Question about Dayton Heating & Cooling
Model#gg8s080b12mp11a does this model have lo-nox screen
How do i correct a "high limit switch circuit is open" code
check the fusable link for voltage on both sides if not replace also check pressure switch
May 26, 2014 | Jandy LX 400P Lo-NOx, 400,000 BTU Heater...
Lo Nox Fault
check safety circuit
Mar 09, 2013 | Raypak Pool & Spa
Header cracked on hayward pool lo nox h250fdn heater. need to replace the header. Please help?!
Headers on hayward heaters are usually warranted for 10 years, except for freeze or chemical damage. You may want to contact a local warranty station to see if you can get it replaced under warranty.
May 07, 2010 | Hayward H250FDN Low NOx Natural Gas Pool...
Blown Heater blower motor
you will have to replace the brain unit its shorted out
Jan 26, 2010 | Sta Rite Sr400na Max E Therm Pool & Spa...
Error code lo and eo4
The LO is just telling you the water is below 58 degrees. The EO4 is the fan sensor. If you haven't used the heater for a while you should check for rat and bird nests then you can check your air pressure switch to be sure it is OK. The NT LN model will have the gas pressure switch in the same circut, so if you have the low nox model be sure to check all your gas valves and be sure they are on. If this is a LP heater be sure your tank is at least 1/3 full to have enough pressure to run the heater. If the heater hasen't been run for a while be sure to bleed your gas line also. Good luck.
Dec 04, 2009 | Pentair Minimax NT Heater
Model # SR333NA e01r9
Try consulting the owners manual for these pool heaters. They have a very comprehensive flow chart that will walk you through troubleshooting step by step. This should answer any questions that you have and help you reach a solution.
http://www.backyardcitypools.com/images/bwp/Max-E-Therm-Manual.pdf
Jun 07, 2009 | Sta Rite Sr333na Max E Therm Pool & Spa...
Heater turns on runs for short time display reads 120 or so but temp stays at 80 or so
It is probably your thermistor. It is screwed into the header (the place where the pipes come out). To know for sure you would have ohm it out (I am not sure of the ohms of this particular model). If it ohms out ok then it could be the control board.
Apr 06, 2009 | Sta Rite Sr400na Max E Therm Pool & Spa...
Heating & Cooling Logo
100 people viewed this question
Top Dayton Heating & Cooling Experts
Paul Carew
Mack Baxter
Dan Webster
Dan Webster
Are you a Dayton Heating and Cooling Expert? Answer questions, earn points and help others
