Question about Panasonic CT-27G11 27" TV
Panasonic CT-27SX12AF 27" TV The front panel controls/switches functions normally, but tv will not operate by remote (e.g. no power on/off, or channel/volume adjustments). However, if unplugged it from wall, press front panel "power button", and cool(5 mins.) Then all remote control functions would be restored for approx. 5 mins. before this problem repeats. Is it a bad I.C. ? If so, which one? Appreciate any assistance from your experts. WW.
  • wwing106 Feb 03, 2010
    ABRSVCS, I was surprised by your prompt reply from fixya.com. As an update, when i rotated this heavy tv around to remove rear cover. I found and removed cardboard/papers beneath it. Blocking up to 85% of the cooling vents (heat issue). Then examined underneath the IR receiver's circuit board for any cold solder joints (i.e. brittleness) and found none. Re-soldered all three IR connections for good measure. Tested the set with these fixes, but problem returned. Powered off (unplugged), placed my meter (continuity setting) leads acrossed two of the IR leads at a time and found one side with an opened reading on the forward/reverse (flip test leads) bias test. Replaced the IR receiver with a scrapped one off my junked VCR. The remote works fine !!! Now, i no longer need to manually change channels, etc. for my disabled brother if that not enough work. Thanks for your efforts anyway. WW.
  • 4,234 Answers
This sounds more like the connections at the IR receiver being bad. This module is located near the front of the set. While this is not the area of a large amount of heat, the area does heat up a bit. It is repeated heat/cold that will cause the solder to become a little brittle. It looks like the heat generated by the set running will end up breaking the connection. This is a simple fix that requires the removal of the PC board from the set. Without prior experience working inside TVs, I would not suggest you attempt this repair. This should be a labor only repair for any TV shop and should not take long to repair.
Dan
Posted on Feb 02, 2010
  • ABRsvcs Feb 03, 2010
    While rare, it is possible that heat can damage the IR sensor. The most common cause is poor conenctions. I'm glad you have resolved the problem.
    Dan
My panasonic crt tv stuck on standby mode only
Hi. Replace the batteries in you remote control already ?
Normally, every TV can be switched on using the local "channel up/dwn " buttons. If this does not work, then there is a more serious problem at hand.
Apr 09, 2014 | Panasonic CT-27SC14 27" TV
Universal remote code for a panasonic ct-27g14a
Two things you can do:
GOOGLE THE NUMBER OR MODEL OF THE REMOTE AND LOOK FOR THE INSTRUCTIONS FOR PROGRAMMING IT.
GOOGLE THE MODEL NUMBER ON THE REAR OF THE TV WITH THE WORD REMOTE AFTER IT FOR A DIRECT REPLACEMENT.
LET ME KNOW IF YOU NEED HELP
Mar 15, 2012 | Panasonic CT-27G14 27" TV
Need the remote code for this model tv
Hello
Three digit universal remote code for Panasonic are:-
003/ 054/ 055/ 062/ 070/ 148/ 149/ 170/ 171
Four digit universal remote code for Panasonic are:-
0171 0148 0054 0170 0062 0374 0381 0437 0950 0003 0070
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Note: Switch OFF and switch ON your TV with its front panel power control switch [Main power control] each time before proceeding for an other code.
OK.
Jan 20, 2011 | Panasonic PV-DM2799 27 in. TV/VCR/DVD...
I have a problem with my Panasonic CT-27SX12 27"
On remote you must push the TV button first then the on button to activate or deactivate the TV. Channel or volume on the TV does not need to select anything on remotes.
Nov 18, 2010 | Panasonic CT-27SX12 27" TV
It appears that the image on the screen is zoomed in, but I can't figure out how to "undo" that. Thank you!
If the image on screen is zoomed both in vertical and horizontal direction, your TVs power regulator inside it is faulty. [Overvoltage]. If it is zoomed in vertical direction only, that is only the height of the picture is zoomed, you can adjust it with the remote control button directly on going through menu and get in to the function menu. Normally all TV remote has a special button marked as "Zoom" which on pressing it once the picture get zoomed, again another press the picture gets wide and again an another press picture will come to normal mode. You should select normal mode to retify the problem.
Oct 16, 2010 | Panasonic CT-27SL14 27" TV
Remote sensor on Panasonic CT-27G14 not functioning. How can I fix it?
firt try with your cellular, put your cellular in camera and put your remote control in front of your cellular and press one botton, if you see a blincking ligth, your control is good and your IR sensor in the tv is bad.
Apr 25, 2010 | Panasonic CT-27G14 27" TV
The television CT-27G5 is not recognizing the IR from the remote. I have tested the remote and it is outputing a signal. Is there a reset procedure for the television and remote to put them back in sync?
No reset for that. Most likely the remote sensor inside the tv has gone bad. It is at the front of the main PCB beside the front panel buttons. check www.encompassparts.com for availability. Thanks for using fixya.
Feb 20, 2010 | Panasonic CT-27G5 27" TV
Not receiving commands from the remote. (Panasonic Panasonic CT-34WX54 HDTV)
Your using a universal remote from what U am understanding, Two solutions for ya
1)diffrent remote all togeather from radioshack
or
2) the Tv's IR is not working
Apr 22, 2009 | Panasonic CT-27SL14 27" TV
Vchip was accidentaly set by guest and password was forgotten
For Panasonic:
Parental Lock Feature
Combo's, Screen will say VCR Lock Activated.
During stop or power off, hold the stop/eject button on the unit for at least seven seconds.
Combo's, Another method
With unit on and no cassette inside, hold the rec/time button on the front of unit for 7 seconds.
CTV's Lock Mode
Only the on/off button will work,the others have no effect. Press the action and power buttons at the same time on the front of the set for 10 seconds or so.
LCD TV's, Lock Mode
If customer forgot Parental Lock Code, unit must be re-initialized.
Press and hold the Volume down button on the front panel, press the OK button on the remote for 5 seconds.
DVD's Lock Mode
Setting Method
The sales demonstration lock function is set by simultaneously pressing the "POWER" button of DVD Player on the remote control unit and the "STOP" button on the main unit. ("LOCKED" is displayed when the lock function is engaged.)
Release Method
The function can be released using the same procedure as for setting. If the remote control unit is not at hand, the function can be released by using the same method as for player initialization (pressing the "PAUSE," "SKIP/SEARCH<<"and "OPEN/CLOSE" buttons simultaneously).
VHS-DVD Recorder (DMR-ES40V), Forgotten Ratings Password
From the Owners manual: Open tray, Keep Pressing Rec and Play/X 1.3 buttons on the remote for 5 or more seconds.
Another servicer found resetting to defaults worked well.
(VCR>DVD Dub) + (Open/Close) + (DVD Rec)
Bill
Apr 01, 2008 | Panasonic CT-27E13 27" TV
Code for panasonic tv
ineed the code for a panasonic ct-27sx12af
Dec 01, 2007 | Panasonic CT-27G11 27" TV
Televison & Video Logo
298 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
