Question about Asko 1385 Dishwasher
The top rack of our Asko dishwasher spontaneously slides forward when we open the door and pull out the bottom rack. I can't get it to catch and stay back. This seems to happen regardless of whether the top rack has items on it or not.
  • 641 Answers
SOURCE: dishwasher leaves residue in top rack only
Most cleaning problems are caused by the dishwasher not getting enough water. It could be cause of the switch level, which control water level in the tub. The switch level is usually a diaphragm device with a small clear tube attached between the switch and the bottom of the washer's outer tub. I am not familiar with your machine, but if you will open the rear panel you will find it easily. Be aware you should discoonect the power cable !!! Clear the tube (attached between the switch and the bottom of the washer's outer tub) from any obstruction.In case it will not solve the problem, you should replace the switch. Good luck !
Posted on Jun 01, 2006
  • 351 Answers
SOURCE: ASKO dishwasher
F2 fault water in the base remove dishwasher from under the bench and tip back water will run out,then it will restart.remove rear lower panel and run the dishwasher you may find a leak,also check that the inlet valve is shutting off and not filling the dishwasher up overnight.hope this helps.
Posted on Mar 28, 2008
SOURCE: Just installed new dishwasher top rack will not slide in
I had the same problem with my new GE. They installed 2 brand new upper racks.$$ it worked ok for about a month and then I had to force it in again. on the 7th repair call in as many months my repair guy walked in the door stating that he finally knew how to fix the problem. It is caused by poor design in the wheels. they are porous and the detergent breaks them down and they swell. new wheels from an older model fixed the problem. they have RND on the case.
Posted on Jun 18, 2009
hondo73162
  • 132 Answers
SOURCE: Top rack of dishwasher seems to deposit particles
check the holes on the sprayer for the upper rack, somtimes they get pluged up and the top rack dishes wont get sprayed off. if they are pluged remove them and wash in a sink
Posted on Oct 26, 2009
  • 382 Answers
SOURCE: The top rack on my Asko D1796 dishwasher is defective
call manufactuerer and ask or a good appliance parts and repair they usually are on a spring clip and you just replace the whole roller
Posted on Dec 25, 2009
ASKO 1375 Dishwasher top rack keeps rolling out
Your dishwasher may have sagged since being level when installed.
May 20, 2016 | Asko 1375 Dishwasher
Top rack automatically slides out upon opening door
This is actually a feature to allow the user easy access of sliding out the top rack. A look at the parts diagram disclosed that there is no mechanism activating this and therefore could be assumed to be gravity driven. It would stop a few inches due to the action or rather inaction of the rollers which would require user intervention (pull).
The only modification I could think of is to change how the inner rails are attached by inclining it to prevent the sliding out. The idea would be to lean in the upper rack to prevent gravity from sliding it out. Am not sure if inclining the entire dishwasher would affect the overall performance but it is also a possibility.
I have taken the liberty of including the diagram of the upper track should you wish to reference it.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Jun 28, 2008 | GE PDW8680NSS Built-in Dishwasher
Hi Just bought and installed a Bush wkp12-9348 integrated dishwasher. There seems to be a problem with the door. When I open the door the spring seems very tight and tries to close. I am unable to unload...
Open the door...PULL THE RACK OUT...and unload. I mean, really??
If the bottom rack is loaded it sits on the door. if its the top rack ..open door, pull out rack, and unload.
Jan 12, 2018 | Dishwashers
Top drawer
Hello, Welcome to FixYa. Based on the info you provided it's likely a pretty easy fix. The machine is leaning forward slightly and it shouldn't be. Remove the top screws fastening the machine to the counter...if applicable, some are on the side if granite counters or similar exist etc. Then take off the lower kickplate/access panel and screw the front leveling legs down ( which will cause the tilting of the machine back slightly ) and screw the back legs up, hence the rack should no longer slide out on it's own. There are also locking nuts for the legs so make sure you loosen amd re-tighten them in the process. Let me know how you make out. The most difficult part will likely be the removal and replacement of the toe panel/kickplate. Good luck, Macmarkus :)
Aug 02, 2010 | Asko D1706 Built-in Dishwasher
My door doesn't seal/catch when closing. Machine
If the door switchmechanism is still in place inside the door, you should be able to see it when you open the door ,it is visible on the inside if the door top centre if it is intact then it could be that the actuator bracket has moved, this is located under the top panel front centre and is held in position by an hexagonal nut. the top is secured at the back of the machine by 2 screws one on the left and one on the right remove the two screws slide the top to the rear approx 1/2 inch lift off the top you can now access the door catch bracket, close the door and adjust the bracket forward so that it latches securely but don't position it to far forward or it could bottom on the back of the door mechanism, if everthing is in place unit should be fixed, reposition top onto the two front lugs and slide top gently forward replace the two screwws at the back and you should be in business
Apr 29, 2010 | Hotpoint 24 in. FDW60 Free-standing...
Dec 25, 2009 | Asko 1385 Dishwasher
LG modelLD-1403W dishwasher. The bottom spray arm
The wheels on the bottom rack could be broken or collapsing..or the rack is distorted or bent..or the spray arm is not attached correctly or is damaged.
Nov 08, 2009 | Asko 24 in. D3530FI Built-in Dishwasher
Top Rack always slides out fully
Well, you are right on about the level. It is tilted just slightly forward. The only parts to go bad are the plastic ball bearing guides, and usually when they go, you get a rack that wont come out and gets jammed. You 've got the problem, you just need to remove the screws hidden in the holes that are sometimes coverd with rubber plugs so that the dishwasher may move freely, andjust it till it no longer rolls out, then screw it back to the counter to hold it in place. There are no springs in that rack, so either its still tilted forward, or the tank is bowed or bent somehow, and that would mean new dishwasher. Hope this helps!
Jun 19, 2007 | Asko 24 in. 1585 Built-in Dishwasher
Upper rack travel sticks and jams.....
you have a bad bearing retainer. you will need to call an asko parts dealer and order 8 upper rack ball bearings, and two ball bearing guides (they are grey plastic and break over time, causing the rack to jam. To replace tham, you must take the upper rack out by turning the plastic retainers on the front of both rails 90 degrees towards the outside of the machine. The slide the whole basket out. Now look at the back of the rails inside the dishwasher. there shoul be 2 more grey plastic retainers with bumpers on them in the rear. These must be pried out wiht a screwdriver (be careful, have cut myself several times on this job till i figured out the best way to do it. cover the bottom hole in the dishwasher with a rag, as you are likely to drop the old bearings when you slide the rails out. Slide out both the rails. Put your new (or old if youve got all 8) ball bearings into the ball bearing holders, then put the holders into the rail thats attached to the dishwasher. slide the rails back in, andthen put all your retainers back in and your rack. you may have to slide the rack in and out a few times before it will center the bearings and work smoothly. Should cost you about $12 in parts. Good Luck!
Apr 17, 2007 | Asko D1716 Built-in Dishwasher
Asko 1385 Dishwasher Logo
111 people viewed this question
Top Asko Dishwashers Experts
John Tripp
John Tripp
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
