Question about KitchenAid Refrigerators
No water does not fill to make ice - KitchenAid Refrigerators
  • 52 Answers
Please check the connection between the faucet and fridge, may have been inproperly connected. Also, check the power switch on the ice maker.
Posted on Feb 06, 2010
I have a kenmore coldspot model 51559101. The water dispenser is working and I can hear the motor for the ice maker but no ice....
Ice maker stopped making ice. For this problem you have check few things. First thing, is the water filling in the ice maker chamber and then ice maker not making ice? Or, the water is not filling in the ice maker chamber so it's not making ice. If the water is not filling in the ice maker chamber then it's clear that ice is not getting made due to no water in the chamber. For no water filling, the problem is either water supply valve turned off so water is not filling. Turn on the water supply and it will fill. But if the water supply is turned on then the other possibility is ice blockage in the water fill tube. There is a tube from which the water runs and enters the ice maker chamber. If this tube is blocked then water will not enter the chamber. The tube needs to be defrosted, by using hair dryer. This procedure melts the ice collected in the tube and water starts running again. But if water fill tube is completely clear and no ice blockage or any other blockage. Then other possibility is water valve. This water valve is for letting the water in the ice maker. The water valve open only for 7 seconds and in this time the water fills in the ice maker chamber and then water valve closes and the same procedure runs again in the next water filling cycle.------- The main valve on the back of the fridge section. This main valve lets the water enter the refrigerator .In most of the cases the fault is water valve . ------------- The other above possibilities which I gave you is water not filling in ice-maker chamber so it's not making ice. But now consider that water is filling in ice maker chamber but it's still not making ice. Then the problem is ice maker unit itself. This unit is controlled by main board. But in most cases if water is filling the ice maker but it's not making ice then its faulty ice maker unit. So see if the problem is water not entering the ice maker then the water fill tube is frosted by ice or the water valve is faulty. Replace the valve. ------------
You can get required parts from sears part direct online site or from repairclinic.com site.
This will help. Thanks. Helpmech.
Jul 08, 2011 | Refrigerators
Smeg FA561X ice maker not making any ice. Water dispenser is fine and rest of fridge/freezer fine, just no ice in the ice storage part
ice maker stopped making ice. For this problem you have check few things. First thing, is the water filling in the ice maker chamber and then ice maker not making ice? Or, the water is not filling in the ice maker chamber so it's not making ice. If the water is not filling in the ice maker chamber then it's clear that ice is not getting made due to no water in the chamber. For no water filling, the problem is either water supply valve turned off so water is not filling. Turn on the water supply and it will fill. But if the water supply is turned on then the other possibility is ice blockage in the water fill tube. There is a tube from which the water runs and enters the ice maker chamber. If this tube is blocked then water will not enter the chamber. The tube needs to be defrosted, by using hair dryer. This procedure melts the ice collected in the tube and water starts running again. But if water fill tube is completely clear and no ice blockage or any other blockage. Then other possibility is water valve at the back of ice maker unit. This water valve is for letting the water in the ice maker. The water valve open only for 7 seconds and in this time the water fills in the ice maker chamber and then water valve closes and the same procedure runs again in the next water filling cycle.------- In most of the cases the fault is water valve at the back of ice maker section, on some refrigerators the valve is at the lower section. ------------- The above possibilities which I gave you is water not filling in ice-maker chamber so it's not making ice. But now consider that water is filling in ice maker chamber but it's still not making ice. Then the problem is ice maker unit itself. This unit is controlled by main board. But in most cases if water is filling the ice maker but it's not making ice then its faulty ice maker unit. So see if the problem is water not entering the ice maker then the water fill tube is frosted by ice or the water valve at the back of ice maker is faulty. Replace the valve. ------------
Jun 29, 2011 | Smeg FA561X Side by Side Refrigerator
My icemaker is not making ice. The water dispenser is working. Settings are fine, no ice at all in ice compartment. Filter light is not on. Ice maker button is in on position
