Question about Ricoh Aficio 2022 All-In-One Laser Printer
SC542 Error message Sc542 on Ricoh
  • 2 more comments
  • ainasurf Apr 21, 2008
    IN FACT, MY MACHINE IS REX ROTARY 2822 Which I THINK HAS COMPATIBILITY WITH THIS AFICIO 2022, isn't it?
    what is the problem when SC542 code appears?
  • JBB baker Dec 12, 2008
    Ricoh Aficio 550 has code SC 542-00 and won't copy. How do I get rid of this code and make the machine start copying again?
  • Anonymous Mar 18, 2009
    we were trying to print on a ld 265 lanier printer when the printer gave was a message of waiting to print and then the error message of sc542
  • Anonymous Mar 16, 2014
    3510 sc542
Sc 542 is when the machine cant warm up to temperature for whatever reason usually entering service mode via clear 107 clear stop and rebooting clears the code if that dosnt work then the next step is call a service engineer
Posted on Mar 31, 2008
Press following keys in sequence
1. Clear (Yellow Key)
2. Press 107
3. Press "C" (Orange key)for 4 seconds It will give beep
4. Restart
5. Press SC copy (on Screen)
6. Press page down arrow until you get code 5810
7. select 5810
8. Execute
9. Restart
Thanks
Amit Luthra
Posted on Dec 04, 2008
    Novelist:
  • 201 Answers
How about:
n order to clear error SC542, you can perform the following:
  • Press and hold online + escape, then power on.
  • Use up and down arrow keys to select SP2
  • Press Enter
  • Use up and down arrow to locate SP5
  • Press Enter
  • Use up and down arrow keys to select 810
  • Press Enter
  • Confirm the selection
  • Power off and on.
Posted on Jun 02, 2015
4 Suggested Answers
SOURCE: error sc542
"clear modes", 1, 0 , 7, then (hold) "clear/stop" for a few seconds until "sp mode" comes up. turn main power off/on (red switch).
If code comes back there is trouble with the fuser that needs to be repaired to clear code permanently.
Posted on Apr 21, 2009
SOURCE: ricoh aficio 2022 error code sc542
I have a Aficio 551/700 and the display reads SC124 anyone have a suggestion on how to re-set this
Thanks
ES...ASD
Posted on Feb 08, 2008
SOURCE: Ricoh 1515 MF shows error code sc542
Um.. I don't see an "online" or "escape" button anywhere on the printer...
Posted on Jun 23, 2008
What is error code SC542 for ricoh aficio 9005?
Ricoh Aficio MP2510, 3010 Error code sc542 on Lanier ...
? 6:08
https://www.youtube.com/watch?v=58MQVyjfDyg
Sep 3, 2013 - Uploaded by Used .Copier
Are you getting Error Code sc542 on your Ricoh, Lanier,Savin or Gestetner copiers? ... Ricoh Aficio 1022 ...
How to reset Ricoh Error Code sc542 sc546 sc548 problem ...
? 2:41
https://www.youtube.com/watch?v=3CnGl1Ytp34
Sep 21, 2015 - Uploaded by Copier Liquidation Center
How to reset Ricoh Error Code sc542 sc546 sc548 problem ...Ricoh Aficio copiers : AFICIO 1013 F
Dec 02, 2015 | Ricoh Aficio Office Equipment & Supplies
Ricoh sp3510 sc542
This is the correct solution to resolving SC542 error on a Ricoh SP3410 SF and SP3510SF:
Press Clear/Stop button once and then press 1 0 7 and then the Start button to enter the "Engine Maintenance" in Maintenance Mode. Select "Fuser SC Reset" and execute..press ok. Turn main power on and off. Issue will be resolved.
Mar 16, 2014 | Ricoh Aficio SP3410SF Laser Print
What is error code sc542
I found some information on this error at http://www.fortc.com/2007/06/17/ricoh-cl4000dn-error-code-sc542/
According to this website, the error code is due to a fuser temperature problem.
The Fix
In order to clear error SC542 follow these steps:
- Press and hold online + escape, then power on.
- Use up and down arrow keys to select SP2
- Press Enter
- Use up and down arror to locate SP5
- Press Enter
- Use up and down arrow keys to select 810
- Press Enter
- Confirm the selection
- Power off and on.
Kindly rate this solution, thanks!
Mar 08, 2011 | Ricoh Aficio 3025 All-In-One Laser Printer
Sc:542 error message on the screen
You need a firmware update…
SC542 SP1-103-2 Off + Temp has been newly added to prevent SC542 from occurring at machine power-on under low-temperature conditions.
Note: For this fix, it is necessary to use Controller firmware ver5.15.1 or newer.
Apr 02, 2010 | Ricoh Aficio 2015 Copier
Ricoh aficio cl7300 error sc542 what does it and how do ifx it
This error is power related... their are two possibilities either... your fuser is blown or your machine needs a reset... here is a link to try the reset...
the reset should be all you need...
reset link
Feb 08, 2010 | Ricoh Aficio CL7300 DT2 Laser Printer
Ricoh aficio 2232c sc542 error
SC542 means that the thermistor hasn't detected right temperature in given time.
Often you only have to reset service code.
Try this reset:
  • Press Enter
  • Use up and down arror to locate SP5
  • Press Enter
  • Press Enter
  • Power off and on.
from http://www.fortc.com/2007/06/17/ricoh-cl4000dn-error-code-sc542/ here is another service procedure:
  • Press Mode(The Yellow Button)
  • Enter 107
  • Press STOP Button for 3 second (RED Button)
  • Copy Sp
  • 5810#
  • Execute
  • Power Off
  • Power On
Nov 19, 2009 | Ricoh Aficio 2015 Copier
Ricoh 2090 SC542 error
model 2090 richo sc 542 thermistar and hetar mail cancektar parobelam
Aug 22, 2009 | Office Equipment & Supplies
Ricoh Aficio 2022 All-In-One Laser Printer Logo
1,958 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
fares
Level 1 Expert
Michel
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
