CD exchange drawer wont open unless pried by a screwdriver. Once open it does not close properly unless pushed closed.
  • 506 Answers
I don't know how your unit would be constructed however most CD trays are built like this. The tray itself has little teeth for a plastic/nylon gear to ride on. Open the tray and look underneath to see if the teeth are damaged, if they are you may be able to take a small file and repair the damaged tooth or teeth. Does the tray open and close smoothly? If it does then it could be also be the little belt that connects the shaft of the motor to the gear drive assembly. The first test doesn't take much time however determining if the pulley is bad will require some disassembly of the unit. Good luck!
Posted on Feb 02, 2010
The display flashes "closed" and I can't open the cd drawer when pressing the open/close button. Is there a reset please ?
Try removing power from the unit, let it set two minutes without power and power it up again. See if the problem continues.
Make sure the cd drawer is complete closed and flush with the front panel. If not, something could be stuck inside.
Turn off power and remove cord from wall for next step:
There is a small hole generally on the flat face of the cd drawer through which a bent straight paper clip can be pushed gently until you hit a mechanical stop. Pushing slightly harder at this point should cause the cd drawer to move open mechanically. Gently pull the cd drawer open until you can remove any CD still inside.
Gently push the drawer closed again and restore power to the unit and see if the problem returns.
Would be nice to have manufacturer and model number of the CD player.
Apr 08, 2015 | Audio Players & Recorders
The CD drawer on a JVC EL-E3 CD Player fails to open/close. The CD fails to play when I physically close the drawer. The drawer does not close completely and needs an extra push to close it.
Sounds like the alignment is off. By physically pushing the drawer.
There is a motor on the side of the drawer that should control the drawer by pushing a piece of plastic back and forth. This piece can shift if pressed to hard. In the back of the drawer are the rods that control the top to drop. These need to be aligned with the side motor.
Jan 07, 2015 | JVC Audio Players & Recorders
Cant open dvd drawer
Sometimes DVD player drawers get stuck closed because the disc inside isn't seated properly. At other times the player may have another problem. The first step in discovering if it is the disc or another issue is to remove the disc. Most DVD players have a secret eject button. It allows you to open the drawer when a disc gets stuck and cannot be ejected normally.
For this you'll need a standard size paperclip.
  1. Unfold the paperclip and make it as straight as possible.
  2. Look closely at your DVD player . Push the tip the paper clip into the small hole on the tray cover on the front of the Toshiba. The hole is on the right side of the cover.
  3. Press inward gently with the paperclip until you feel a slight resistance, then continue pushing to engage the internal eject button. The tray should pop open partway.
  4. Gently pull the drawer until it's fully retracted. Be careful not to pull too far.
  5. Remove your disc from the drive.
  6. Before you reinsert another disc, use the remote and/or buttons on the player to close the door, and reopen it. You can also press carefully with your fingers. If you cannot open/close the drawer normally at this point, do not put in a new disc until you have repaired the problem.
What You Need
Dec 09, 2013 | Toshiba SD Computers & Internet
My top drawer of my Fisher and Paykel dish washer wont close tight. It seemed to be jammed and not closing unless it was pushed closed hard and then it jumped a bit now wont close tight and has no...
Make sure the unit is level. Remove drawer. On the inside of the cabnet there are the drawer runners on iether side. Behind these there are a pair catches. If one or both of these are latched back when they shouldn't be, ie. when the drawer is open, they will obstruct the drawer from closing fully and fail to hold it closed.
Hope this helps
Dec 13, 2009 | Fisher and Paykel 24 in. DS-603 Built-in...
Drawers wont open or close.
I will assume you are talking about the CD/DVD drive drawer.
Get a large paper clip. unbend it part way and use the straight end to push the drawer out using the little hole located on the front of your drive.
You may have a stuck disk in the drive.
Mar 19, 2009 | Dell Computers & Internet
CD door will not open. Does not respond to the open close button. Cd is incside player. Was put in correctly. How do I open cd drawer without breakin it.
the cd drive should have a tiny hole under the drawer. push a small screwdriver into the hole and it will release the drawer.
Mar 16, 2009 | Aiwa Audio Players & Recorders
Dvd drawer wont stay closed
take it back to the store or repair shop. Same thing happened to a friend and because it was new, the machine was exchanged.
Jan 25, 2009 | Sony BDP-S300 Blu-Ray Disc Player
CD drawer will not open or close
Hi, The CD drawer mechanism needs a new belt. They have a motor that drives the tray mechanism, and there's a small belt that drives the main gear so that pushing the drawer in gently to close it doesn't damage anything. However, once that belt breaks/wears out, the drawer will stay in whatever position it was last in.
Jul 24, 2008 | Audio Players & Recorders
CD drawer stuck, then won't close
1. Most of the player drawer fixed over the chasis for a rigid support
2. try to remove the drawer safely without damagind the chasis and drive mechanism
3. there might be some shaft jam.
4. Look for the thread. how does the player drawer moves in and out
5. there may be some sensors to sense the door close/open. if it is jammed then open/close function cannot be done. why because this problem occurs
6. unwear the mechanism read the mechanism moving technique. see which has got jammed.
7. if you feel too risky then
8.contact service centre... all the best
Dec 21, 2007 | NAD L40 CD Player
Having a problem with my CD Player's drawer
This has to do with a mini switch inside the door mechanism that it pushes once but with the bounce phainomenon in electric pulses it thinks that you pushed the cd door inside manualy and it tries to close the door. Try replacing this mini switch. this will solve your problem.
Apr 15, 2007 | Denon DCD-425 CD Player
24 people viewed this question
 Grubhead
Grubhead
