Question about PfaFF Sewing Machines
I have the pfaff 18.8 and qbot... I am having a
I have the pfaff 18.8 and qbot... I am having a very difficult time finding needles and bobbins. Also, I have no operator's manuals. Can you help?
quiltergranny
  • 18 Answers
SOURCE: Needle hits the bobbin casing.
check to see the bobbin is in correctly first, is the needle in the centre?
Posted on Nov 24, 2009
  • 192 Answers
SOURCE: How do you connect Qbot to a Pfaff 18/8
Don't put the blame on the equipment and instruction manuals. Put the blame on the dealer that sold you the equipment. That is who should be ultimately responsible to you to make sure that everything is working together properly.
Most reputable dealers will have some type of support for you if you are having a problem using products that they sold you.
Now, in your dealer's defense, if you refused to include set up and support in your purchase in order to negotiate a lower price, or, you purchased from multiple dealers or (heaven forbid) online, you are now on your own unless you can get a knowledgeable person to adopt you.
Many dealers are willing to forgive your transgressions of getting the best price if you will purchase a set up package even if you purchased elsewhere. Remember, we make a living selling machines and keeping our clients happy. If a shopper purchases anywhere the product is cheaper and then we spend our time offering free service, we go broke and our loyal clients are left out.
Remember two things:
1. Build a relationship with a reputable dealer and they will take care of you.
2. Shop for that reputable dealer first, shop for a make and model second. If you don't have a reputable dealer, the brand name means nothing.
Posted on Feb 16, 2010
  • 255 Answers
SOURCE: I am using black bobbin threaad with white needle
In my experience, I can adjust the tension on my older machines (like my Singer Featherweights so that the needle thread will not show at all on the underside of the fabric (and the bobbin thread will not show at all on the top)--but I've found it nearly impossible to get the same degree of control on my newer (computerized) machines. It always seems that there is a touch of the needle thread showing on the bottom and a touch of the bobbin thread showing on top.
I'm not familiar with the MegaQuilter but I'd just keep playing with your tension control to get it as fine as possible.
Robbie
Posted on Aug 02, 2010
  • 54 Answers
SOURCE: Pfaff Varimatic 6085 purchased June 2001. Second
a bent needle can cause this, or you have a hook to needle timing problem. something could hve worked loose.
Posted on Aug 17, 2010
  • 35 Answers
Many users also had the similar bobbin locking problems. I suggest you to order the following product:
Sewing Machine Repair Guide
It's a professional repair guide written by an expert. Besides PfaFF sewing machine, you can learn how to repair other brands of sewing machine as well. The author claims that you can earn money after you had learned the repair skills!
Good luck.
Posted on Sep 08, 2010
How to remove broken off needle from pfaff machine
Pfaff Machines are difficult to work on so I would only recommend you to take it to your repairman.
For the basics though you can remove the bobbin case assembly and see if you can see where the needle may have dropped and gotten caught on the bobbin case assembly. Replace the bobbin case assembly after you have tried to remove the piece. If you can pick up your machine and shake it slightly and hear the part moving around then you can feel sure it is on the bottom of the box that holds the machine. As long as it is in this location it won't pose a hazard for your machine. If you still feel there is a hazard then go to your local repairman.
Apr 14, 2017 | PfaFF Sewing Machines
I got pfaff expression 2 not stitching i have rethreaded changed needle reloaded bobbin cleaned out all of bobbin area
If the thread is not picking up the bobbin thread and you have installed a new needle, then your machine is not in time. Search for sewing machine timing or take it for service.
Dec 24, 2016 | PfaFF Sewing Machines
Needle Jams In Bobbin Case Area pfaff 1540
First, make sure there is no debris and scraps of thread in the bobbin area. I'm sure you did that already. I assume you also tried it with another thread just to be sure. I would suspect that the timing went out of whack. The machines depend on a synchronization between the needle motion and the bobbin action underneath. I once had a Singer that slipped and I had to reset the timing. If it is the timing synch problem then it would happen consistently and not work sometimes and then not work other times. G
Jan 27, 2014 | PfaFF Sewing Machines
MY 18.8 PFAFF WITH IS SKIPPING STICHES I HAVE THE QBOT
Skipped stitches
1. The needle is not inserted correctly
Remove needle & reinsert needle( flat side towards the back of machine)
2. The needle is damaged
replace with new needle
3. The wrong size needle is being used
Choose a needle to suit the thread & fabric
4. The foot not attached correctly
Check & attach correctly
Jan 12, 2013 | Sewing Machines
How do you connect Qbot to a Pfaff 18/8. The instructions for setting up the inspira quilt frame, Pfaff 18/8 and qbot are very poor. The frame dvd didn't work and directions are not precise. The Qbot...
Jan 26, 2010 | Sewing Machines
Needle hits the bobbin holder and doesn't grab the bobbin thread
Check you have the right size bobbin case the gap where the needle enters should be 13mm approx at the widest point. A lot of other pfaff bobbin cases seem to fit and can be easily be mistaken. I have two pfaffs and have accidentally mixed the cases and had a similar problem.
Mar 04, 2009 | PfaFF Creative 7570
Bobbin holder problem. Needle hits bobbin holder and doesn't grab the bobbin thread. It will break the needles if persisted.
Is the needle all the way up in the holder? Have you checked the timing with the bobbin and the needle. Look in your manual for needle timing
Mar 04, 2009 | PfaFF Sewing Machines
Pfaff Select 1540
Search for:
Lots of web sites and videos available.
Jun 28, 2017 | PfaFF Hobby 4260
Bobbin Winding
How do I wet wind a 2 inchs long bobbin using varnish.
Thanks
Gholam
Jun 16, 2008 | PfaFF Creative 7570
Sewing Machines Logo
178 people viewed this question
Top PfaFF Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
