Its pretty easy to see how the screws come out to remove the door 'off' the dryer, but the problem im having is how to actually get the little door latch off the door itself, to move it on the other side...there seems like there are 2 little 'pins' that seem to be logged in the door (by design), but it looks like they should 'pop' out with relative ease, but thats not the case..i've tried tapping them gently with a rubber mallet but to no avail.
SOURCE: Kitchen Aid Classic mixer
http://www.kitchenaid.com/custserv/faq.jsp?sectionId=222#troubleshooting
Check this link to the Kitchen Aid website. It answers your question very well.
SOURCE: Handle Replacement on a HKMS155L Microwave
I think you have solved your problem already.
I have seen your requesty only now and I am sending the diagram to replace handle.
You remove door latch (nr 3 on diagram) first, then you unscrew the screw nr .8 and remove handle (nr.7).
Below the diagram:
You can find all parts and diagram for your appliance here.
SOURCE: My dryer will not stop when I open the door, only
If you take a plastic spoon and press on the "Thingy" it should click when you press it and again when you release it
If it does not do that, the micro switch is goosed and needs replacing
SOURCE: Trying to replace the KHMS155LSS3 handle...
To replace the plastic handle on the KitchenAid KHMS155LSS-3 you pry open the door cover from the inside to release the upper tangs (~10). I used razor blades wedged between the tang point to hold them disengaged. Pull the front cover off the door starting from the handle end. Once the top edge is free, the bottom can be remover. See Pitcures.
Repeat the door cover removes with the handle attached from the front after you lift the tangs.
Opening the cabinet for newer Whirlpool brand models
starts at the control panel. Begin by removing the end caps found at
either end of the console. Lift them from the back, and then pull them
towards you. There will be two screws holding the console in place.
Remove the screws, and then slide the console towards you and flip it
up. You will find an additional three screws at the back of the cabinet
top. Remove these and slide the cabinet top towards you and lift it off
the unit.
Proceed by removing the kick-plate. There are two
spring catches that need to be disengaged before you can remove the kick-plate. Each spring catch is found about four inches in from each
side. Use a putty knife or some other thin and flat object to wedge in
between the front panel and the kick-plate. Push down on the clips with
the putty knife to disengage.
Open the dryer door and remove the screws that are
holding the hinges to the door. Tilt the door up and pull on it gently
to remove it. Continue the dismantling process by removing all the
screws you find that are holding the front panel to the unit. There will
be door switch screws, ground wire screws, and other screws holding the
front panel to the bulkhead.
Reassembling the entire unit is basically the disassemble process in reverse. Replace the front panel of your dryer. Replace the dryer door, and then replace the kick-plate. Reattach the cabinet top and then push the control panel back in place and reattach the two end caps.
