Question about JVC AM FM CD DET FACE CAR STEREO
Installed CD Player. Accepts CDs but won't turn on. HELP!!
I've connected all the wires. checked the connections three times. It beeps when I plug it in and it accepts cds. What can I do?
  • 909 Answers
Have you connected the red wire to battery and the yellow to the ignition live? so that it won't get power unless the ignition is on.
To test the unit is o.k. connect the yellow and red to the battery and if it works the connection for the yellow wire is wrong and you need to find the ignition live, careful though as there will be one that is live only when you crank the starter and give a high amperage output, also check the fuses are o.k. as the one on the yellow wire is a low amp , 1amp to 3 amp depending on the model.
Posted on Feb 02, 2010
Radio will not go off
Hi Steve, I'm glad to help! I'm assuming you installed the CD Player and now it stays on. Most CD Players have 2 power wires, sometimes only 1. If your only has one then you have your power wire connected to a wire on the vehicle that stays hot with the key in the off position. Here's what you do to find the wire you need. Take a test light and place it on a fuse in the fuse block, then turn the key off and if the test light turns off thats where you want to connect the power wire for the CD Player. Then when you turn the key off the CD Player will go off also. Hope this helps and have an awesome day Steve.
Mar 09, 2014 | 2005 Dodge Magnum
Cd player dosen't play with amp
hmmm...what cd player are you using?..
May 03, 2008 | Kenwood KDC-MP828 CD Player
Radio won't play
There may be differences between the color coding of the adapter wires and the color coding of the vehicle. Check to determine whether the wires were functionally matched, not just matched by color. Check for missing or poor connections
May 07, 2013 | Dual Electronics XD1222 Car USB Player
How to clean a lens reader?- The message keeps saying wrong disk ?
Sir to clean the optical lens remove the cover of your unit but be sure to unplug the unit from ac outlet, you will see the dvd rack assembly it has a top cover if you remove the top cover you will see the optical lens, use a cotton buds to wipe the optical lens but very gentle when wiping the optical lens because it has a very small wire it may be damage and be sure not to touch the optical lens, hope this help good day and best regards.
Sep 21, 2011 | Televison & Video
Installed Pioneer DEH-1200MP, won't turn on.
sounds like yours acc (red wire) is not connected
Aug 23, 2011 | Pioneer Deh-1200mp Car CD/ MP3 Player
When I turn the system on the CD Drawer keeps going in and out repeatedly by itself. When I load a CD it won't recognize it and won't play it and keeps going in and out opening and closing by...
Hello
Check all connections, such as from player to amplifier or receiver and receiver to speaker. Check and clean contacts on RCA jacks and cables and try a different input on the amplifier or receiver.
Clean the lens. Use only a special CD lens cleaner and follow the instructions carefully.
Check the traverse assembly (the metal rod that the laser travels along and the gear that drives it) if CDs aren't recognized or won't play, frequent skipping occurs at random, CDs randomly get stuck in one spot, the player can't find tracks correctly, or cleaning the lens doesn't work. Dust and lint may be interrupting its function.
Have the laser-head assembly checked by a repair person if the traverse assembly seems intact and free of debris.Look for broken plastic parts, such as gears and clips,look for loose or broken internal connections.possibly have gears and belts replaced.
Jun 09, 2011 | Audio Players & Recorders
Sony CDX-L410X Power Going To Unit But Won't Turn On
make sure you are getting power the the red (ignition ) wire.
Mar 03, 2010 | Sony CDX-L410X CD Player
Wiring of a Panasonic CQ-C1001N Car CD Player into a Morris 1000
You can get wiring diagrams on line, do a search using the players full name. Is your morris positive on negative earth? you will have to swap it if it is positive as the player is negative earth only (usually dynamo is +ve and alternators are-ve ) I have changed lots over when dynamos were common, turn the battery round and pull the 2 wires off the dynamo take a wire from the +ve battery terminal  and "wipe it across the 2 terminals on the dynamo, this will make it -ve earth too, re connect the dynamo and off you go
Mar 17, 2009 | Panasonic CQ-C1103U CD Player
Mp2035 cd player will not turn on.
My hunch is that the fuses blew. When you cut all three at once you shorted the battery to ground and most likely blew out the fuses. Check the fuses and let me know. That is my best guess. Good luck
-Andrew Hawkins
Jun 10, 2008 | Kenwood KDC-MP2035 CD Player
JVC AM FM CD DET FACE CAR STEREO Logo
132 people viewed this question
Top JVC Car Audio & Video Experts
Radames Pagan
Radames Pagan
xxxxxx xxx
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