Ice maker stopped making ice. For this problem you have check few things. First thing, is the water filling in the ice maker chamber and then ice maker not making ice? Or, the water is not filling in the ice maker chamber so it's not making ice. If the water is not filling in the ice maker chamber then it's clear that ice is not getting made due to no water in the chamber. For no water filling, the problem is either water supply valve turned off so water is not filling. Turn on the water supply and it will fill. But if the water supply is turned on then the other possibility is ice blockage in the water fill tube. There is a tube from which the water runs and enters the ice maker chamber. If this tube is blocked then water will not enter the chamber. The tube needs to be defrosted, by using hair dryer. This procedure melts the ice collected in the tube and water starts running again. But if water fill tube is completely clear and no ice blockage or any other blockage. Then other possibility is water valve at the back of ice maker unit. This water valve is for letting the water in the ice maker. The water valve open only for 7 seconds and in this time the water fills in the ice maker chamber and then water valve closes and the same procedure runs again in the next water filling cycle.------- In most of the cases the fault is water valve at the back of ice maker section, on some refrigerators the valve is at the lower section. ------------- The above possibilities which I gave you is water not filling in ice-maker chamber so it's not making ice. But now consider that water is filling in ice maker chamber but it's still not making ice. Then the problem is ice maker unit itself. This unit is controlled by main board. But in most cases if water is filling the ice maker but it's not making ice then its faulty ice maker unit. So see if the problem is water not entering the ice maker then the water fill tube is frosted by ice or the water valve at the back of ice maker is faulty. Replace the valve. ------------
May 16, 2011 | Kenmore Refrigerators
My ice dispenser dispenses water but is not making ice.
Ice maker stopped making ice. For this problem you have check few things. First thing, is the water filling in the ice maker chamber and then ice maker not making ice? Or, the water is not filling in the ice maker chamber so it's not making ice. If the water is not filling in the ice maker chamber then it's clear that ice is not getting made due to no water in the chamber. For no water filling, the problem is either water supply valve turned off so water is not filling. Turn on the water supply and it will fill. But if the water supply is turned on then the other possibility is ice blockage in the water fill tube. There is a tube from which the water runs and enters the ice maker chamber. If this tube is blocked then water will not enter the chamber. The tube needs to be defrosted, by using hair dryer. This procedure melts the ice collected in the tube and water starts running again. But if water fill tube is completely clear and no ice blockage or any other blockage. Then other possibility is water valve at the back of ice maker unit. This water valve is for letting the water in the ice maker. The water valve open only for 7 seconds and in this time the water fills in the ice maker chamber and then water valve closes and the same procedure runs again in the next water filling cycle.------- For your information I will mention that there are two valves. One is the main valve the back of the fridge section. This main valve lets the water enter the refrigerator and other valve is at the back of ice-maker section. This other valve lets the water to enter the ice maker. In most of the cases the fault is water valve at the back of ice maker section. ------------- The other above possibilities which I gave you is water not filling in ice-maker chamber so it's not making ice. But now consider that water is filling in ice maker chamber but it's still not making ice. Then the problem is ice maker unit itself. This unit is controlled by main board. But in most cases if water is filling the ice maker but it's not making ice then its faulty ice maker unit. So see if the problem is water not entering the ice maker then the water fill tube is frosted by ice or the water valve at the back of ice maker is faulty. Replace the valve. ------------
May 03, 2011 | LG LRSC26920TT Side by Side Refrigerator
The ice maker is no longer filling with water
Apr 29, 2011 | KitchenAid (KSRD22FKST) Side by Side...
I have a side by side refrigerator and ice maker will not produce ice anymore
Apr 27, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice maker not producing any ice cubs
Apr 26, 2011 | Fisher and Paykel Active Smart® E522BR...
The water is not coming any more into the ice maker unit, water is available at water dispenser. The filter has been replaced and system purged. The ice maker continues to cycle, but after it cycles...
It can be issue with water fill valve.
