Question about Canon PIXMA IP3500 Photo Inkjet Printer
Paper jam, even when I do not have paper in tray.
I have a Canon PIXMA iP3500 that I can not print with most of the time. It is being used for cakes as an edible ink printer. It just says paper jam, and then I just keep having to hit the paper feed button. I even let the paper run out and just keep hitting the feed button, it and just kept saying paper jam. Friday it took me 5 hours to print 1 page. Is this something that I need to take in to the shop, or is there an update that I am not seeing.
Thank you for anything anyone can suggest! I am getting so frustrated.
SOURCE: paper jam light constantly on.
The suggestion with the heavy stock paper worked. I used a vanilla folder but this was not heavy enough so I simply folded it in half. I had the problem where it would feed 1 sheet of paper in the auto sheet feeder upon starting the printer up. This is unusual in itself. The single sheet of paper would go through normally. But with the vanilla folder, as it was going through, I heard a loud sound like a contraption somewhere was being reset or dislodged or relodged or relocated from some stuck position. After the sound, the green light came on no problem and it all worked. Try something not so heavy like a vanilla folder that has been trimmed down. Then fold it. You might have to hold it up against the black roller wheel to get it to engage the roller wheel when you turn the printer on. Hope this helps.
Posted on Aug 25, 2007
SOURCE: canon mp180 paper jammed
I finally fixed the problem by running two sheets of heavy card stock through at the same time. With the machine off, I positioned the two sheets in the feeder so that they would be pulled in when the printer was turned on. When I turned on the printer, it drew the two sheets through and I guess this reset the paper sensor. I previously found that only one sheet at a time did't work.
I found this solution posted by JsamJr answering another question but it worked for me. pushing the card in and then removing it and pressing ok worked
Posted on Apr 28, 2008
SOURCE: Canon MF4150 Duplex Printing Paper Jams
I have just had the same problem on one of these Canon MF4150 machines.
The manufactures warranty on our machine had expired just one week before this happened so I had to fix this myself.
The problem we had (which is very likely to be the same cause as yours) is when we removed some torn jammed paper, it had somehow pulled off a spring from inside the machine. The spring was linked to the paper jam sensor.
It does involve a LOT of work to fix it, and unless you are very 'techy' it may be quite a difficult task to do this for the 'average' person.
I had to completely disassemble the machine: Take off the front first (lift up the cover and there is 2 screws at the front and 2 clips on the bottom of the machine) Then remove the 2sides and finally the top (screws should be easy to see, to get the sides off, un-clip along the front edges and gently move them outwards and slide them backwards to release the clips on the back) being careful with the wires going to the scanner part). Then look for the fuser unit which is near the top at the back, there is a black rounded cover over the fuser. To remove the cover, look for 2 small clips one at each side and unclip the cover and gently lift upwards.  Under the cover on the left side you will see a small plastic rod which goes from the left side to a small tab in the middle, if you look about half way along that rod you should see a tiny spring, make sure this is clipped on properly and that you are able to rotate the rod and it should spring back to the proper position when you let go.
Once this is done, put it all back together again and it should work fine.
I'm sure a lot of other people probably have this same problem too so I hope this helps someone.
Posted on Sep 09, 2008
  • 52 Answers
SOURCE: Canon PIXMA MP160 showing paper jam, but none
hi
just recently had these problems
symptoms:
LED flashing E3 code and alarm light was solid. But dissapeared when opened the coved and came back on when closed the cover.
Also the when the cover was open the inks did not slide out to the left and stayed to the right side.
There was no paper jam, but error said paper jam.
Solution:
1. I took a thick piece of paper, from like a paper folder ones, thick enough to go in the printer and not curl up when pushed..
2. turned off the printer and turned it back on.
3, while printer was turning on,and makings sound as it does normally when turning on, I pushed through the piece of paper and the rotors stoped for a millisecond.
4.the rotors started again and pushed out the paper by it self with out my force.
5. I let the printer get started. and then turned it off and then on.
6. this solved all of my problems.
this was the first problem ever with this printer in 3 years.,preety good printer.
good luck...
Posted on Jan 23, 2009
SOURCE: Canon MP470 keeps saying "paper jammed"
I had the same problem for DAYS and there was no paper jammed at all. I went to the cannon site as a last ditch effort & the solution below fixed it. Just clean the rollers and the link tells you how. Good luck!
