Question about Maytag MMV5156AAS Microwave Oven
No heating - metal really is not a microwave's best friend
Hello - one of my children decided to see how well metal works in a microwave and decided to heat up a can. As expected, the microwave now does not work. The fan comes on, the turntable turns, all the electonic functions work on the panel - it just will not heat. What would I need to replace to get this working and would it just be cheaper to buy a new one? I can probably do the work to replace but if the part is going to cost me over $200, then it is not worth it. Thanks much for any help you can provide.
  • 958 Answers
Your child could have fried your magnetron. check for its price and if its a little less than a new oven then just buy a new one.
Posted on Feb 19, 2008
Works but does not heat up
It may be damaged from inside. Check it to the Oven Specialist. He will assist you and told you that what's wrong.
Maybe its Power Problems that causing heat not to produce.
Feb 03, 2016 | GE SpaceMaker Microwave Ovens
Hi, I have a GE JES1334 1100 Watts Microwave Oven, it can be power on, but doesn't heat, should I change any part to get it back to work? Thanks!
Hello, W/D here.
There are many variations of your model. Check the fuse first.That's the most common failure, and the cheapest to fix.
I checked the price of magnetrons and, if that is what is wrong with yours (which it sounds like), the cost of the magnetron is more to replace than the price of a new microwave. ($162 vs. $115), plus shipping if you bought the part on-line (I checked Appliancepartspros.com), and add in labor if you have someone else do the work. Your best bet is to take it somewhere and get a free estimate for repair, and decide from there. It may not be the magnetron, but it's impossible for me to tell from here.
Best regards, --W/D--
Feb 10, 2011 | GE JES1334 1100 Watts Microwave Oven
Kenmore microwave Model No. 721.62463201 runs but does not heat and has a terrificately loud buzz. All lights displays are normal
Hello there:
There's no heat, but it buzzes loudly When the microwave won't heat, but you hear a loud buzz, you usually have a defective power diode, high-voltage capacitor, or magnetron. I recommend that you consult with a qualified appliance repair technician for help in determining the problem and deciding what to do about it.
And if you have your warranty for this you can use it to ok
Hope this helps best regards mike
Nov 19, 2010 | Kenmore Microwave Ovens
Kenmore microwave runs but wont heat
Hello there:
There's no heat, When the microwave won't heat, soemtimes you will get a loud buzz, you usually have a defective power diode, high-voltage capacitor, or magnetron. We recommend that you consult with a qualified appliance repair technician for help in determining the problem and deciding what to do about it.
Oct 05, 2010 | Kenmore 63252 Microwave Oven
GE JVM130 001 Over Range Microwave does not heat
It's probably the high voltage rectifier diode or magnetron.
The magnetron will have a guarantee lasting about 5-9 years, so if it might be covered, contact GE at http://www.geappliances.com/service_and_support/contact/
If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
Also, there should be a very helpful "mini-manual" hidden inside the unit behind the control panel.
Dec 08, 2007 | Microwave Ovens
Is microwave dead?
It's probably an open thermostat or thermal cutout on or near the magnetron, or possibly the one on top of the cavity / body of the oven.
Once the thermal cutout is replaced and it's alive again, you may then find the magnetron is bad, too, and it runs but won't heat.
If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
Nov 10, 2007 | GE JE1460 Microwave Oven
Whirlpool microwave
It has a problem in the high voltage which should only be repaired by an experienced technician for safety. On some models the magnatron has a longer warranty than just one year. Will have to check your manual. High voltage parts are magnatron, capacitor, diode, and transformer. If it isn't under warranty it's almost better to buy new due to repair costs on microwaves. May be worth at least having it checked by a technician.
Oct 08, 2007 | Whirlpool MH2155XPS Microwave Oven
No heat or fan movement
Probably a bad door switch or door switch mount. If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info (as well as a text file which helps in diagnosing and repairing door switch problems) at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk You can find helpful exploded view diagrams and order parts by entering your full model number (without the suffix) here: http://tinyurl.com/gv383
Apr 19, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Motor runs but does not heat
You most likely have a bad door switch or a bad magnetron. You or a friend can fix the door switch problem for about $10 or less. If it needs a magnetron, that can run anywhere from $40-120, depending on which magnetron it has and whether you can get a generic replacement. If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk You can find helpful exploded view diagrams and order parts by entering your full model number (without the suffix) here: http://tinyurl.com/gv383
Apr 07, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Power comes, turn table and lights come on but no heat... their is a faint plastic metallic smell. I took out the fuse and then the microwave wouldn't power on at all. Any suggestions? Thanks,...
Sounds like the fuse is working fine! *grin* It's probably a bad magnetron or high voltage transformer. Since it's GE, it's much more likely to be the mag. If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk You can find helpful exploded view diagrams and order parts by entering your base model number (without the suffix) here: http://tinyurl.com/gv383
Mar 19, 2007 | GE JVM1451BA/WA/AA Microwave Oven
Maytag MMV5156AAS Microwave Oven Logo
56 people viewed this question
Top Maytag Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Maytag Microwave Oven Expert? Answer questions, earn points and help others
