Question about Car Audio & Video
Looking for the value of the resistor R140 for a fender amp Super 210
  • 2,069 Answers
R140 = .47ohm
Regards
Posted on Feb 17, 2010
Jvc subwoofer will not power up
you can get the value from this link..
http://www.doctronics.co.uk/resistor.htm
Nov 01, 2008 | JBL LC-S960 Car Speaker
Fender super 210 guitar amp
8 Ohm. Here is a nice trick for you. If you use the ext speaker wire it the wrong way the + to black and the - to red. This puts the speaker out of phase with the others. Some like this effect. Have Fun
Aug 13, 2014 | Fender Music
Fender FM65R Distortion
It seems to me that you have the operational amplifier working on an open loop configuration (feedback resistor is open or its value is too high). You say you traced the signal path to the op amp's pins 2 and 3 and that the signal seems to be OK there, so with that on mind, I suggest you to measure the feedback resistance of your op amp (IC u7). To accomplish this, measure the resistance value from pins 1 and 2 and compare this reading to your circuits feedback resistor's value. You should be able to tell which resistor is your actual feedback resistor by determining which resistor is connected between pins 1 and 2 of your IC u7. I am assuming you are familiar with resistors color codes. If you need further assistance, please let me know or send me a personal e-mail. Best regards and good luck!
Nov 16, 2012 | Audio Players & Recorders
Fuel relay on a 2002 f250 super duty, no manual
  • The fuel pump relay is in a junction box under the hood. The junction box you are looking for is the one closest of the two to the fender and of the three relays in there the relay closest to the fender is the fuel pump relay.
  • Also, here is a diagram of the fuel pump fuse. #40 - 20 Amp fuse.
  • Also make sure to check to see if the fuel pump shut off switch.
  • Hope this helps.
Regards, Tony
Oct 16, 2011 | 2002 Ford F250 Super Duty SuperCab
I got these subs given to me brand new from my dad and was not sure on how to wire the duel voice coils. Could you please tell me the different ways to wire the coils for the different ohms. Thanks, Gerald
Ok..If each coil is say 4 ohms and you wire them in parallel you will obtain 2 ohms...in series you will obtain 8 ohms...remember..series resistors add together and parallel resistors(of the same value) divide...so if you were to wire all 4 voice coils in parallel, then you would obtain 1 ohm...or, if you were to series all 4 voice coils then you would obtain 16 ohms...a lot of amps are not stable down to two ohms..the way we did it old school was to parallel each speakers voice coils to obtain 2 ohms..and then we would series the 2 speakers in the box to obtain the 4 ohm load needed by the amp
Jan 07, 2011 | Jensen KS-210 Car Subwoofer
Fender hot rod deluxe tube rattle.
Fender hot rod´s have an common problem on the plate resistors of the preamp and phase inverter tubes.
Check if the 100K and 82K resistors on the tube socket board are not brown. Those resistors usually need to be changed to bigger ones 1/2W.
this guy made a good document about this fix:
http://home.comcast.net/~fredholz/Justin-Holton/Fixing%20Loud%20and%20Intermittent%20Crackle%20or%20Static.pdf
Apr 01, 2010 | Fender Hot Rod Deluxe Guitar Combo...
Fender Rumble 100 210 pop noise then hum after strong low e note
Replace C21 (10uF/50V) and C38 (2.2uF/50V) and it will work great.
Feb 22, 2009 | Fender Rumble Series 100/210 100watt 2x10...
Fender reverb mod both channels
Go to http://www.silvertoneamps.com/micKfender/Fender-Reverb-Both-Channels.html
there is info on this mod. heed the warnings of hot rod activities!!
There is a solution to your misguided nods you mentioned earlier.
Dec 16, 2007 | JBL Control 23 Speaker
Car Audio & Video Logo
18 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
