Cant get my cd drawer to open i push the button and it wont open try pushing button and pry at the same time and nothing happens have emachine T3508
With your computer power turned off, use a straight mini-kabob pin (or sturdy paper clip) to manually let out the DVD drive tray. There is a little hole under the drive tray door that accepts this kind of tool device. Another option is to massage the door while trying to eject the DVD drive tray. This method requires your computer to be turned on and by selecting the proper drive (E:) from the My Computer in Start Menu, you then "Eject" and can push in on the door and on the corners, enabling the DVD drive tray to open.
Posted on Feb 03, 2010
NEW LAPTOP CANT OPEN CD DRAWER, WHERE THE HELL IS THE BUTTON, IT SEEMS STUCK.
When first powering on this laptop, you should push the button on the left side where the CD/DVD drive is located. You should also push F10 to stop it from loading an OS and it will enter into bios where the CD tray can be opened.
Feb 24, 2014 | Compaq Presario X1000 Notebook
Opening cd player
What about opening the cd player?
Are you saying the cd drawer will not open when you push the button? If so, try the steps below.
Take a paper clip (Gem Clip) and straighten it out then get in front of the cd drawer where you place the cd. Look for a small tiny hole on the drawer and insert the paper clip (Gem Clip) into the tiny hole and push it in while you press the button on the drawer. Don't worry about breaking something, use a little force to push the paper clip in, that's why that hole is there.
May 31, 2012 | Samsung Computers & Internet
Cdr drawer won't open on Philips cdr 800.
looks like the rotor is jam or broken,try to unscrew it and open the top cover so you can see the rotor and then plug it in to the power source ,then always press the open/close button and check the rotor if its jam or broken and see what happen.
Jun 06, 2010 | Philips CDR800 4-Disc CD Recorder
The CD drawer doesn't open...I push the button and it sounds like it's going to pop the lil drawer open...nothing happens. Help pls...
take a paper clip and streighten it out in a long wire - you should see a hole in front of the cd rom by the drive bay press it in the hole and push the drive open
here is a video
http://www.youtube.com/watch?v=kscn5_XG2oE
Dec 27, 2009 | Compaq (120192-B21) CD-ROM Drive
CD-ROM not opening
The eject mechanism is driven by a seperate belt. You'r's is worn or broken, however, there is a small pinhole in the face of the player that you may stick a paperclip into and the tray will open.
Oct 09, 2009 | E-Machines emachines (emachinees) CD-ROM...
Cd rom drive won't open
i had the same problem i solved mine by using a knife and using the tip of the blade to push up and pull out on the drive while it tries to open and drive opened with out a hitch.. it turned out to be a gear problem with the drive.
Jan 07, 2009 | E-Machines emachines (emachinees) CD-ROM...
DVD/CD ROM does not open
There should be a small hole on the front panel of the DVD-ROM. Take a paper clip and insert it into the hole and push to open the tray. If the DVD-ROM tray continues to malfunction, you'll need to replace it. DVD-ROMS run anywhere from $25.00 to $75.00.
Oct 01, 2008 | E-Machines emachines (emachinees) CD-ROM...
CD problems
hi you push the button and it dosent work? maybe the button went bad push harder pull the button out ( if possible) and push with something small and hard you hear anything after you push? if soo then the drawer is stuck or the engine is about to die (not enough power to open the drwer) take a flat screwdriver and shove it (gently) between the carack of the drwer and try helping the drawer out maybe a plastic wheel will brake from this soo be careful in the end these system are ment to start dying after 5 years soo if this is the case sorry wont do any good have a good one
Mar 26, 2006 | Sony CMT-HPX9 CD Shelf System
Computers & Internet Logo
297 people viewed this question
David Payne
David Payne
