Question about Alpine SWR-1021D Car Subwoofer
The box i have only has one out so is it safe to wire these subs parallel?
  • colin butcher May 11, 2010
    Ok, you have a twin box with two subs but only one connection on the box, is this correct?
  • 44 Answers
Yes you can, but paralell series would be better. connect the +'s together and do the same to the negative side and brigde to amp. you can thank me later, have fun bangin
Posted on Feb 10, 2010
2 dvcoil 4ohm.subs, need 2 ohm load total for monoblok.amp. how do I wire.it
If you run one sub with the DVCs in parallel, you would get 2 ohms. If you run both subs with all DVCs in parallel, you would get 1 ohm.
If you run both subs with DVCs in parallel and subs in series, you would get 4 ohms.
If you run both subs with DVCs in series and subs in parallel, you would get 4 ohms.
If you run one sub DVCs in series and the other sub DVCs in parallel and both subs in parallel, you would get 1.6 ohms but the subs would not be balanced.
If you run both subs on only one coil and the subs in parallel, you would get 2 ohms (but only if the individual coils are rated for the full power)
Oct 15, 2015 | Ohm Car Audio & Video
Wire 2 sub 4ohm
I am assuming these are subs, you didnt say, but that is my guess. do you want bass, or do you want to take it easy on your amp? do you have a terminal cup on your sub box, or just wires going into the box to the speakers? take it easy route: wire positive from amp to positive of one speaker, negative of amp to negative of the other speaker, with a jumper wire connecting the negative of the first speaker, to the positive of the second.
more bass route: run seperate positive and negative wires to each speaker, making sure to maintain proper polarity.
Oct 21, 2013 | Jl Audio 500/1 Car Audio Amplifier
How do I wire up my 4subs in bridged to my peace 2600
Please state the subs impedance, but assuming 4 subs with 8Ohm Voice Coil you CAN'T run them in parallel in Bridge Mono because this amp's minimum impedance is 4Ohm in bridge and 2Ohm stereo, maybe a series/parallel connection work, but what's the advantage to run them in Bridge mode? This amp delivers 900W per channel at 4Ohm, you can run a pair paralleled for each channel in a safe way and without the high-risk of your amp being destroyed, besides, amp power at 4Ohm Bridged is NOT recommended for continuous use, let me know your results...
May 13, 2012 | Peavey Pv 2600 Power Amplifier
How should i arrange the wiring on my xm-zr1852 xplod amplifier to get the best performance out of my 12'' audiobahn subwoofers?
it depends on the impedance of the subs-if your subs are dual 4 ohm coils then you can parallel the coils which will give you 2 ohms per sub- you could get max performance from your amp by just wiring the 2 ohm speaker load to each channel of the amp which will hit them with about 200 watts rms each. another way to do it is to wire the coils in series which will make each sub an 8 ohm load and then parallel them together and that will show a 4 ohm load -which you can use to run the amp safely in bridged mode. This will give you exactly the same amount of power to your subs as in 2 ohm stereo will. so with your amp being 2 ohm stable in stereo or 4 ohm stable in bridged mode- those are the numbers you want to hit for maximum"safe" operation
Dec 10, 2009 | Sony Xplod XM-554ZR Car Audio Amplifier
How to connect HIFONICS BXI 2607 D watt at 1 ohm....
That's dependent on your subwoofers. You will need 2 dual 4 ohm subs wired in Parallel, a single dual 2 ohm subwoofer wired in parallel, a single dual .5 ohm wired in series. Or something similar.
http://www.bcae1.com/spkrmlti.htm
Nov 20, 2009 | Hifonics BXi 2006D Mono Block Amplifier...
How many svc subs at 4ohm does it take to get this amp to 1ohm stable and can you reccomend a good sub combo for this amp whether it be dvc or svc
It depends if your sub is 4ohm svc, or 2ohm svc. 4ohm would take 4 subs wired in parallel, 2ohm would take 2 subs wired in parallel. But for a amp that big, subs that'll handle it are definitely gonna be dvc. I'd recommend 2 Orion 4ohm dvc hcca's. They come in either 15in or 12in. the 15s are louder if you have the space for them. As far as wiring goes, wire the voice coils on the subs in parallel to 2ohm per sub, then wire the 2 subs in parallel to 1ohm. Goodluck and congrats on the equipment, Orion is about as good as you can go for subs and amps. just be ready to lay down some dynamat cuz this system'll bloww your vehicle apart! good luck...
