Question about Hoover UltraCare HC6 150M Front Load Washer
NEED A MANUAL A2580
HOW CAN I GET A MANUAL A2580 WSHING MACHINE FRONT LODER
  • ADAMS ABY Feb 19, 2008
    i will be happy if i am considerd
My washing machine spring from fron loder cace out while pulling from front loder and now water leaking
It is so common that the drain leaks in many ways and is the most problematic fault in a washing machine. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that water has leaked then as the drain hose pump/valve and fittings are located on the underside of the machine it is important that you look for possible leaks here. In some cases the drain hose would be clogged at the drain end to outlet of the house and so there will be back flushing resulting in overflow to the outside. Also the drain pump/valve can be clogged or the drain hose clamps can be loose on the grip which can all cause the leak to occur. Removing and cleaning the drain pump/valve, tightening of the hose is also very important. Also water can leak if there are gaps on the front door gaskets and must be checked but this will happen only during the cycle and not on the drain cycle end.
Tips for leak: http://www.espares.co.uk/advice/washing-machines/a/7/1461/do-you-have-a-leaky-washing-machine.html
Check for tips on the link below to identify parts and removal:
Jan 21, 2013 | Washing Machines
I WOULD NEED THE USER MANUAL
Hi sansz,
Plz specify the brand name & model no of your Wshing Machine to get a specific manual.
Thanx
Aug 24, 2011 | Zanussi Washing Machines
Is the memory board gone in my electrolux washing
Sad to say, yes "Replace the board". Quote no. on the board as there are newer updates as models change.
May 23, 2010 | Electrolux EW1000i Front Load Washer
How do I pop the head on a worlpool top loder with raise head
unplug the machine
On top of the machine is the console there should be one screw on the left and and and one on the right side(at back sometime front where console appears to set on top of main cabinet) remove them... Then you should be able fold the bottom of the console up and back out of the way. There should be 2 brass clips on left and right stick a flat screwdriver in the front slot to release clips. Disconnect wires for lid switch. Tilt cabinet forward and remove....
Mar 19, 2010 | Haier HWD1000
Wshing machine operates but does not rinse and speen.
Try cleaning the filter if its not pumping out water this causes no rinse / spin
Oct 02, 2009 | Washing Machines
Drum bearing very noisy on my hotpoint wma44 wshing machine
Sounds like the seals have gone as did the ones on mine. It need a complete new spider frame and bearing set as the front bearing had collapsed and groved the bearing spindle. Open the door and try lifting the drum to see if there is any up/down movement.
Aug 31, 2009 | Hotpoint WMA44 Front Load Washer
My kenmore wshing machine 11023812100 is not
It appears your Agitator/Agitator Dogs has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jun 14, 2009 | Kenmore Washing Machines
I've got a hotpoint wf220 wshing machine which is not spinning the pump is working and the on/off lights and mini load lights are flashing
i have a hotpoint wf321 water comes in and pumps out have flashing mini load light on and start light, but drum does not go round,
Jun 06, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Intermmittent buzzing noise
IT COULD BE SOMETHING CAUGHT IN THE DRUM UNPLUG THE MAINS AND OPEN THE DOOR AND TURN THE DRUM BACK AND FORWARD YOU MAY BE ABLE TOPUT THE CAUSE EASIER LIKE WORN BEARINGS SOMETHING CAUGHT IN THE HEATER OR A BRA WIRE?
May 11, 2008 | Hotpoint Aquarius WD63 Front Load...
Hoover UltraCare HC6 150M Front Load Washer Logo
46 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
