Question about Hand Tools
No longer able to execute electric start..just clicking sound...plus...now can start by pull motion but unit cuts out will not continue to run nor does it have enough power to remove snow.
  • 494 Answers
Water can get into a snow blower and freeze use some, SOME gas dryer in the tank and try a hair dryer for the electric start........
Posted on Feb 14, 2010
Honda GX160 firepump runs good than dies starts first pull after and repeats
Check that the fuel tank is venting properly, sounds as though the tank is not venting therefore creating a vacuum that the carburetor cannot over come. Try running the engine with the fuel cap loose to see if that alows the engine to continue to run.
Dec 16, 2012 | 5.5hp 6:1 Gear Ratio GX160 Engine
Motor continues to run after machine has been switched off
If it keeps running after you unplug it, you have somehow gotten your hands on a perpetual motion machine. Use it to run a generator and sell electricity to your neighbors!
Seriously, I think you meant "after you turn it off at the washing machine control panel." You probably have a shorted motor contact in the timer (contacts welded together).
Oct 23, 2011 | Washing Machines
Mower deck will not engage when i pull the switch nothing happens
assuming all the other electric doodads are working; sounds like your PTO, electric clutch, has gone bad.
before you start buying parts get underneath the thing and find the heavy wire coming from the clutch and follow it back until you find the in line fuse container. take it apart and make sure it is not blown, if so replace it.
the crankshaft of the engine protrudes underneath the frame. there will be a belt transferring power to the transaxle for motion, and an electric clutch transferring power to the cutting blades.
May 06, 2011 | John Deere Garden
With Electric down, I just plugged my 12 in. fan into the XPower 200 PLUS after 15 min. the unit started to mum loudly.....and the fan stopped....is that as long as it will work before charged again
That sounds about right. 200 watts isnt alot of power, its enough to power small electronics such as phone chargrers, but if you want to power a high energy product, try a 650-800 watt supply. More watts = longer run time for your devices.
Mar 30, 2011 | Xantrex Technology XPower Powerpack 200...
Powers up for a few seconds then cuts out and goes dead
Make sure your extension cord can provide 13 amps or greater of current. The longer the extension cord the more current it requires to supply the 13 amps to your power washer. If your unit has a long extension cord it could pull more than the typical 15 amps used for a household circuit breaker. If you do not have an adequate circuit breaker it will continue to trip. Plug the unit directly into the power receptacle or use a larger current rated power cord and power receptacle. If the problem persists then the unit could be pulling too much current due to motor restrictions.
Jul 26, 2010 | Alfred Karcher K 5.93 M Electric Pressure...
Freezer compartment no longer cools. Continuous defrost cycle?
Good day,
Sounds more like the compressor trying to start and can't.
Pull the machine out, remove the rear cover and see if in fact the sound is coming from the compressor.
Apr 08, 2010 | Whirlpool Refrigerators
Toro powerlite 98cc engine...unit will start by pull motion but will not continue to run beyond 2 minutes or so....electric start no longer executes...get clicking sound
I believe your carburetor needs to be rebuilt or replaced. The carb has thin rubber diaphragms that meter in the fuel to combustion chamber. If the diaphragms get hard (from gas sitting in carburetor for extended time or from hot weather) they won't allow enough fuel in to keep up with the demand. if you need parts email desertairrepair@aol.com.
Feb 02, 2010 | Toro Blowers Rake and Vac - Electric...
Fiat scudo starts and runs for 8 secs then cuts out
8 seconds and stall,..
Sounds like you're starting fine and there's no apparent problem with the engines electrical impulses in regards to wires, plugs, coil etc,..
Which it sounds like you're running off residual fuel but continuous fuel supply is being disrupted.
I'm all but certain if you pull a SP it'll have unburned fuel on it. Check your fuel pump, filter, pressure regulator and injectors
From those symptoms the pump could be faulty, filter clogged and only feeding seepage, the regulator could be flooding it out ot the injectors aren't opening { clogged }
What do you get when you try to press the accelerator when it's running or have you not tried that?
Jul 27, 2009 | Fiat 124 Cars & Trucks
Help me please
sounds like the main pc board.
Jun 19, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
General Electric model # GSS25JSRFSS
if your appliance is humming then your motor might be out. Im not positive but i had a similar problem of the humming and clicking and the entire motor burned up. Might be a reason the lights are fading and such... Hope this helps
Hand Tools Logo
Top Hand Tools Experts
Don Numinen
Don Numinen
Ivan
Ivan
Level 1 Expert
Bill Boyd
Are you a Hand Tool Expert? Answer questions, earn points and help others
