Need to reset Classic remote IRC 83088 to Panasonic STB TU-CT41
5 Suggested Answers
chrispurs1
  • 372 Answers
SOURCE: panasonic freeview box TU-CT41 suddenly
Hi
get A new onethey are cheap now.
Posted on Aug 24, 2008
  • 4 Answers
SOURCE: hi i hav a classic
If its the same as for a IRC81600:
1. Hold down the TV/Tuner Button.
2. Whilst holding down the TV/Tuner Button, enter the four character numeric device code.
3. Press any other button on the remote.
Posted on Nov 08, 2010
  • 336 Answers
SOURCE: I require the instruction manual
http://service.us.panasonic.com/OperMan/Default.aspx
That model # did not come up for me. but here is panasonic web site for owners manuals.
Posted on Jan 27, 2011
gopakumarg43
  • 74383 Answers
SOURCE: I have the classic IRC OD DTV1 REMOTE CONTROL, does anybody know what the procedure AND CODE is that I need to operate them please x
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Type in the brand name of your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
Posted on Mar 27, 2015
Connecting rca tv model#F20352SF to a tv converter box
  • Connect ANTENNA OUT of STB to antenna terminal on rear of TV OR, for better picture, connect 3-wire cable to color coded L AUDIO, R AUDIO, and video outputs on rear of STB and connect other ends to L AUDIO, R AUDIO, and video inputs on rear of TV.
  • If STB connected to antenna terminal of TV, set CH 3/4 switch on rear to whichever channel is NOT used in your area.
  • Connect antenna to ANTENNA IN of STB
  • Connect STB to power and use STB remote to turn on
  • Turn on TV
  • If STB connected to antenna terminal of TV, use TV remote to select channel 3 (or 4).
  • Use STB remote to select SETUP and perform channel search.
  • Use STB remote to change channels.
Oct 23, 2016 | RCA Televison & Video
I have a bush le-40GB01-C DTV AND a classic IRC OD DTV1 REMOTE CONTROL, WHAT IS THE CODE I NEED TO WORK THE TV
0281.0288. Check these codes. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common set-up codes to check with TVs and other devices are given, in the order of the "device's brand name" in alphabetical order. Pull up older posts. Surf the site with patience. Surf the sites by type in the brand name to your set, in its search box.
http://electro-medical.blogspot.com/
Mar 26, 2015 | Televison & Video
I had a IRC 550 starchoice remote and it ran my panasonic home theater system but quit working so I purchased a IRC 551 and couldn't get it to run the audio Shaw suggested i try a ir 600 remote and I found...
SEARCHING FOR YOUR CODE=irc 551
If your home entertainment device does not respond to
the Star Choice IRC 551 IR and Star Choice URC 551 IR/
UHF Remote Controls after trying all of the codes listed
for your brand, or if your brand is not listed at all, try
searching for your code.
For example, to search for a code for your TV:
1. Turn on your TV.
7. To search for the codes of your other devices,
repeat steps 1 through 5, but substitute the
appropriate key (e.g., AUX, DVD, AUD, or SAT)
for the device you are searching for.
Jan 29, 2011 | Panasonic Home Theater System System
I have a Panasonic home theater and am looking for a code that will work with either a starchoice IRC 550 or shaw direct ir/rf 600 remote
http://www.shawdirect.ca/images/support/downloads/550_Manual.pdf
This is the manual for the irc 550 ..and in the manual you have the codes for audio (cd ) which I believe to be the ones you need to use..They are on the end of the manual ..But ! If you read the manual carefully you see that it actually can pick-up the codes automatically if you follow certain programing procedure.described in the manual ..
Jan 28, 2011 | Panasonic Home Theater System System
My new amino remote only works on my tv and not on my aminorouter. If a switch from tv to stb I can still use the vol button but the ch. button does not work. I cant change the channels on the amino...
Try re-coding the remote. Hold down STB and OK for a few seconds. Then when the red light is steady on the STB button you put in the code 000. By doing this you have reset the remote control. Also a good trick is to remove the batteries and put them back in. With that you are basically turning the remote off and on again. The good old restart.
Mar 22, 2010 | Philips PM3S Remote Control
Need remote code to control a Panasonic Omnivision VHS PV-M2079 TV/VCR combination
You need to program the VCR (which turns the sey on/off) as an aux, then program any Panasonic TV type for TV, and then set the STB button to control STB, TV and AUX and you should be set.
Jan 03, 2008 | Televison & Video
DTV remote code
KZXten,
Don't know if this will help but I have Comcast as my cable TV provider and am using a Motorola DCT-6200 STB and the remote Comcast provides with the STB. To get my Panasonic TV/VCR combo (PVQ-2510A) to work with the Comcast remote I had to do the following:
1) Do the remote code search in AUX mode (or VCR or DVD mode if your remote has that button instead) using the instructions for searching ing remote codes. I had to toggle back and forth between AUX and POWER on the remote until the TV turned off. I saved that code on the remote, but it only controlled the power on the TV, not the volume control.
2) Next I did the remote code search using the TV button on the remote and toggled between the TV button and the volume control until the volume +/- bar appeared on the screen. I saved that code too.
I use the AUX button to turn the TV on and off. Once the TV is on the volume control on the remote operates the TV volume normally. I still need to toggle between CABLE and AUX depending on which device I'm controlling, the cable Set Top Box (STB) or the TV. You may have to experiment some to get it to work correctly.
Here's a link to the remotes Comcast is providing in my area.
http://www.comcast.com/corporate/customers/customer_support/remotes.html
Dec 23, 2007 | Panasonic PVQ-2510 25 in. Combo
Remote code for PV-M1349
The secret is that the VCR code turns the set on/off and the TV code controlls the volume...try this:
Program the Verizon remote AUX button using the panasonic VCR codes until it turns the set on/off, program the remote for TV using the panasonic TV codes until it controls volume, then program the STB button to control all 3... STB, TV, and AUX. If you are missing any VCR or TV funtions try another respective panasonic code until all functions are available.
Panasonic VCR codes are 1089, 0062, 0189, 0252, 0643, 1062.
Panasonic TV codes are 0277, 0078, 0677, 1437.
To figure this out, I had to use the "what if none of the codes worked" section and figured I'd try the VCR codes since the TV codes would not turn it on/off.
Good Luck!
Nov 25, 2007 | Panasonic PV-M1349 Combo
Televison & Video Logo
82 people viewed this question
Top Televison & Video Experts
Electro Med Services...
