Problem for Washing Machines
Generic problem for all Washing Machines
Greesey Spots.........
My washing machine has suddenly started leaving, what looks like greesy spots, all over the washing. The spots are that of the little holes around the drum. I have tried doing a high temperature wash on its own with a touch of detergent to see if that would clean it up, but to no avail!!
Please help!!!! My baby daughters pretty clothes are getting ruined.
Thanks
Comments:
Feb 20, 2008
- Thank you. Is it/would it be difficult to remove the drum? If it is the shaft that is creating the problem would this need to be replaced, cleaned, fixed? and would this be an a job we could do?
Thank you again for any help you can provide.
Best Solution
posted on Feb 19, 2008
Rank: Guru
Expert
Rating: 88%, 711 votes
looks like the grease would be coming from the shaft at the middle of the tub. that would be the only source of grease in that area.you need to remove the whole drum to look at it.
Comments:
Feb 20, 2008
- yes it is a difficult job to remove the drum, the shaft could either be repaired or parts can be replaced. and i dont think you can do it yourself.
Popular Solutions for Washing Machines
Maytag Neptune MAH5500B Front Load Washer
1 Solution
Whirlpool Duet GHW9150P Front Load Washer
1 Solution
Whirlpool Cabrio WTW6600SBT Top Load Washer
2 Solutions
Questions and Unsolved Problems for Washing Machines
what washer and dryer to buy
Posted. Thank You!
I'm looking at the Whirlpool WTW6300 or Fisher & Paykel WL26CWI Washers. Which should I buy...
Posted. Thank You!
I have the wfmc 3200uc/01/fd 8502 model.Purchased in June 05. Water is turned on; press start, the...
(More)
(More)
I have the wfmc 3200uc/01/fd 8502 model.Purchased in June 05. Water is turned on; press start, the machine fills with water and begin a slow rotation left then right (as per usual) but stays in this mode, will not wash. no error code.
Posted. Thank You!
Congrats on your 3 solution. You're helping others! Someone may even thank you with a Testimonial.
Maytag washing machine (modelA606) After the load completes its cycle, it starts washing the load...
(More)
(More)
Maytag washing machine (modelA606) After the load completes its cycle, it starts washing the load again without me resetting it. It just keeps going and going.
Posted. Thank You!
kenmore 12502100 washer won't complete rinse cycle. fills with water agitates then stops. hear a...
(More)
(More)
kenmore 12502100 washer won't complete rinse cycle. fills with water agitates then stops. hear a humming or buzzing the stops completly
Posted. Thank You!
