I have an office jet k60 printer and tehre is a message on that i cannot get rid of saying colour carttridge remove and check .Nothing wrong with cartridge printer and copier working however fax isnt .i hear a dfial turn and when i put in no it says busy and wrong no after i have enteredin 1 number .have had machine over 6 years never any prob .
  • 2 more comments
  • sara971 Feb 02, 2010
    This soloution did not work .The display now states that there is an error incorrect colour cartridge .Still my fax does not work and display shows the sabove now.
    Please someone come up with a soloution .The printer and copier is wporking ,just the wrong message on lcd screen .Also why has my fax stopped working .
    Someone must have an idea .Its a great printer (all in one ) and I dont want to gte rid of it.
  • sara971 Feb 03, 2010
    all advice I have been given I have already tried and nothing works fax still now working saying busy as soon as I put a number in even though there is a dialing tone before i dial a number PLease can someone have some sdviuce that works !!!!
    As I said previously I have already tried this and nothing helps.
    message the same printer and copier work fax is busy and wont allow me to send anything even though there is a dial tone and when i try to input a number it comes up busy and wont allow me to do it.
  • 838 Answers
Hi, thanks for joining Fixya.
Please go to Setup> Restore Default/ Reset Factory Setting. Try to restore old setting and let me know.
Thanks once again.
Have a good day.
Posted on Feb 03, 2010
  • Mohd. Tareq
    Mohd. Tareq Feb 03, 2010
    If all advise given to you not works, last try should be to upgrade printer firmware. or disconnect it from pc and try to send or receive fax.
    Thanks for joining me.
    Good Luck
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. The reason the machine says to remove and check color cartridge is because of the drop counter of the printer. The printer counts the drops that come out of the machine
and when it hits certain #, it reminds you to replace the cartridge, even though the cartridge prints fine. To resolve this open the top cover of your printer with power on and then take both of the cartridges out, and close the lid. When it asks you to insert the color cartridge, do it. Then close the lid and the LCD display will ask to press 1 for new or 2 for used, press 1. Now do the same with the black cartridge. When you press 1, it actually "fools" the machine into thinking it has a new cartridge. Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Feb 02, 2010
  • Rylee Smith
    Rylee Smith Feb 02, 2010
    well in that case you can get the printer replaced as the issue could be that the print head has gone bad and instead of getting it repair its always better to replace it. Please do accept the solution if the issue is resolved or else revert for further assistance.
    Thanks
    Rylee
I lost my software to install my HP OfficeJet K60
You can go to http://www.hp.com/#Support and then click on download drivers.
It will ask you for your printer model and give you the option to download your drivers
Jan 22, 2009 | HP OfficeJet k60 All-In-One InkJet Printer
Faxes office Jet K60
You have to have either a dedicated phone line just for the fax --or-- pay your phone company approximately $2 a month for a service called Distinctive Ringtone. This service will ring a certain way when you have an incoming fax. You will then configure your fax machine to pick up when this distinctive rington is heard. The ringtone is usually two or three quick rings. Your fax machine's settings will have this setting.
Unfortunately, you can't just plug your fax machine into your phone line and start sending/receiving faxes. Look through your fax machine's manual regarding the distinctive ring service. Good luck!!
Oct 01, 2008 | HP OfficeJet k60 All-In-One InkJet Printer
I recieved a used HP office jet k60, no wires except the plug, and no user manual!
you can use the printer by itself , but if you want to hook it up thru the computer , then youre gonna need a special cable that connects on one end to the printer and USB connector at the other end , then your gonna need the installation disk that comes with the printer, but Im guessing you dont have the disk , but dont worry , it can be download thru the HP website , heres the link : http://welcome.hp.com/country/us/en/support.html , this will direct you with support, click where it says DOWNLOAD DRIVERS and SOFTWARE , and on the white box, you gonna write officejet k60, and follow the steps from there , hope this helps , please rate AJ
May 08, 2008 | HP OfficeJet k60 All-In-One InkJet Printer
Broken disk.
I'm assuming that you have Windows XP. If not, click on Software & Driver Downloads to access support for other operating systems. http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&cc=us&dlc=en&product=59273&os=228&lang=en&
Dec 14, 2007 | HP OfficeJet k60 All-In-One InkJet Printer
OfficeJet K60 All In One Problem:Aligning Cartridges
In the process of alignment there are two phases:
1. When the message comes to align the ink ..press ok and the page is printed out.
2. Once the page is printed then place the page on the scanner glass and tehn scan the same.
Follow these two steps in the same order and it will never give Align Ink Cart message again.
Oct 24, 2007 | HP OfficeJet k60 All-In-One InkJet Printer
HP OfficeJet K60 Printer
you can bypass when asked and use last good settings by..Press and hold the Enter button, and then press Menu
This problem is caused by incorrect alignment page print out caused by faulty cartridges, ideal fix is replacement of all ink carts
HP have a webpage dedicated to this...h10025.www1.hp.com
Also get on your gloves get out your vac and suck on the carts till a little ink comes out, make sure colour cart releases all 3 colours then reinstall, can get messy.
Oct 19, 2007 | Office Equipment & Supplies
Cartridge problems
Ref: our live chat - Definitely worth replacing the colour one with a new one - some other people had identical problem and that cured it - they really don't survive not being used very well. :)
Apr 21, 2007 | HP OfficeJet k60 All-In-One InkJet Printer
47 people viewed this question
jasbo
jasbo
