Question about Apple 15" PowerBook G4 Aluminum 1.67 GHz LCD Display (p/n 1002587) (661-3749 1002587) Mac Notebook
My screen is on but just have a small camera in the middle of the screen blinking.. G4 power book can you help?
    Guru:
  • 206 Answers
I seen a blinking folder with a question mark in the middle in folder, in the middle of a display screen, but not a camera.
Either way, you are not able to access your main desktop so that is where I want to help.
A blinking folder with a ? in middle, is an indication that your bootable Mac OS X volume cannot be found.
If you do, I would first recommend you try this procedure first:
(PRAM Reset)
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} • First, hold in your power button for approximately 10 seconds to do a hard shutdown, if you have not already turned your Mac off.
• Once your Mac is shutdown, you will need to perform what is called a PRAM reset (Parameter RAM)
• Locate the following keys on the keyboard: Command, Option, P, and R. You will need to hold these keys down simultaneously .
• Turn on the computer.
• Press and hold the Command-Option-P-R keys. You must press this key combination before the gray screen appears.
• Now, hold the keys down until the computer restarts and you hear the start up sound for the third time.
• Release the keys and allow the Powerbook G4 to start up.
If this still returns you to a blinking ? folder, try this process:
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} DISK UTILITYYou can use your Mac OS X install disc to repair your hard drive and Mac OS X volume using Disk Utility. Click the link below to try this procedure.
* Apple Support Link:
Use Disk Utility to Repair Disk
Should neither of these processes work and you still boot up to a flashing ? folder, then your only recourse is to use your Mac OS X installation disc and perform an Archive and Install procedure.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} This procedure also allows you to save your applications, files and folders without the old directory interferring with you then accessing those files and creating a new Mac OS X Directory.
Here is the Apple Support Link for that procedure:
Archive and Install
This should get your Powerbook G4 back to normally functionality without any serious data loss.
Regards,
-Mactechtrainer
Posted on Feb 03, 2010
Laptop apple power book g4 boot up problem
What happens when you try to boot up the PBG4? Does it show the Apple logo on the screen? Are there any sounds or blinking LED status lights?
Dec 04, 2013 | Computers & Internet
I was using my I Book G4 when it stopped responding. I powered down and restarted. When it began restarting it went to a gray screen with a file folder in the middle of the screen. the file folder had a...
Hi ,
take out the battery for 5 minutes , this resets the computer , , if this does'nt work , put in a bootable disk and try to recover the system ...........let me know if this works , i can advise futher
Goodluck Roy
Aug 27, 2011 | Apple PowerBook G4 Mac Notebook
Powerbook g4 no brightness have yo use flash light
Okay. Try this
http://support.apple.com/kb/TA25861?viewlocale=en_US
If it does not help then it is possible that the Back light on the screen is faulty. If you just purchased the computer, then you should go back to the vendor and ask him to change or fix it .
Oct 25, 2010 | Apple Power book G4 Refurbished Notebook -...
My g4 power book screen is very dark
This is door to a poor backlight meaning the backlight needs to be changed out. Going to cost like $125 for the part if you do not know how to do it then a tech will need to get involved so tack on your labor. I hope this helps as it did dozens of people with the same issue. please do leave ratings and feedback for your free answer today.
Apr 27, 2010 | Apple 15" PowerBook G4 Aluminum 1.67 GHz...
My Power mac G4 Quicksilver has problems. When i boot it up the chime comes on, and i see the boot up screen. Although in the middle of the screen there is a folder that is blinking a ? mark sign. I tried...
The folder with the blinking question mark means that your Mac cannot find a bootable system on the internal drive. This usually means either that the drive has been corrupted or is not accessible. The proper repair procedure is to boot from the system installation CD and use the Utility menu to run Disk Utility / Repair Disk on the internal drive. But at this point, I'd have to ask you to elaborate on your claim that you "messed up your Super Drive" before I can figure out how to proceed from where you are.
