Fisher Model CA-270 amplifer. Audio select not working.
I have a Fisher Model CA-270 amplifer. The right hand ride of the face lat has controls to select what audio device. Ths is not working. Everything else works, powers up, lights up. Can't select a device. The unit is not allowing an input at all. 16VAC and 19VAC works. Any ideas.
  • 4,234 Answers
When you state that you can not select a device, do you mean that there is no sound, or that the device selection is not happening? A few more descriptive details will help here.
Thanks,
Dan
Posted on Feb 02, 2010
How to adjust height on rear springs
adjusting the spring tension makes the ride harder and mite hold you up slightly ! is the adjuster on the top of the shock and rotates by hand coz thats the oil reaction responce , or is it below the spring which you need a tool to adjust ? if suspension is nearly full compressed after all these then fit longer shocks ! Dial a ride air shocks are good as you can select the height , not cheep though ! P...
Dec 21, 2013 | 1987 Honda VT 1100 C Shadow
My Studio Standard by Fisher stereo system's audio keeps breaking up.
Could be a defective volume control. After 20 years, it would not be surprising
Apr 10, 2013 | Fisher Studio Standard Am/fm Synthesizer...
Fisher Price Baby Grand Piano not working properly.
Hi, we have exactly the same problem with our baby piano. The sun, hands and music note not moving or doing anything it suppose to do. Did you manage to get it fixed?
May 02, 2012 | Fisher Price Laugh and Learn Baby Grand...
I have a Kenwood KR-V9030 and the right channel is crackling and will not provide increased output when the volume is turned up. 1) Swaped speakers from left to right and the problem is in left speakers...
There is a chance that a common control may have developed a high-resistance or 'dead' spot and is causing your symptom. Turn the POWER OFF and operate every control throughout its range a number of times, especially rarely-used ones like Tape Monitors and the Mute control.
If it still doesn't work you might want to prove if its a low-level signal loss or a high level amp failure.
One way would be to run an RCA cable pair from the Tape Out to any other device (even a TV with speakers) you might have that accepts an audio input. If IT can't detect receive the DEAD Channel you're losing it in the preamplifying or source selection stages.
If it CAN be played externally, the receiver is losing it on its way to or at the amplification stage. Further isolation would require hands-on technical expertise.
Apr 16, 2011 | Audio Players & Recorders
No output on right channel ofkr7050
"KENWOOD" KR7050?
I presume you have proven the channel is dead by trying multiple sources, swapping a different speaker onto it and that the balance control is NOT all the way to the right; headphones don't work either and we're down to proving it's dead before you take it in to a tech, right?
There is the slighest chance that a common control may have developed a high-resistance or 'dead' spot and is causing your symptom. Turn the POWER OFF and operate every control throughout its range a number of times, especially rarely-used ones like Tape Monitors and the Mute control.
If it still doesn't work you might want to prove if its a low-level signal loss or a high level amp failure. One way would be to run an RCA cable pair from the Tape Out to any other device you might have that accepts an audio input. If IT can't detect receive the Right Channel you're losing it in the preamplifying or source selection stages.
If it CAN be played externally, the KR is losing it on its way to or at the amplification stage. Further isolation would require hands-on technical expertise.
Jan 06, 2011 | Kenwood Audio Players & Recorders
How to fit new belt
Ya gotta have model numbers. Go to searspartsdirect.com and enter your model number. Most models then have manuals available over on the right hand side of page. Most manuals have pictures or diagrams on bets.
Aug 11, 2010 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Latitude & longitude
Here is the way to find the Lat/Lon Info on TomTom.
Tap on main screen. You will be taken to Main menu 1 of 2. Tap on the arrow. You will move to Main menu 2 of 2. Tap on Browse map. You will see the lat/Lon info on the bottom left hand corner (of a selected location) Tap on another location and you will see that the lat/Lon will change to that of the newly selected location. You can use the slider on the right hand side to zoom in or zoom out so that you can get the Lat/Lon info of far off locations. However, for this purpose, google maps would be a better option. But if you know the address, use the find button which will give you easier access to Lat/Lon info.
May 02, 2010 | Tomtom XL 330S GPS Receiver
Hit Object - Steering gear shifted....decreasing right turn to 15 degrees...increased left turn to 90 degress. How best to reset?
look down at the base of the steering column and you should notice that the steering is like two gears faceing each other. when you hit an object hard enough it is possible for the gears to jump out of alignment, simply loosen and realign, gears should be facing each other equally, to give you the same turn radius, left and right
Oct 23, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
RE: Fisher Model CA-270 - 480 watts.
These units use amp-pacs for the output stage, if I remember correctly. All in all, the unit will require some diagnosis to determine the problem with the power supply and the final output stage. The total cost of repair easily could exceed $125. You can probably replace the unit with a better one for not much more.
If you would still like this unit repaired, please indicate where you are in the country and I'll try to find a shop for you.
Dan
Aug 12, 2009 | Audio Players & Recorders
220 people viewed this question
 Grubhead
Grubhead
