Question about Consew 146RB-1A Mechanical Sewing Machine
Upper thread fraying - Consew 146RB-1A Mechanical Sewing Machine
    Problem Solver:
You have a groove in one of your upper guides, or you have a bur on your hook assembly. Contact Robert at National Sewing Supply, 888-283-9640 if you would like more detailed information.
Posted on Feb 11, 2010
The top threat keep on breaking
Possible causes:
  • Needle eye too small for thread used - then thread frays and breaks
  • Cheap thread used that easily frays - esp. when thread has unequal thickness
  • Needle eye too sharp
  • Component of the thread guide is not smoothly guiding the thread or is sharp
  • Upper thread tension (far) too large
Jan 18, 2018 | Sewing Machines
My brother innovis machine has a problem. Top thread frays and breaks, not not seem to be picking up bobbin thread properly. I have changed the needle tried a previous bobbin.
Be sure to install a brand new needle--check that the needle eye is the correct size for the thread you are using--a small needle eye will shred heavy thread. It may also help to remove the top thread from the machine, ALWAYS RAISE the presser foot and rethread from the beginning. Verify the thread path is correct. Try different thread--AVOID old or bargain bin thread. Check that the upper tension is not too tight.
If the top does not pick up the bobbin thread, the machine may be out of time.
Otherwise, there may be a burr or snag somewhere along the thread path that is catching and fraying the thread. Sometimes there is a snag in the bobbin area (possibly the needle plate or hook) that is rubbing the thread.
http://www.servicethread.com/blog/stop-industrial-sewing-thread-breaks
What Causes My Thread to Shred
Fraying Breaking Madeira
Nov 09, 2017 | Brother Sewing Machines
Why does top thread keep breaking?
Sounds like your tensions, both upper and lower are out of whack. Easily fixed if so...google a vidyfor your make/model machine on adjusting both upper and lower tensions.
Jun 18, 2017 | Sewing Machines
The thread keeps bursting after a few stitches. I've tried adjusting upper & bottom tensions,changing the needle, trying it with different fabrics, but nothing seems to work. What do I do?
Usually when it stitches an inch or two and then breaks, the upper thread is mis-threaded.
Remove the upper thread and rethread from the beginning. ALWAYS RAISE the presser foot when threading the upper thread. Check to make sure the thread path is correct. If it is threaded incorrectly, the thread will frequently break.
Also check that the thread is not hanging up somewhere, sometimes it gets looped around something or it snags on the little slit on the thread spool or a rough spot.
If the upper thread tension is too tight, it will also break the thread. Make sure the tension disk is clean. If there is gunk or a piece of thread stuck in the tension disk, it could be interfering.
If the thread is fraying as it goes through the needle eye, then there is probably an incompatibility of the needle, thread, fabric.
All About Needles
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=2&ved=0ahUKEwjWgZq5ho3PAhUh7oMKHVc-DVcQFggkMAE&url=http%3A%2F%2Fwww.schmetzneedles.com%2Flearning%2Fpdf%2Fschmetz-needle-chart.pdf&usg=AFQjCNHTR52AmqwzvyCjbXmD5Ch52Va5_Q&cad=rja
Sep 13, 2016 | Singer 4411 Heavy Duty Sewing Machine
Top thread keeps breaking
Upper thread breaking is usually a sign of incorrect threading or tension too tight, although there are other possible problems:
Industrial Garment Printers Sewing Machines
When threading the upper thread, be sure to ALWAYS RAISE the presser foot so the thread will seat properly in the tension disks. Avoid old thread or bargain bin thread. If the thread is fraying and breaking at or near the needle eye, then try a different type of needle with a larger thread groove that will protect the thread from fraying on rough fabric. Also, check that the thread is not hanging up on something, ie the slit on the side of the spool where the thread tail is stored.
Sewing Machine Problem 1 Thread Breakage
Sewing Machine Thread Keeps Breaking
NMSU Checklist of Common Machine Troubles
Jul 02, 2016 | Brother XL-2600I
Sews perfect then locks up. I clean thread out then it will sew perfect again
Depends where the excess thread is accumulating.
If through the tension disks, there is something stuck that is interfering with the thread's path to the needle. Be sure to RAISE the presser foot before threading the upper thread and that it is threaded correctly. Can also try installing a brand new needle and changing the brand of thread.
Remove all the thread and rethread from the beginning verifying the thread path is correct. ALWAYS raise the presser foot before threading the upper thread.
Can also try cleaning the upper tension disks. RAISE the presser foot and loosen the tension all the way. Then gently pull a length of unwaxed dental floss down through the tension disks a few times.
If the thread is fraying at the needle, then it is most likely a needle-thread-fabric incompatibility. This link may be helpful:
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&cad=rja&uact=8&ved=0ahUKEwjBiZLlx8bKAhVik4MKHQAJCG0QFggdMAA&url=http%3A%2F%2Fwww.schmetzneedles.com%2Fall-about-needles%2F&usg=AFQjCNGsGZ5hl6pOJw4NdqTtkEIqlHZfuQ
Another thing to check is if the upper thread is hanging up somewhere. Sometimes it will get wrapped around a thread guide or the spool pin. The machine will sew for an inch or two and then the thread frays or breaks.
If the thread is accumulating in the bobbin area, there is most likely a nick or rough spot that is catching and fraying the thread.
Avoid old, fuzzy, or bargain bin thread.
Jan 25, 2016 | Sewing Machines
Why does upper thread break when I try to sew zig zag stitch?
Your tension sounds too tight, try lowering it on the upper thread. Or you may be using a cheap thread which frays easily and frays in the needle. Try using a longer zigzag to see if that works. Is straight stitch smooth?
Nov 02, 2015 | Brother Ls-2125i 10-stitch Portable Free...
How can I clean the upper thread sensor? My machine continually throws a "Check upper thread" error, even though the upper thread is fine. It seems the sensor is not "Seeing" it.
Try using waxed dental floss to dislodge the snag. Gently pull the floss toward the needle through the thread path. You might have to do it several times. You can use canned air to blow the lint out of the machine. Then make sure you are using a good quality thread. Avoid those cheap spools of thread because they usually are not spun tightly enough to prevent lint build up in the thread path.
Dec 30, 2013 | Brother PE770 Computerized Sewing Machine
Thread fraying on certain vinyl material, why?
u need a silicon based nylon thread and a larger needle. needle may be getting hot too depending on thickness of work. spray some silicon on upper thread.
Jan 30, 2013 | Juki DDL-8300
Brother 8500D sewing/emb machine - upper thread stops feeding
If the thread is hanging up at the spool - this could be the way it was manufactured, a nick in the spool end or the thread is unwinding too fast, puddling and wrapping around the spool pin.
Keep the bobbin case and surrounding area clean and free of thread tangles and snips. Thread tangles in this area can cause the machine to stop.
When the presser foot is down on any sewing machine, the tension closes and you cannot manually pull the thread through.
Sulky and C & C black tends to fray more than other brands of thread.
If the problem continues, the machine will need to be serviced by a professional.
Feb 24, 2010 | Brother Sewing Machines
Consew 146RB-1A Mechanical Sewing Machine Logo
215 people viewed this question
Top Consew Sewing Machines Experts
Michael Galve
Michael Galve
Oloyede Monsuru
Irene Tulloch
Are you a Consew Sewing Machine Expert? Answer questions, earn points and help others
