SOURCE: Monroe Calculator 7130 - won't print red for negative
turn it off & back on & that should fix it. the ribbon lift needs to reset.
dennis
SOURCE: faint numbers show on screen of T-85 texas calculator
Make sure you have fresh batteries. Increase contrast
First possibility.
Press [2nd] and hold pressure
Press UpArrow and repeat this step
2nd Possibility
Press [2nd] key then release
Press UpArrow then release
Repeat the two steps in sequence till contrast is to you liking.
Hope it helps.
Have you remove the tape that used to fix the ribbon cartridge since the time you get the Monroe 7130? If you do remove the tape, please try to take out the Ribbon Cartridge and install it again, by refer to the description of 'Changing the Ribbon Cartridge' in the Instruction Manual. The printer lift may stuck and need to adjust.