Oct 08, 2009 | Orion 2500D Car Audio Amplifier
I have a audiobahn a400t and im running 2-12''jh45 mtx jackhammers the speakers are wired in parallel stabel @ 2or1 ohm. the speakers are in a ported box. how do i run my wires to my hook these up right to...
Hello rattle822,
A pair of JH4512-04's can be wired to 2 ohms if the subs themselves are paralleled. There's only one voice coil and it's 4 ohm. If wired in series, the final impedance to the amp would be 8 ohms. They cannot be wired to 1 ohm.
In bridged mode, your 4-channel amp is only stable down to 4 ohms. You can bridge 2 of the channels to provide a relatively low 200 watts RMS X 2. The best power solution for your subs would be to bridge channels 1 and 2 and wire one sub to it. Likewise, bridge channels 3 and 4 and connect the other sub. If you connect both subs in parallel, the impedance will be too low causing the amp to overheat and possible fail.
As for the settings: Low pass filter on, crossover somewhere between 80-100, input levels to match your receiver, and bass boost to your personal preference.
Hope this helps.
Aug 13, 2009 | AudioBahn Car Audio & Video
Help wiring kicker cvr12's
Hello pr7met7me,
Assuming that the "old sony box" has 2 chambers with at least 1 cu/ft of internal volume each, there should be no problem running the Kickers. The CVR's are dual voice coils and come in either 2 ohm or 4 ohm versions. The coils are wired together either in parallel or in series and then wired to the box terminals.
You did not specify what make and model of amp that you intend to use. The amp will dictate how the sub voice coils are wired. You do not want to go below the minimum load that your amp is capable of supporting. If your subs are the 2 ohm version, you wire the dvc's in parallel and then parallel both subs to the amp, your final load to the amp will be 0.5 ohm and there are not many amps stable at that low of an impedance.
The terminals with the white dots are for the first voice coil. The terminals with solid-red and solid-black markings are for the 2nd voice coil. In a parallel setup, you would wire the white-dot positive and the solid-red terminals to the box internal positive and the white dot negative and solid-black to the box internal negative. In a series setup, you would run a jumper from the white dot negative to the solid-red and then connect the remaining terminals to the box terminals.
Hope this helps.
Apr 11, 2009 | Kicker CVR12 Car Subwoofer
Popping
If you Wire the 13 w7 in parallel you get 0.75 ohms which this amp is incapable of handling, that's why your speaker is popping. Be carefull cause this setup could ruin both your amp and sub. You have to wire that sub in series so that the amp "sees" a 3 ohm load which it's best suited for.
May 28, 2008 | Jl Audio 13W7 Car Subwoofer
Dual voice coil wiring to class d amp
The easiest way to think of wiring voice coils and subs is this:
  • Two items of the same impedance in parallel = Half of the impedance
    • 4 ohms in parallel with 4 ohms = 2 ohms
    • 8 ohms in parallel with 8 ohms = 4 ohms
  • Two items of the same impedance in series = Double the impedance
    • 4 ohms in series with 4 ohms = 8 ohms
    • 8 ohms in series with 8 ohms = 16 ohms
In this case, you want to wire two subs, each with dual 4 ohms voice coils, so that the total equals 2 ohms. Your options are:
  • DVCs in parallel, 2 subs in series = 4 ohms
  • DVCs in series, 2 subs in parallel = 4 ohms
  • DVCs in parallel, 1 sub = 2 ohms
With two, dual 4 ohm subs, you can only have 1 ohm or 4 ohm total impedance.
Mar 16, 2008 | Car Audio & Video
Alpine SWR-1021D Car Subwoofer Logo
Top Alpine Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Jaime Hernandez
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
