Question about Saniflo 013/003/005 Sanibest Toilet with Grinder Series Pump in White Round
Much louder noise from the unit than usual. The system was fitted by a plumber in an en suite. It services a power shower, wc and basin. The basin when emptied backflushes the shower, which doesn't always drain away quickly. The unit used to flush well, with acceptable sound, but now the flushing seems mimimal and a much louder, vibrational noise
    Sniper:
  • 82 Answers
The Sanibest has a pressure sensitive switch that activates when the water pressure inside the unit gets to a particular level. It is basically a microswitch sealed in a watertight container.
If the Sanibest has got gunked up inside it is possible that the unit is not kicking in soon enough and the water is backing up into your shower.
Another possible issue is that something has got into the Sanibest that should not be there that is impeding the flow out of the unit.
For both cases I would suggest that you empty the cistern and WC bowl after running clean water through th unit for a few miunutes (makes the job a bit less horrible!).
You could also try and use SaniFlo cleaning product and hope that it clears the potential blockage http://www.sanifloproducts.co.uk/products/Saniflo-Products-Saniflo-Descaler.html
** ENSURE THAT THE VERY FIRST THING YOU DO IS TURN OFF POWER TO UNIT **
1. Turn off the electricity to the unit (should be on a fused spur)
2. Disconnect the pipes (inlet and discharge) - you may get a bit of surplus water coming out so have some sponges and a bucket ready.
3. Disconnect the wiring and take the unit out
4. I clean my Saniflo's outside with warm bleach water ..
- Wear rubber gloves to keep germs out of any cuts you may have / get on your hands
- Put the elextrical cable in a taped up plastic food bag or similar to keep dry
- undo the 'star screws'
- Flip up the plastic retaining tabs with a flat blade screwdriver and gently ease the lid up.
- I put bleach and warm water in, leave it for a while (30 mins) and then swish it around and empty out into an outside drain etc
- If you want to use an old toothbrush to get into the areas by the float switch and under the motor it does help. I also used a hosepipe in the past which did the trick.
- Also pay attention to the inlet port and the actual pipes under your sink for gunk
put it back together, aligning the seal and plastic clips should just pop on (may need a firm push). Do up star screws and you are ready to reconnect the pipes and electrics.
I use some tissue paper to check for any leaks around the pipes just to be sure!
Another point to note is that you can insert a simple non-return valve into the pipe near the shower to stop the water coming back up; however this is not addressing the root cause.
Hope this helps - if so, please leave feedback. If not let me know and I'll try and help some more!
Posted on Feb 02, 2010
Hi, is there a way to make the hot water hotter in a 2016 Jayco Journey. The water is just hot enough for showering but not hot enough to wash the dishes.
remove the unit that mixes the hot and cold water at the hot water system to prevent scalding of people
it is fitted there by law but unfortunately the plumbers who fit it are not willing to fit it where it is supposed to be fitted ( baths , showers and hand basin taps and lines )
better and cheaper to fit just one than several
it is not required for sinks and dishwasher and washing machines lines
anyway the human hand cannot stand water over 75 c as that when burns occur so having hotter means that you have to add cold to be able to put your hands in the water and that sort of defeats the purpose of having hotter water
Apr 05, 2017 | Home
Looking for an extension valve for shower faucet #108 191 Glacier Bay product.
Fixya is not a buying service. You may have to have the "plumber" redo the job; he forgot to measure the setback distance allowing for surface mounting of the escutcheon.
Nov 13, 2016 | Plumbing
My 12 yrs old house has now got excessive clonking noise coming from the internal pipe system-seems to occur every 20 mins or so-even I believe caused the fracturing of the backing plate where clamp...
Normally clonking noises are caused by loose pipework.
As the valve closes the inertia in the water bangs the pipe against the wall.
For instance in heater radiator systems it can also cause a continuous banning noise when water under pressure is pumped through it, usually in sync with the rotation of the pump motor.
Mar 13, 2015 | Home
What brand plumbing in shower
most taps for bathrooms have replaceable spigots and handles of various design that suit the shaft. I would be talking with a plumber as to what you have and as to why any spigot assy will not fit. Even if you have ceramic inserts they still fit the tap proper.
