Hello sir i am having 8 GB transcend pen drive some of them did password fom my pen drive i tried to format so many times but it showed as the device is write protected after some time i tried to format using dos after dat i cant enter into my pen drive too can u pls tel me the solution i hav windows 7 os whther my pen drive is still working condt or not in dos windows it showed as we hav encountered some problem so tat this device is unusable pls tell soonly as much as possible
    President:
  • 281 Answers
1. Download this tool:
http://dl.dropbox.com/u/4040651/LLFTOOL.EXE
2. Format
(WARNING: After running this low level format tool,
the whole USB flash disk surface will be fully erased.
Therefore, data restoration will be impossible after using this utility!)
Posted on Feb 02, 2010
4 gb pen drive give write protected error
Save the contents in the pen drive (this process will delete all the files in ur pen drive) and then download this http://www.apacer.com/en/support/downloads/Repair_v2.9.1.8A.zip,unzip it n run.....click "Format". Make sure u have connected only the pen drive u wanna recover to computer,this tool is very blind n it doesnt allow u to choose which removable drive to format..it formats the first removable disk (seems so). Gud luckmoz-screenshot.png
Feb 23, 2010 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
Pendrive Shows Write Protected
These are the tech specifications of your pen drive which includes write protection micro S/D switch. So search it and make it read and write
USB 1.1 compliant and 2.0 compatible,
True Plug and Play for hot swap function
Maximum Transfer speed of 1.5MB (12M bit) per second at full speed
Powered directly via the USB port.
No external power or battery needed.
Operating Systems Supported: No driver required for Windows Me/2000/XP, Mac OS 9.0 or later, or Linux kernel 2.4 or later.Only Windows 98SE needs the provided drive
Write-Protect Function: Write-protect switch Security Function: Password protection available via supplied software (Windows environment only) Boot-Up
Function: Makes JetFlash a MS-DOS Boot Disk LED: Flashing LED indicates
Data Traffic Specifications : Size: 75mm X 11mm X 25mm (L x W x H)
Weight: 15g Data Retention: Up to 10 years Shock Resistance: 1000G (maximum) Erase Cycles: 1,000,000 times Speed: Read 9.0 Mbyte/s, Write 8.0 Mbyte/s (Max.) Certificate: FCC, CE,
BSMI System Requirements: Win 98/98SE/ME/2000/XP, Linux Kernel 2.4 and above, Mac OS 8.6 or later
Aug 12, 2009 | Transcend 32GB ExpressCard SSD, MLC 32 GB...
Can tot open pen drive
you format your pendrive
or
go for nearest transcend service centre
or
your your pendrive is out of order
Jul 31, 2009 | Transcend (589307) Media
Unable to format 64 gb pen drive
Plug your pen drive into a computer that is on. In Windows Explorer, find the pen drive and right click on it and select "Properties". Select the "Tools' tab and then the "Check Now" button in the "Check the volume for errors"Box. Select both oxes and click "Start". Hopefully this will recover all of your drive. If not, the drive has been compromised (toasted). Then you should check with Kingston to get a replacement.
May 28, 2009 | Transcend (589307) Media
I have pen drive Transcend 4 GB which becomes Write protected and can?t be formated.When I plug it on, it shows Removable Disk in my computer and it contained autorun.inf Folder having 2 files which could...
Hello sir,
You can recover by doing the following:
go to transcend website and download this software;
(http://www.transcendusa.com/products/online_recovery.asp) and then you have to select repair and save data..
Regards
Devesh Golani
devgolani@gmail.com
Mar 17, 2009 | Transcend (589307) Media
My Pen drive is 1 Gb Transcend,When i format it show 4 Gb & Error
its probably a virus trying formating on windows 98 or on linux based system may work for u also check when the pen drive isnt connected properly or the usb port or connection is loose it may say a read only pen drive due to slow speed connection of pen drive to computer
Jan 19, 2009 | Transcend (589307) Media
How can i remove write protect from my 4 GB transcend pen drive
Hi Virus or Trojans can run some process that keeps running in background. This not only harms the computer, but also prevents the pen drive from formatting as it shows that the drive is in use. Remove and re-insert the pen drive, don't double click on drive and cancel auto run operations if it starts automatically. Run a virus scan on pen drive, this will help fix the issue. Now format the pen drive.
Jan 16, 2009 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
Transcend 8 GB Pendrive showing write protected
Think this write protection error is due to some virus.
Steps to remove write protection for Transcend users
1) Go to download center of the transcend,here is the link
http://www.transcendusa.com/Support/DLCenter
Type the model no. or part of model number you are looking for.
example: JFV30(all alphabets in Caps )
2) Choose other details like product type etc. and search for your product
3)Then select the product which which is most similar to yours from search results
4)Then download the mFormat utility. You will asked for serial no. if you dont have..enter this no. 1456784523
5) Connect your pen drive
6) run the mformat utility and select full format after full format your write protection will be removed. try twice or thrice if you can't correct at first time.
Thats all...
It worked for me and my friends....
Other pen drive users may visit there vendors site and download any fromat utility present there for your model.
Nov 07, 2008 | Transcend (589307) Media
Pen drive does not open
Your pendrive is affected virus and do the format both pen drives and first cheak with your usb port also once and when you are pushing the pen drive in the pc should be smoth dont press just push some times light is appear but data cabe is not connected to pc
Jun 17, 2008 | Computers & Internet
Transcend pen drive 2GB not getting detected
Sir: Transcend pen drive 2GB not getting detected Can you suggest anything?
Feb 27, 2008 | Transcend (589307) Media
Computers & Internet Logo
384 people viewed this question
David Payne
David Payne
