Got home last night and for no apparent reason my tv had no display whatsoever or static, just a completely black screen, however there was sound any ideas?
    President:
  • 4,402 Answers
Need make and model
Posted on Feb 19, 2008
My magnavox crt is about 10+, worked great.Last night,the screen remained black, and sound was static. Tried unplugging, held the power button, ran a new cable line from working tv.No lights in back.
I hope I can help. I would first try another outlet.
  1. another power outlet
  2. check the cable from the TV to the wall or cable box
  3. Check the TV Input channel, make sure you go through each source input to verify which tv/video input is the correct one.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/laura_08254539050d64db
Jul 28, 2016 | Televison & Video
DS240WB worked fine but seems now not recognizing signal and fails to turn on
The reason why your monitor might not be recognizing a signal is because the graphics card in your pc might not be correctly plugged into a pci slot or your internal graphics may have a short somewhere. If the monitor turns completely off after it cycles Then it might be an internal problem with the backlighting in your monitor screen
Dec 07, 2013 | DoubleSight DS-240WB Monitor
Tv turns on but the screen in black....worked a few days ago and last night but now it is giving the black screen again
Change Your Hi Voltage Regulator Triac Mosfet Static Problem...
The Voltage Regulator need a proper Choke to iniate a cold start_up All Sony Trinitron got Heat Problem Paste dry too fast betwen the heat_sink and the Regulator....
Sep 21, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
JVC Model no: AV-48WP34 Projection Problems
OK, problem seems in convergence section of TV and can be confirmed by testing voltage supply as mentioned in schematics.
You can download service manual copy from Manual Zone for small fee and it has schematics, exploded views. board location, part numbers info.
Let me know if you need further help.
Thanks.
May 07, 2009 | JVC Televison & Video
No visual display
It sounds like your graphics card is shot. If your graphics card is a dedicated graphics card, you might be able to get it fixed/replaced; if it is embedded, then you are probably going to have to buy a whole new display screen.
Sep 04, 2008 | IBM ThinkPad T40 2373 Notebook
Hitachi 32LD6600 - When the TV has been on for abot 30 minutes the colours start to go blue/red and the picture is distorted,noting I do gets the picture to display as normal.
Hi i have this tv and last night the screen went black i can hear sound ok but no picture just a black screen, Also i can see dark
outlines /shadows of whats on the tv, can you tell me please what has caused this
Mar 05, 2008 | Hitachi 26LD6600 26 in. HD-Ready LCD...
No Image on Screen
Since you have a comcast info on screen your system is fine.Call comcast to fix your box.
Mar 02, 2008 | Televison & Video
No picture but sound works.....
  • adjust brightness setting when playing tv.
  • adjust screen control located on flyback transformer.
  • hope this will help.
Oct 23, 2007 | Sony KV-36FS16 36" TV
Blue pincushion
Shannon you have a blue convergence failure. this problem can be repaired in home, by a good tv repair guy. John
Sep 11, 2007 | Sony KP-51HW40 51" Rear Projection...
TV was Fine last night, this morning there is picture, but no sound
Since the you were vacuuming behind the set before this happened, I'm going to assume that you unplugged an input. Check the wiring, not just on the back of the set, but, on the back of the peripherals (DVD, Satelite, cable box, etc.) If wires are connected, then, take a component, such as a VCR or cable box and hook it up to the RF connector (AKA the cable connector) and run it on channel 3 or 4. If you have sound, then, you have a configuration problem and need to rewire your set. Hope this helps.
Mar 17, 2007 | Philips 27PT5441 27" TV
Televison & Video Logo
Top Televison & Video Experts
Marvin
Marvin
