Question about Sta Rite Ds3hf 1.50 Hp Self Priming Irrigation Pump
My model DHH 169 won't start. I hear humming noise when I turn switch on but pump motor won't start. I replaced the capacitor but still won't start. What might be the problem/fix?
  • 990 Answers
If you replaced the cap and their is nothing wrong with the impeller (check to see if it turns OK by hand) Then I'm sorry to say your motor is probally burnt out.
Posted on Feb 05, 2010
Should motor make humming noise - instead of making no noise - if starter Capacitor is the only thing faulty ?
Not always, just replace the cap to start with. Sometimes they howl an other bearing make a noise.
Jul 23, 2017 | Cars & Trucks
DAB Jet 62 won't pump
U might've burned the start capacitor also. If u don't see one on the exterior,check inside the end bell (cap) of your motor. Do u hear the motor hum? If not there a likelyness u burned ur motor
May 26, 2017 | Plumbing
Cambell Hausfeld model wl506201aj compressor Hums when switched on
This could be caused by one of two things:
- a stuck or broke tank check valve. This would be evident if the compressor starts up when there is no pressure in the tanks but only hums when the tank pressure is up. Some valves can be cleaned and will work for a while but they usually have to be replaced.
- motor start capacitor. If the capacitor is bad it won't get the motor spinning, with or without pressure in the tanks. You can test it by taking the shroud off the pump and carefully bumping the motor to get it turning. Be careful, it may run up to full speed right away. If it runs replace the capacitor, if not you may have a burnt or shorted motor.
Apr 11, 2012 | Campbell Hausfeld Air Compressor Check...
Pool Pump Motor (AO Smith 2HP 56Y CX) won't turn over when switched on. Makes slight humming sound. Removed the motor from pump housing. When I spin the impeller when powered on, the motor starts up
3 THINGS QUICK.. RUN CAPACITOR THIS IS LOCATED ON TOP OF MOTOR HAVE IT CHECKED. OR START SWITCH DIRTY OR STAR CAPACITOR BAD.. SEARCH YOUR AREA FOR YOUR LOCAL POOL PUMP MOTOR REPAIR GUY WITH FREE TESTING.. WARNING THESE CAPACITORS HOLD HIGH VOLTAGE AND WILL NEED TO BE SHORTED ! USE A DRY RAG AND COVER CAPACITOR THEN SHORT WITH SCREWDRIVER
Dec 26, 2011 | AO Smith Pool & Spa
When I turned my pump off to backwash and then turned it back on it made a humming noise then stopped running. Now it is doing nothing. what could the problem be?
sounds like a bad start capacitor, or there is something (rock, sand, or some debris) caught in the impeller.
The start capacitor not working will cause your motor to hum, then it will overheat and trip the high limit. It won't attempt to come back on until it has cooled. It's a common problem.
try clearing the impeller first, if that doesn't work and the motor shaft spins freely, then it's a capacitor.
Jul 27, 2011 | Hayward Power Flo Lx
Turn breaker on to hayward pump 1 1/2 hp model C48L2N134B1 just heard a humming noise and shut off
DIRTY START SWITCH OR AND COULD BE THE START CAPACITOR OR RUN CAPACITOR,. RUN CAPACITOR IS ON TOP OF THE MOTOR. I WOULD SUGGEST YOU TAKE THE BOLTS OUT AS PICTURED AND BRING IT TO YOUR LOCAL POOL PUMP REPAIR GUY WITH FREE TESTING.. SEARCH YOUR AREA FOR HIM ..JAY LONGWOOD FLORIDA
May 22, 2011 | Hayward 1 12 Hp Super Swimming Pool Pump...
Makes electrical humming noise but does not pump water
This is could be the capacitor that has failed. The capacitor gives the motor the initial kick in the right direction to get it started. You can confirm it is a failed capacitor and that the motor is still ok by flicking the fan blades with a stick in the direction it should spin just as you switch the pump on. The pump should run normally. You can get them off Amazon or ebay for around 5 Pounds (GBP)
Oct 11, 2010 | Karcher K2.26 Electric Power Washer
I have a Polaris LR51044 pump that is not working. When I turn it on it "hums" but won't pump water. I live in Baton Rouge, La. and we have had freezing or below freezing weather for the last 2 days. The...
Usually when a polaris booster pump hums it means 1 of 2 things; either the starting capacitor needs to be replaced (its located under the black hump on top of the motor) or the pump is bad. Most likely the starting capacitor needs to be replaces. This is where you should start since the capcitor is only $20-$30. Get a new capacitor from a local pool store, shut the power off to the motor, remove two screws on each side of black hump on top of motor, remove two wires from starting capacitor and install wires on new capacitor, replace cover and turn the pump on. If that doesn't work you will need to replace the motor.
Jan 09, 2010 | Polaris Pb4 - 60 Booster Pump
When I press the start button on my Kenmore Dryer Model #96291100 I hear the motor humming and the timer clicking but it's not turning on. The belt is good
you have a problem with a part called a capacitor,which holds an electric charge to start the motor when,when it's faulty,the motor cannot start,hence the humming noise.it must be replaced,only by a qualified repairman.
Oct 06, 2009 | Dryers
Motor hums then clicks off
Has the motor seemed a little slower in starting than usual? If so then you probably have a weak or defective motor capacitor. Try switching out with a new one.They are inexpensive.Try to turn the motor shaft at rear (under end cap) while it attempts to start. If the motor kicks on then replace capacitor.
Apr 09, 2009 | Jacuzzi MAGNUM FORCE POOL PUMP - TWO SPEED...
Open Questions:
See all Sta Rite Ds3hf 1.50 Hp Self Priming Irrigation Questions
Sta Rite Ds3hf 1.50 Hp Self Priming Irrigation Pump Logo
341 people viewed this question
Top Sta Rite Garden Experts
appman67
appman67
Jay Finke
Jay Finke
steve morris
steve morris
Are you a Sta Rite Garden Expert? Answer questions, earn points and help others
