Question about GE GSH25JSTSS Stainless Steel Side by Side Refrigerator
I have a GE side by side Model # GSH25JSTA and the water dispenser just stopped working. I tried, 1. removing the filter and putting the plug in to see if it was the filter and, 2. depressing the dispenser switch for 2 minutes in case of air in the line. Neither of those solved the problem. Anything else I should try before calling a repair person?
  • annouttx Feb 02, 2010
    I tried the hair dryer but wasn't real sure where to put it. I warmed up the inside of the freezer door right behind the dispenser and the big hump under the crisper on the frige side. I also left the light on the dispenser for about 30 minutes. One of these things worked because I now have water running again.
  • 3 Answers
Mine also quit working. Was working fine when I went to bed and then nothing the next morning. The ice make works fine. I have had this fridge for three years with no issues so it is weird it just decided to quit. I am trying the light and will do the hair dryer next. Please continue to post any solutions as I really do not want to call a technician.
Posted on Feb 21, 2010
I have a GE side by side model #GSH25JSTA SS. It is 4 years old. The Water disenser stopped working about 6 months ago. We have replaced water filter and that did not seem to work. When we press the...
hey Jun, I have the same problem,, especially in the winter.. I just unplug mine for about 20 minutes,,,(DON'T open the frig while doing this!!!) .. seems to get the water flowing for me.....
Jun 14, 2017 | GE GSH25JSTSS Stainless Steel Side by Side...
Water dispenser not working
This could be that your water supply is not good , check to see if you have plenty of water pressure going to the dispencer, this is aproblem sometimes at the valve, also change your filters, and make sure all is clean, this is a good start, if this does not do it will have tocontnue to troubleshoot
Feb 04, 2010 | GE GSH25JFR Side by Side Refrigerator
GE Refig. water does't dispense
adjust tempt of fresh food side it may be to cold and freezing veg/ and water line .. **** ..
Jan 19, 2010 | GE GSH25KGMWW Side by Side Refrigerator
Water Dispenser not working
I removed the water filter overnight and then replaced and reset filter setting over the dispenser. I then waited a little while and then tried the dispenser and water began to flow out normally.
Apr 08, 2009 | GE GSS25LGM Side by Side Refrigerator
I replaced the water filter for my GE GSH25JSTA SS side by side fridge and now the unit is no longer dispensing water
I have had the same problem with the same model several times in the past. It also happens to me within a few days of replacing the water filter.
In my case, I believe the water line in the freezer door has become frozen. I usually let the freezer thaw for a couple of hours, and my water works again.
I have had constant problems with this model. I would recommend trying to sell your fridge now while it's still running, before the real headaches begin (mine has died 2x in the past six months, and I have not even had it for 2.5 years yet). No more GE's in my house.
Mar 22, 2009 | GE Refrigerators
GE GSS25SGRE side by side water dispenser...
The same thing happened to me. If you pull the refrigerator out and remove the large silver panel, you will see the water lines on the left. The line going to the ice maker was fine, but the line going to the water dispenser was split. You may have the same issue.
Jan 30, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
No water flow
turn the freezer side to zero fridge side will zero also . click for water it should work . just worked for me no water for 1month replaced the filter and everything.
Dec 06, 2008 | GE GSH25JSRSS Stainless Steel Side by Side...
The water dispenser in my frig stopped working but it still makes lots of ice. I replaced the filter on 29 Dec 2007. I normally get 6 months out of a filter.
We had same problem! The water line gets frozen in the door, and there is no way to get to it. But, I took some 14 gauge electrical wire and would get one end hot by putting it under hot water, then put that end up the water line in the door. This might take several attempts, but it will work. A little piece of ice about 2 inches long will come out.
Mar 05, 2008 | GE CleanSteel GSL25JFTBS
Water/Ice Dispenser is not working
at the very least replace that water filter.clogged water filter will reduce water pressure to the line.
Feb 24, 2008 | GE Profile PSW26P Stainless Steel Side by...
GE GSH25JSTSS Stainless Steel Side by Side Refrigerator Logo
429 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
richie46
