Question about Sony Ericsson Cyber-shot C905 Cell Phone
Normally when you plug the charger in something appears on the screen to show its charging. Well nothing is coming up on the screen. On the side a red light flashes sometimes. Can you please tell me whats wrong with it ? it wont even switch on xx
If your display says that you should use an original SE battery and you already have such, then you have a software problem. If you have some battey capacity left then try to connect to your computer and get an upload of your programme. If your battery is fully unloaded, then you need to send it to SE service.
Posted on Mar 06, 2010
    President:
  • 1,738 Answers
There are three possible solutions to your problem.
1) The battery needs to be replaced; or
2) The charger needs to be replaced. (If you have a car charger, you can use it to rule out if the problem is your wall charger.) or
3) Your mobile phone needs to be returned for repair.
If you found this information helpful, please give me a big thumbs up when you rate my answer. Thank you.
Posted on Feb 02, 2010
Brand new tablet will not turn on
Make sure it is fully charged. Hold power button down for about 10 seconds and wait if nothing comes up press power again for half a second. Still nothing? Then put it on charge, it should show that it is charging with a light of a picture on the screen. If there is no sign of charging, wait about 3 hours leave the charger connected and press the power button again for about a second and wait for it to turn on or for the picture to show it is charging appears on the screen, (make sure the charger is on and connected) . Press the power button again for another 5 seconds and wait. sometimes it takes a little while to turn on, especially if the battery is very flat. Other things to try are check the charger on another device e.g. another table or a phone if you can and try another charger on the tablet if they are compatible, (usually the same plug is o.k, check the voltage is the same. most chargers are USB 5v). It may need a more powerful charger than most small phones,. you can try plugging the USB cable into a car charger or USB 3.0 port on a computer. 2 amps is common for most tablets. Apple may be different, hard to be exact without knowing brand etc.
If all else fails see the retailer
Dec 26, 2017 | Tablets & eReaders
NOTHING BUT A BATTERY AND RCA TABLET COMES ON WITH CHARGER BUT SHOWS NOTHING BUT A BATTERY ON SCREEN RCA 7 INCH TABLET
With the charger hooked up and plugged in the tablet will only show the battery on the screen briefly to let you know it's charging. It won't actually boot up until it has a sufficient charge. Just let it set that way for a couple of hours then try to power up.
Feb 26, 2015 | RCA CA 7" Tablet with 4GB eory 28458515
Nexus 7 problems
Pop the back cover off. It's real easy - you can use a credit card or even your fingernails. Carefully prise all around the edges. It'll come off quite easily. Looking from the rear with USB port at the bottom, you'll see the left side if the unit is occupied by a large rectangular battery. At the top right of the battery is a connector with six wires. Gently disconnect the connector from the main board. Leave disconnected for about 30-60 seconds and then plug it back in.
Put the back cover back on, and then plug in the charger.
You Nexus will charge fine.
Jul 16, 2014 | Google Nexus 7
Plantronics audio 995H wireless headset not charging when plugged into computer. It does not show a red light for charging. When turned on it stays blue for several seconds then flickers red for 2 or
38cafd7a-6060-4717-bc4f-b4db91cc266a.jpgI recently fixed my 955 headphones... it's probably not going to be attempted by most folks, but it saved a great set of headphones from being tossed and replaced.
Basically you need to remove the right side padding and take out the 3 screws. This gets you access to the battery. The battery is a standard 3.6V lithium battery. Pretty much the same that is in most cell phones and many small toys. You can simply replace the battery with something like:
http://dx.com/s/3.7v+li
Or... here's what I did... add a lithium USB charger to the battery.
http://dx.com/s/li+arduino
Now, if the battery dies I can plug it into USB and the phone will work while it charges.
Nov 12, 2013 | Plantronics .Audio 995 Digital Wireless...
NEW PURCHASE AND PLUGGED INTO AUTO TURNED ON AND GARMIN LOGO APPEARED AND THEN SCREEN WENT BLACK. DOES NOT WANT TO STAY ON. INTSTRUCTIONS SAY UNIT WILL PROMPT BUT NOTHING HAPPENS. IS THERE SOMETHING ELSE...
Yes!!! Please charge the unit overnight. You didn't say what model you have. If it's a 2xx series, plug in the charger and move the on/off switch momentarily to the left until you see the screen say charging. Set the unit down and the screen will go off. If you touch the screen again, it will come on. After charging is done, when you touch the screen it will say charging is complete. Remove the charger. If its' a 3xx or 6xx product, hold down the on/off power button until you get the charge screen.
- Jim
SHARCNET-USA
Dec 11, 2008 | Garmin GPS
Razr V3 not recognising Charger
the connection between the phone and the adapter are copper and the get corroded take a small pin and scratch away the green corrossion and that should solve your problem. the cause is condensation. good luck
Oct 21, 2008 | Motorola Mobility RAZR V3
Apple screen
Connect the ipod to your computer and let it sit for about fifteen minutes. Then it should show up in your computer and under itunes. Usually, if your ipod dies completely, when you try to charge it using a wall or car charger, it will do that, just flashing the apple logo and going back off. Leaving it plugged up to the computer will allow the battery to charge normally, just enough so that it can come on and sync with itunes. While it is plugged into the computer and charging, it should say something like, battery very low, wait few minutes, charging. It should work after letting it sit plugged up to the computer.
Oct 17, 2008 | Apple iPod nano
Battery Will Not Charge
Hi amber_penn, battery charging problems usually come from two sources, the battery or the battery charger.
Check the contacts on both the battery and the charger for oxidation, dirt, etc. Try cleaning the contacts with a little alcohol on a swab. The charger seemed to still work judging from the humming sound. Next step would be to buy a new battery.
Try to follow this link http://www.livingroom.org.au/photolog/reviews/miscellaneous/norcent_dc420.php
Mar 29, 2008 | Norcent Technologies DC-420 Digital Camera
Sony Ericsson Cyber-shot C905 Cell Phone Logo
195 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
270rexton
270rexton
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
