Question about Samsung DV218AG Gas Dryer
How do you convert a Kenmore model number to a Whirlpool model number 110.45872400 .
I need to replacement fuse for Kenmore electric dryer. model number 110.62212101
Sears Parts Direct lists all of the parts for the 110.62212101 here: www.searspartsdirect.com/model-number/11062212101/0582/0151200.html . If you need the dryer thermal fuse (3392519), that is part 9 on the Bulkhead diagram. The direct link to the part is http://www.searspartsdirect.com/part-number/3392519/0026/110.html?modelNumber=11062212101&categoryName=Residential%20Dryer&brandName=KENMORE . They also sell thermal fuse kit, http://www.searspartsdirect.com/part-number/3977393/0026/110.html?modelNumber=11062212101&categoryName=Residential%20Dryer&brandName=KENMORE .
Other vendors will have the part since the dryer is made by Whirlpool. Whirlpool used the parts in many models.
I hope this helps.
May 16, 2017 | Kenmore Dryers
Will icemaker from whirlpool #ET1CHMXKOO4 WORK IN MY KENMORE?
Need the model number to answer that question Kemore is a brand name not a manufacturer. What is the model number of the Kenmore
Oct 05, 2015 | Whirlpool Refrigerators
Do you have access to the reset code for my Kenmore Ultra Wash dishwasher model 655.16812990?
Check your model number again. Missing or transposed numbers. You should be able to see or download rhe manual here. Also parts and diagrams.
Parts for Brands Craftsman GE Kenmore Whirlpool and more
Sep 04, 2014 | Kenmore Dishwashers
What is the comparable Whirlpool model number for Kenmore 596.76579600
Refer your query directly to Whirlpool or an appliance parts supplier. Sears states that it repairs all brands so they would have to have a cross reference for parts.
Apr 23, 2014 | Whirlpool ET1FHTXM Top Freezer...
Kenmore h2 dryer convert from propane to gas
Contact Sears with the model number and they can provide the parts and instructions, it will not be more than $25.00
Feb 07, 2012 | Kenmore Dryers
Kenmore dryer,, looking for adiagram for the belt on a kenmore dryer
Below are the belt diagrams for Kenmore dryers.
Figure 1. Whirlpool-made Kenmore dryers with removable back panel, filter on top, and model numbers starting with 110 or C110.
Figure 2. Whirlpool-made Kenmore dryers with non-removable back panel, filter below the door, and model numbers starting with 110 or C110.
Figure 3. Frigidaire-made Kenmore dryers (model numbers starting with 417).
Mar 01, 2011 | Kenmore Dryers
How to disasemble model 11020722
Can you provide the exact Make, Model and Kenmore model number? ..........
Kenmore model numbers use the format ###.######## with the first three digits of 110 for Whirlpool manufactured machines.........
The model number on top load washers is usually found by lifting the lid and looking above the tub.
The Fixya numbers are Stock Numbers. Actual Model Numbers are necessary to correctly diagnose the problem.
Can you describe exactly what you want to disasemble??
Jan 25, 2010 | Kenmore Washing Machines
Looking for model# 84870100 kenmore top loading washing machine parts list catalog
Add a 110. to the beginning of the model number. That's 110.84870100, which is a direct drive convertible from the early 90's. I have the same model.
Feb 21, 2009 | Kenmore 3362625 Ss Washer Timer Knob ...
My washer does not work
Sounds like you may have a lid switch problem. Without a model number, I really can give you a part number (Kenmore Stacks are made by two companies, Frigidaire and Whirlpool) or a way to get to it. It is right under the lid. Check the top and be sure that the plunger that goes into the hole isnt broke or missing. If you need further help, send me the model number (will start with 417 if its a Frigidaire or 110 if its a Whirlpool) and will try to get you a little more information. The job on either unit isnt that hard, and parts are pretty inexpensive. Let me know. Jim
Dec 13, 2007 | Kenmore 98702 Stacked Washer/Dryer
Samsung DV218AG Gas Dryer Logo
182 people viewed this question
Top Samsung Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Samsung Dryer Expert? Answer questions, earn points and help others
