is designed and tested to work only with a standard USB keyboard and mouse. However, most wireless keyboards and mice work with it, but they cannot guarantee any specific model or brand that would work correctly.
As you can see, this KVM switch is a bus powered device (meaning it only gets power from the USB ports of the computers). If the computer cannot provide enough power for the KVM switch to function correctly, then the wireless keyboard will be affected.
You may try using the IOGEAR GKM541RA. It's tested to work with the GCS634U. Or you may also try using a self-powered USB hub (meaning, it has it's own power adapter) and connect it in between the KVM switch and the computer. That self-powered USB hub will be the one that will add up power to the KVM switch and help it to function properly.
Jan 12, 2009 | IOGear GCS634U KVM Switch
Windows XP using Wireless Intelimouse with KVM switch exhibits erratic behavior
Hi
What type of mouse do you have plugged into the KVM ?? PS2 or USB and what type of KVM switch are you using.
Respond back and I will look into it for you.
/SPH
May 19, 2008 | Computers & Internet
KVM converter
Buy a usb hub and an usb extension, so that you can have 4 or 6 free usb at the front of your computer, and you can switch devices using usb rather then the mouse converter . Using the converter on mouse and keybord make easier for the plugs to slip out, and usb is better. Note some usb modem and some other device do not support usb hubs, you have to plug them straight into the free computer plug , if you have any.
Apr 09, 2008 | Computers & Internet
KVM GCS1734 with microsoft wireless mouse/keybrd 4000
The MS keyboard & mouse receiver is effectively a USB hub with two devices connected to it. So, plugging it into the keyboard socket on the KVM switch may well work, depending on how that particular switch implements USB. If it just passes things through, it should be OK. On the PC side you should only need to plug in the USB cable from the switch's keyboard port.
Sep 30, 2007 | IOGear USB gcs1734 4-port KVM Switch
Can't Use Wireless Mouse
I?ve had issues with USB mice on the more inexpensive KVM switches. I?m currently using a Belkin OmniView using a Microsoft Explorer USB optical mouse and a PS2 to USB adaptor. The adaptors I use are from Cyberguys.com and work well for most of the USB mice we have.
Nov 09, 2006 | IOGear MiniView 4-port KVM Switch
Avocent SwitchView MM2 (4SVPUA20001) 4-port KVM Switch Logo
103 people viewed this question
Top Avocent Computers & Internet Experts
Peter Parker
Peter Parker
Are you an Avocent Computer and Internet Expert? Answer questions, earn points and help others