Jun 17, 2013 | Home
Water is flowing back to shower tray macerator not switching on
Usually Saniflo requires 8" or 9" from top of p-trap to floor level, not from top of shower base to floor level. If the base is raised 8" then you will have enough room to fit a p-trap without cutting the concrete, if you had cut the floor to fit the p-trap then the base is not raised high enough to maintain the water pressure inside to engage the unit.
Mar 22, 2013 | Saniflo & Saniplus& Macerator Pump
I have redring expression 500, the power is on but no water coming through, no noise from the shower. could this be the solenoid valve
Replace the shower unit.There never worth repairing after five years use.You could end up paying £80 for a plumber and £60 for a part and something else goes in 6 months
Aug 06, 2010 | Home
My thermostatic mixer shower will not turn off
he probably put it together wrong.
there is usually a blue gasket inside for testing purposes, if that is not removed, the valve will not turn off.
May 12, 2010 | Grohe Integrated 1/2'' Shower Thermostatic...
Saniflow plus works allright for w.c but will not work for shower
Thanks for the clarification - This rules out power supply to the unit, motors/pump and points more towards why the water would be pumped from the WC flush and not the basins ...
1. The Saniflo range of macerators have a pressure switch that engages when the water pressure inside the unit activates a microswitch that is encased in a waterproof container. It is possible that the water pressure from the shower and basins is not great enough to activate the internal switch.
So, I would propose two checks
a) If the unit previously worked for the shower and basins something has changed and it is most likely to be gunk inside the unit causing the switch to be less sensitive and only activate on the high pressure that the WC would provide. The fix would be to open up the unit and clean it - please let me know if you need info on how to do this
b) If this is a new install and the shower and basins never worked, you should check the fall in the pipework into the Saniflo is sufficient (should be 1 in 70 from memory - full install instructions are available from the Saniflo website)
c) It could be that if the unit has been in for a long time with a large number of operations that the microswitch is starting to fail and is not as sensitive as it once was (quite unlikely) - but always a possibility!
Replacement microswitches are freely available online and you should also be able to get the exact match spares from Saniflo
If this helps please leave feedback - if not please let me know and I'll try and help some more!
Good Luck :)
Feb 05, 2010 | Saniflo Sanibest Grinder Pump Only 013
Only HOT water coming out of Redring Expressions 520 Power Shower
Hello philipknowle,
Regretfully we have cowboy plumbers on this side of the pond!! I Sent you a few links that should help. The last one is the installation manaul (12pages) The Middle one looks like a 60 page catalog. And the top one is the company website.
Please rate this response and best of wishes, Phil
www.redring.co.uk
http://www.protimbathrooms.ie/downloads/pdf/RedringBrochure.pdf Pages 21-23 looks like there is a 3 year guarantee on these units.
But this looks like the manual for this item
http://www.applied-energy.com/clientfiles/File/manuals/redring/Powerstream%20Instructions.pdf
Dec 28, 2008 | Home
Shower too hot
Hi sallypenn
I'm Harvey the Master Plumber.
Your question seems to be how to adjust the temperature of a shower valve?
I'm going to assume this is a single handle faucet. Most are adjustable under the handle. This is the responsibility of the installer but sometimes they forget and you can't get them back. Anyway this requires a little mechanical ability and a few tools.
First be sure to turn off the water to the faucet, then remove the handle (allen wrench or small screw driver). Most have a temp. adjustment ring right there. Simply pull out, rotate and replace. With some you have to remove the sleeve or bonnet under the handle to expose the adjustment fitting. Reasemble and turn on. It is not uncommon to have to do this two or three times before the customer is happy with the setting. The adjustment fittings usually don't have tenp. setting numbers to go by so it might take a few tries.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 06, 2008 | Home
Saniflo 013/003/005 Sanibest Toilet with Grinder Series Pump in White Round Logo
394 people viewed this question
Top Saniflo Home Experts
Donni Steen
Paul Carew
Are you a Saniflo Home Expert? Answer questions, earn points and help others
