Washer won't spin,motor runs,belt is on all pullys turn without drag
  • 51 Answers
This is a simple problem to solve, the capacitor needs replacing, a very inexpensive part.
Posted on Feb 02, 2010
What needs to be replaced? I installed a new motor but my washer still won agitate or spin.
check / replace the start run capacitor for the motor
have a electrician do it or a service technician if you do not recognize it
it is normally up near the control panel
Oct 19, 2015 | Haier HLP21N Washer
Not spining- water standing can't get water to
If your washer is not spinning ! You first need to drain it. Then underneath your washer you will find your drive system. It will consist of drive belt, drive pulley or pullies and motor. Belt could have come off , if so check the condition before reinstalling, also some times from overloading the belt will spin on the pulley which will make it hot and thanks to the manufacturer the pulley is likely plastic. Parts supply shops best source for belts and possibly pulley though sometimes they want to sale you the whole motor with pulley which you don't need. If so uae internet to find your pulley probably under 10.00 dollars. Hope this helps.
Feb 23, 2010 | Kenmore 23822 Top Load Washer
Agitator will not spin easily from pully below or
transmission out buy new washer cost to great to repair 15 year old washer
Feb 03, 2010 | Maytag LAT3600A Top Load Washer
The drum does not turn.
there are two potential problems. firstis te belt to the drum drive pully from th moter. this is the easiest. take off the back panel an seeif the belt is intact. if so run through a cycle and see if the motor spins or triesto spin. if not this is most likely thesuspect. one plug three screws and about100 dollarsfixes te motor. hope this helps.
Dec 18, 2009 | Kenmore 44102 Front Load Washer
Belt won't stay on the pulley
These belts are really sensitive. Try messing around with it. Making srue that the belt isnt coming off the big tub pully. You tub pully isnt loose is it. Make sure the bolt that hold the pully onto the tub is tight on. Make sure the pully isnt loose. Inspect it for any small craks where that boltt tightens up. If the pully check out ok. Check the small motor pully as well. Make sure that isnt loose or anything. Pull on it if if its loose then thats you problem.. Inspect both pullys good. I would assume belt is in good shape right? If both pullys check out ok, then i would try to get the belt on and just mess around with it, spin the pully and if you se the belt starting to slip off adjust it as you keep spinning the pully....hope this helps
Jul 31, 2009 | Maytag Neptune Washer
Maytag Performa PAV2300AWW screaching noise, belt problem, pulley broke
My Maytag Performa was making the loud squealing noise. I changed out the water pump/bearing, took care of the problem.
Putting a new belt on just help burn up the bearing (they needed replacing) and probably ruined the new belt. Probably seized the water pump bearing and the belt jumped and broke the motor pully. A washing machine motor is very strong, when that h20 pump bearing seized (or possibly some bearings jamed up) the motor kept on turning that belt and the plastic pully gave in. You'll need to replace that also. If the h20 pumb bearing is turning freely, likely the bearings jammed up but or now loose. That bearing should be tight, no slack or play in it. You can probably wobble the pully on it all around while turning it. The slightest slack is too much.
Oct 09, 2008 | Maytag Performa PAV2200
Hotpoit belt
hook the belt around the motor spindle first then get the belt as far round the pully as you can once at that stage hold the belt firmly as you can on the pully and turn the pully round making sure that the belt does not slip off keep turning the puully round till the belt is fully on once on spin the drum around by hand to make sure that it is on the pully square with motor spindle. job done. if this helped please leave feed back.
Feb 20, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Belt
Jan 06, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Kenmore washer won't spin
ok " sounds like motor belts need replaceing, that smell is the loose belt rubbing against the motor pully.
Jan 01, 2008 | Kenmore 12502 Top Load Washer
Non-spinning washer
Do you hear the motor running when it doesnt spin? Is the belt still over the idler pully between the drive pully and motor pully? Does the lid switch operate properly? Need a little more information if you can. Give me a shout back, and we'll figure it out. Jim
Oct 31, 2007 | Washing Machines
Washing Machines Logo
24 people viewed this question
Top Washing Machines Experts