Sep 26, 2009 | Apple Power Mac G5 Desktop
I turn on my mac and only this small folder icon appears in the middle of the screen
The face is probably frowning.  The computer cannot find the operating system.  Use a utility disk to boot up the computer and then use First Aid or Disk Utility to check the disk.  You may have to re-install the operating system.  This can be done without losing your files if done correctly.  Seek help from an Apple repair facility if you are in doubt about how to do it.
May 20, 2009 | Apple iBook G4 (Z0AZW13397068) PC Notebook
Power Book G4 reinstall using Power Book G5 OS X10.4.6
Apple have software locks to stop you using the bundled disc in the "wrong" machine, get a copy of 10.4 (try eBay, ) and you should be OK
Apr 13, 2009 | Apple Titanium G4 and 8413i Book series AC...
Powerbook g4 going to white screen only!!
Do you have any external harddrive attached to it? If so, remove it before restarting. Try to start it up in safe mode by holding the Shift button down at startup: http://support.apple.com/kb/HT1455
Mar 24, 2009 | Apple PowerBook G4 Mac Notebook
Panasonic pv-gs150 mac connection
For Macintosh
OS:
Mac OS X v 10.1–X v 10.3
CPU:
iMac, iBook or Power Book G4, Power Mac G4 or
Power Mac G5
RAM:
64 MB or more
≥The USB equipment operates with the driver
installed as standard in OS.
Sep 30, 2007 | Panasonic PV-GS150 Mini DV Digital...
Mac book stoped working
Try these in no particular order (except last 3) try command-option power this puts p-books to sleep (may trigger it to wake) (it could be asleep) Remove your battery and wait 5-10 mins then try to start up with battery in Remove your battery and wait 5-10 mins then try to start up with battery removed To zap PRAM On startup hold down the cmd, option, p and r buttons Hold till you hear boot up sound To zap NV RAM On startup hold down the cmd, option, n and v buttons Hold till you hear boot up sound To reset Power Manager On startup hold down the shift, fn, ctrl and power buttons Hold till you hear boot up sound To reset the screen on a powerbook: On startup hold down the r button - To force internal Hard drive to be startup disk On startup hold down the r button - until boot Disable extensions: Try power up-reboot with shift key down Last but not least try to startup with original MAC system startup CD If all else fails try to get to an Apple Store...unless it's a real hardware problem (fried circuits/damage they'll fix it for free!) Pray - believe it or not... it worked for me when I got down on my knees and prayed. Hope this helps also from Fixya By  horthette Rank: Master Rating: 74%, 10 votes Apple is advising all owners of MacBooks or MacBook Pros bought after February 2006 to download a software update that will help fix some battery issues. The update, available through Software Update in the Apple menu or here on Apple's site, was released to correct some battery performance problems, such as shorter than usual battery life or problems charging the battery, according to a Web page on the support section of Apple's site. But if that fix doesn't work, notebook users should contact Apple to have their battery replaced if they notice the following symptoms, cut and pasted from Apple's support document: * Battery is not recognized causing an "X" to appear in the battery icon in the Finder menu bar. * Battery will not charge when computer is plugged into AC power. * Battery exhibits low charge capacity/runtime when using a fully charged battery with a battery cycle count (as shown in System Profiler) of less than 300. * Battery pack is visibly deformed. Apple says these problems aren't safety issues, just performance-related, a relief for those who remember the massive battery recall of last summer. Apple had to recall 1.8 million batteries manufactured by Sony as part of a larger recall that affected just about everyone in the PC industry.
Jun 03, 2007 | Apple 15" PowerBook G4 Aluminum 1.67 GHz...
Apple 15" PowerBook G4 Aluminum 1.67 GHz LCD Display (p/n 1002587) (661-3749 1002587) Mac Notebook Logo
135 people viewed this question
Top Apple Computers & Internet Experts
paulcarew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
