Question about Canon PIXMA iP1600 Printer
Canon iP 1600
Hi
i am using printer for the first time and i dont know how to put cartridge in 1P1600...and what is the difference between ink and cartridge...i want to take colorful prints so what will i use for that, ink or cartridge???
let me know..
thanks
  • 1 more comment
  • Anonymous Mar 12, 2008
    GIVE ME DIRECTIONS FOR CHANGING CARTRIDGES
  • Anonymous Mar 14, 2008
    how install ink
  • smcoggin82 Sep 18, 2008
    I can't access the cartridges. I'm trying to change the cartridges, not refill the ink with a needle. The cartrdiges are empty and are stuck to the right side of the printer. I tried unplugging the computer and moving the cartridges with my fingers, but they wouldn't budge.
    Help!
    Guru:
  • 377 Answers
Dear
you can refill your catridge, open the label .... make a whole with knife or something edge, and the red color in center position, the yellow in the right position , and the blue in the left position
don't refill too full, about a 30 cc inks
oke maybe it can help you
thks
cropp
Posted on Mar 15, 2008
Canon ip 1600 'color cartridge not recognized and/or device not r
Two things. 1. check your cabling to make sure your printer is properly connected. 2. clean your printer's inkwells.
If you send me an e-mail, I can send you a service manual for a Canon Pixma iP1500. Manual is the same for both printers. I can also send you the software service tool. I have both, as I have a Canon iP1500 printer (cheap ink cartridges).
My e-mail address is: 7ohnnyramone@gmail.com
Best of luck, -Ric C.
Aug 03, 2010 | Canon PIXMA iP1600 Printer
Canon Pixma iP 1600 will not print
Hi there
You can try this it some times works.
Super Canon User's method of resetting IP1600
1.Press Resume button hold for 1 - 2 minutes (count to 1 to 15-16)
2.Open the cover right away
3.Release Both cartridges out and then put cartridges them back again
4.Close The Cover
5.Turn Off Then Turn On again.
You can download the Resetter tools program from my website.
Click Link = http://www.4all2sell.com/reset-tools/ip1600st-RESETTER-TOOLS.zip
1. Download software for Canon iP1200, iP1600, 2200 Printers.
2. Unzip downloaded file by etc
3. Run GeneralTool.exe
4. Select the connected USB port number from USB PORT
5. Click LOCK RELEASE, and select the applicable model name in SET DESTINATION
6. In CLEAR WASTE INK COUNTER, select MAIN or PLATEN. The selected waste ink counter will be reset. MAIN resets the main waste ink counter, PLATEN resets the platen waste ink counter.
If both the main and platen waste ink absorbers are replaced, reset both the main and platen waste ink counters.
Free WinZip http://www.winzip.com/downwz.htm
Please call back to vote
All the best: Pineworks
Feb 22, 2009 | Canon PIXMA iP1600 Printer
Encountered problem inserting cartridges
Hi. Go to this site:
Pixma iP1600 Support
On the Support and Service tab there is a Search Our Knowledge Base block.
Below "Please enter your question:" type in "replace ink cartridge". (Without the quotes of course.)
Click on "Search". One of the choices that appears is "How do I install the ink cartridge(s)?"
Click on it and a window will open with pictures and animations to guide you through the process.
Thanks for using Fixya.
A "Fixya" rating would be most appreciated.
Jan 26, 2009 | Canon PIXMA iP1600 Printer
My printer says that it is out of ink on the color side
hi all,
The printer shows message No Ink means ink has run out. Even you refill the cartridge this message stay remain. Check here to find out more.
regards
Nov 19, 2008 | Canon PIXMA iP1600 Printer
How to refill canon pixma ip1600 ink colour? the hole is too small.
IF YOU HAVE BUY THE INKS THEN YOU GET NIDLE AND SIRING THEN YOU WILL USE THE TECHNIC DOCTOR USE TO SWAP THE LIQUID FROM THE CONTAINER AND INJECT IT IN THE BODY YOU WILL USE THE SAME TECHNICS GET THE INK IN TO THE SIRING AND PUT IT IN THE CARTRIDGE BUT MIND YOU LOOK AT THE HOLES VERY WELL RED HOLE WILL BE MARK RED, BLUE WILL BE MARK BLUE WHILE YELOW WILL BE MARK YELOW SO ALL YOU NEED TO DO IS FOR YOU TO PUT THE INK IN THE RIGHT HOLE IN SOME CARTRIDGE THE HOLES WILL GUIDE BY A OBJECT REMOVE CAREFULLY THEN AS YOU FINISH REFILLING EACH HOLE PUT THE OBJECT BACK.
Nov 13, 2008 | Canon PIXMA iP1600 Printer
Error message
Hi there
4.Close The Cover
Jun 30, 2008 | Canon PIXMA iP1600 Printer
Printer Pixma IP 1600
Verify your ink cartridges have the 'Tape: removed from the top of the cartridge.
IF the tape has not been removed a vacuum is present in the cartridge and it will not allow the ink to flow smoothly.
Also try a few cleaning cycles.
Feb 09, 2008 | Canon PIXMA iP1600 Printer
Canon Pixma 1P1600
printer driver canon PIXMA iP1600
Oct 08, 2007 | Canon PIXMA iP1600 Printer
Waste ink absorber on canon iP 1600
For Canon ip1000 and ip1600, maybe others
1. remove cartridges
2. unplug AC power
3. hold power button and plug AC power (keep holding power button.
4. press resume 4 times
The waste ink counter should be reset by now
Or
http://www.servicemanuals.ru/download/canon/ip1600.htm
Aug 13, 2007 | Canon PIXMA iP1600 Printer
Using refilled cartridges
Are these chipped cartridges/ If so you will need to get hold a cartrisge re setter Most ink suppliers/manufacturers do them.
Jun 02, 2007 | Canon PIXMA iP1600 Printer
Canon PIXMA iP1600 Printer Logo
89 people viewed this question
old marine
old marine