Ice maker stopped making ice or filling with water . For this problem you have check few things. First thing, is the water filling in the ice maker chamber and then ice maker not making ice? Or, the water is not filling in the ice maker chamber so it's not making ice. If the water is not filling in the ice maker chamber then it's clear that ice is not getting made due to no water in the chamber. For no water filling, the problem is either water supply valve turned off so water is not filling. Turn on the water supply and it will fill. But if the water supply is turned on then the other possibility is ice blockage in the water fill tube. There is a tube from which the water runs and enters the ice maker chamber. If this tube is blocked then water will not enter the chamber. The tube needs to be defrosted, by using hair dryer. This procedure melts the ice collected in the tube and water starts running again. But if water fill tube is completely clear and no ice blockage or any other blockage. Then other possibility is water valve at the back of ice maker unit. This water valve is for letting the water in the ice maker. The water valve open only for 7 seconds and in this time the water fills in the ice maker chamber and then water valve closes and the same procedure runs again in the next water filling cycle.------- For your information I will mention that there are two valves. One is the main valve the back of the fridge section. This main valve lets the water enter the refrigerator and other valve is at the back of ice-maker section. This other valve lets the water to enter the ice maker. In most of the cases the fault is water valve at the back of ice maker section. ------------- The other above possibilities which I gave you is water not filling in ice-maker chamber so it's not making ice. But now consider that water is filling in ice maker chamber but it's still not making ice. Then the problem is ice maker unit itself. This unit is controlled by main board. But in most cases if water is filling the ice maker but it's not making ice then its faulty ice maker unit. So see if the problem is water not entering the ice maker then the water fill tube is frosted by ice or the water valve at the back of ice maker is faulty. Replace the valve. ------------
Apr 26, 2011 | Refrigerators
Ice tray won"t fill with
Apr 26, 2011 | GALAXY Microsystems 25.4 cu. ft....
Ice maker stopped making ice. Water line is hooked up and working. Just won't eject ice
Ice maker stopped making ice. For this problem you have check few things. First thing, is the water filling in the ice maker chamber and then ice maker not making ice? Or, the water is not filling in the ice maker chamber so it's not making ice. If the water is not filling in the ice maker chamber then it's clear that ice is not getting made due to no water in the chamber. For no water filling, the problem is either water supply valve turned off so water is not filling. Turn on the water supply and it will fill. But if the water supply is turned on then the other possibility is ice blockage in the water fill tube. There is a tube from which the water runs and enters the ice maker chamber. If this tube is blocked then water will not enter the chamber. The tube needs to be defrosted, by using hair dryer. This procedure melts the ice collected in the tube and water starts running again. But if water fill tube is completely clear and no ice blockage or any other blockage. Then other possibility is water valve at the back of ice maker unit. This water valve is for letting the water in the ice maker. The water valve open only for 7 seconds and in this time the water fills in the ice maker chamber and then water valve closes and the same procedure runs again in the next water filling cycle.------- For your information I will mention that there are two valves. One is the main valve the back of the fridge section. This main valve lets the water enter the refrigerator and other valve is at the back of ice-maker section. This other valve lets the water to enter the ice maker. In most of the cases the fault is water valve at the back of ice maker section. ------------- The other above possibilities which I gave you is water not filling in ice-maker chamber so it's not making ice. But now consider that water is filling in ice maker chamber but it's still not making ice. Then the problem is ice maker unit itself. This unit is controlled by main board. But in most cases if water is filling the ice maker but it's not making ice then its faulty ice maker unit. So see if the problem is water not entering the ice maker then the water fill tube is frosted by ice or the water valve at the back of ice maker is faulty. Replace the valve. ------------But if ice is getting made in the ice tray,but the ice is not ejecting out then there is blockage to the ice ejecting blade.May be some ice is got stuck below inside.Clear all ice frost collected under the ice chamber.And then see.---------------
Feb 21, 2011 | GE Refrigerators
Refrigerators Logo
32 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
geob91
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
