Question about Xerox WorkCentre XE90FX Laser Printer
I am getting copy service error also H4.can you please HELP!!
  • 4,041 Answers
Hi
try reseting the H code:
· Press CLEAR, EXPOSURE MODE, CLEAR, EXPOSURE MODE.
· The display should go blank.
· Then enter 14 with the copy count keys and press START.
· If the machine does not turn off and back on by itself - then turn it Off and back on.
· See if the H code comes back.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 02, 2010
What does H4 mean on a Sharp Copy machine
H4 means; Heat roller low temperature detection. This is an error in your fuser and you will likely need to get a service technician to take a look at your copier.
Sep 17, 2010 | Sharp AL 1631 Copier
I have a Sharp AR-M207 with an H4-00 error. We have installed a new fuser but still get the error the moment that we turn on the device. I have seen several responses telling which buttons to press to...
heat roller low temperture detection&check the thermistor abnormality,heatlamp abnormality,thermostat abnormality,clean the paerdust guide &use sim 5-02
check the heater lamp blinking operation
use sim 14 to clear the slf diagnostic display
Oct 19, 2009 | Sharp AR-M207 All-In-One Laser Printer
Toner was changed, m/c powered,and instead to ready it was showing ERROR 021
Function 7 press monitor slowly 4 times * 6 scroll down to SHIPMENT SET set 2 wait for the fax machine to reboot
Jun 03, 2009 | Toshiba e-STUDIO 50F Plain Paper Laser Fax
System error H4-00
H4 indicates a heating problem in the fuser. The roller never reached a specific temp. Make sure the fuser is free of any left over paper pieces (maybe from a paper jam). Check to make sure its clean.
Try reseting the the error in service mode.
To enter the test command mode, press the keys as
follows one after the other :
[#] key [*] key [C] key [*] key then enter 14 and press start/copy key. this clear error counter. make sure to restart copier afterwards.
May 19, 2009 | Sharp AR-168S Copier
Blinking red light with system error H4-00. Help!
The H$ is not a generic toshiba copier error. It usually associated with the smaller desktop copiers only. The H4-00 indicates a temperature problem in the fusing unit. It could be one or more of the following items : thermostat or thermistor or heater lamp or the control board.
You could try taking the fuser unit apart and cleaning it. Try resetting the error in service mode. make sure you are in copy mode.
press the "C" key then the "auto/text/photo" key then the "C" key then the "auto/text/photo" key again. enter "14" then "start" - this will reset the fuser error. IF there is something wrong with the fuser the error will come back again.
Then its time to call you local service center.
Mar 16, 2009 | Toshiba Office Equipment & Supplies
Error Call for Service H4-00
# - intrrup key - clear - interrup key 14 print
this all
check fuser lamp, thermost
just
Aug 18, 2008 | Sharp AR-M207 All-In-One Laser Printer
H4 error code
H4 is a Fuser Unit heating problem.
This reset is for another model sharp, see if it will work for you.
Press "Clear", "Auto Exposuer", "Clear", "Auto Exposure", the display will go dead... then press "14" (Like your going to make 14 copies), then press "Start".
Hope this works.
Good luck,
Mac
Feb 10, 2008 | Sharp AL-1551CS Printer
H4 error code
H4 codes are related to the fusing unit. Specifically a low heat condition. Follow the reset procedure below. If that doesn't work further diagnosis of the fusing unit an peripherial circuits may be warranted.
Error code reset:
Perform the following key procedure
"#" key, Interrupt key, "C" key, Interrupt key
"1" key, "4"key
Start key, "CA" key.
See if unit cycles and comes back up. If not turn off and then back on the main power.
If error reappears on site technical service may be required.
Jan 06, 2008 | Sharp AR-5320 Black and White Copier
Cant get rid of blinking error message, nothing works
H4-00 is a fuser related service code. you need to get into the simulation programs and run sim 14 to reset the code. Make sure there is no paper jammed in the fuser. (The hot part on the right side inside the door)
Dec 02, 2007 | Sharp AL-1655CS Copier
The correct buttons to push in order to get into the service mode on a 162D are [#] key, [*] key, [C] key and [*] key. Then you key in 14 - 00 and press the Start key. If that fails to bring your machine back on, you'll have to replace the fusing assembly.
Apr 12, 2007 | Toshiba e-Studio162D Copier
Xerox WorkCentre XE90FX Laser Printer Logo
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