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=238&modelid=15403
Posted on Feb 01, 2010
Paper is not printing
Since you are asking about a Canon Pixma ip3500, I would guess that the ink cartridge(s) is/are dried out, empty, or clogged. Try swapping out with new, fresh Canon cartridges and see if that fixes the problem.
Also, be aware that it is extremely ill-advised to use only refilled or "compatible" cartridges all the time in the case of inkjet printers (of which the Pixma line of printers is an example). The reason being that the refilled and "compatible" cartridges use plain ink while the OEM cartridges use a mix of ink and lubricants so as to keep the ink delivery system functioning to peak efficiency and help to keep the system clear of clogs. Therefore, if you have recently put in a new cartridge but it is yet another refill, swap it out for a real Canon cartridge and then try using the "clean the printer" function to try to clear out the ink nozzles. If you don't feel comfortable doing this or you are unsure how to accomplish this task, get in touch with a local computer or printer repair shop and they will gladly resolve this for you.
Jun 05, 2015 | Canon PIXMA iP3500 Printer
I WANT TO MAKE EDIBLE IMAGES FOR CAKE IS MY PRINTER MADE TO DO THAT IF SO WHAT CARTRIDGES WOULD I USE
ask for the edible ink cartridges i use to work with those in 2006. or you can google edible ink cartridge for .....(place your printer and model number after the word for)
Feb 28, 2011 | Canon Pixma MP480 All-In-One InkJet...
Using edible ink in a cannon IP 3500 and is printing with streaky white lines i have done all cleans including a flush of purified water. Any suggestions?
use a mixture of ammonia and water solution. Place the cartridge printhead in the solution and leave it overnight.
It will fix the print head.
Jan 25, 2011 | Canon PIXMA iP3500 Printer
Is it possible to use printer with black ink cartridge only? Printer: canon ip3500
Yes u can.
In the Printing Preference window, Choose the media type (paper type) as plain paper and check the Grayscale printing mode.
Oct 12, 2010 | Canon PIXMA iP3500 Printer
PIXMA iP3500 Printer: the paper jams in my canon ip3500...
Hello there
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Also clean The purge unit, called a spittoon assembly in an HP, Lexmark, Caonon and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing.
That is where you'll find the print head assembly parked on top of it.
It also has an electrical pump to milk the print heads and test for ink flow.
So clean all under where the heads are parked and on IP6600D models you can take out the heads just by clipping them out, and then clean well.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Apr 28, 2010 | Office Equipment & Supplies
Brand New Edible ink cartridge not working on brand new Epson C90
Hmmm 4 this problem you can take the cartridge out and reinstall the software and then put the cartridge back
Jan 24, 2010 | Canon PIXMA IP3500 Photo Inkjet Printer
Hi, i'am from kuala lumpur malaysia, i'am looking for printer for edible image. where can i buy the printer and the sugar ink. tq
I live in the southern part of New Jersey, USA. We have some beautiful cakes produced in our area in the larger grocery stores using this kind of process.
I dont know what to tell you to do in your country, which I have visited, by the way, but if I wanted such a printer, I think I would go speak with the baker at the store where theymight have **** a decorated cake.
On the ohter hand, maybe you are the baker and you are looking for such a thing. Try this ...
Have your tried to Google "cake decorating" or anythng similar to that?
Good Luck to you my friend - and thanks for asking your question here on FixYa.com
a
Oct 30, 2009 | Canon PIXMA iP3500 Printer
Mp530 edible ink
You need to clean the print head manually. Remove tanks from print head, then remove print head. Find a small tray you can put hot water in to the depth of a quarter inch / 6 mm. Soak bottom of print head. Do not touch or get wet the electrical contacts. Next while holding print head in left hand carefully pour a small amount of hot water in the each ink tank well in the print head. Now dab the bottom of the print head where the jets are with a paper towel. Keep dabbing till you get equal size spots of all the colours. Best to wear plastic gloves doing this. Best to use battery water (de-ionized) but if you don't get scale in your electric jug your tap water is fine.
Sep 18, 2009 | Canon PIXMA MP530 All-In-One InkJet...
Canon printer now says edible ink cartridge is not compatible!
Most Cannon Printers will warn you of this specially if your using re manufactured ink and it shows up in the print queue.Just ignore this message and print normally! Bypassing this warning will not damage printer!!
Aug 09, 2009 | Canon PIXMA IP3500 Photo Inkjet Printer
Canon PIXMA IP3500 Photo Inkjet Printer Logo
52 people viewed this question
old marine
old marine
