Question about Dell Inspiron B130 Notebook
Dell B-130 inspiron When I plug in the charger/ac adaptor, the battery indicator light stays on. I purchased a new adaptor and the same thing is happening. I did notice that the tip gets hot.
  • 1 more comment
  • sastein Feb 02, 2010
    B130 inspiron by Dell. Unit is 4-5 years old. ac adaptor was not charging the battery, so i purchased a new adaptor. It too is doing the same thing. If I push in the tip, sometimes it will start to power the unit and charge the battery. Battery will not keep charge very long, and tip gets hot. what is the problem?
    how do i change the port, and what is an IC unit (is it an expensive job)
    Comments:
    Feb 02, 2010 - B130 inspiron by Dell. Unit is 4-5 years old. ac adaptor was not charging the battery, so i purchased a new adaptor. It too is doing the same thing. If I push in the tip, sometimes it will start to power the unit and charge the battery. Battery will not keep charge very long, and tip gets hot. what is the problem?
    Was told that it could be the charging port, or the IC unit is bad.
    Is this really the problem, if so, how do i change the port, what is an IC unit and if replacing, it is it an expensive job?
    See less
    President:
  • 1,185 Answers
The tip should not get hot if it is it the battery is drawing too much current and is faulty.
Either obtain a new battery or get the one fitted to your laptop tested
Posted on Feb 02, 2010
  • Tom
    Tom Feb 03, 2010
    If you can make a connection by "Pushing" it in hard then you may have damaged the female socket which accepts the charge
    This in turn could cause arcing between the pin and the socket which produces heat
    The supply goes in and is regulated by a small pcb (IC) before it is fed to the battery and main pcb
    It will be possible to replace or repair it
    However the cost of doing so can outweigh the cost of replacing the laptop
  • 1,511 Answers
Hello and Welcome to Fixya,
By the comments you have added to your query, it seems that either the charging port is having a loose connection or the charging IC (built in charging unit) is making trouble. If you are only having a loose connection, you need to change the charging port and if these is a charger IC fault, then Sad but true the charging IC needs to be replaced.
Best of Luck,
Do rate my solution, If Found Helpful.
Regards.
  • Waqar Hassan
    Waqar Hassan Feb 02, 2010
    Sir, actually both the jobs requires professional skills and appropriate tools... I would recommend you to have your machine inspected by an expert physically.... Also make sure you bought the original charger will the matching power rating.........Also on a safer side, do make sure that the battery of your machine is intact and properly connected....
  • 10,865 Answers
Hello. The symptoms you are describing are indicative of a battery on it's way out. If your inspiron is under warranty, go to Dell.com and let them know. Otherwise you should have your battery checked, most Radio Shack stores, and computer stores will check the battery for no charge. Regards, Joe
Dell Inspiron 9300. Problem occurs when I try to charge it. The screen says it can't determine the adapter type and the battery does not charge. I can wiggle the charger cable around at the connection to...
The same exact thing is happening to my Inspiron 9300. Did you get it repaired? After reading lots of forums, changing AC adaptors and ordering a new battery, I came to the conclusion that it is the plug on the laptop that is not working.
Nov 17, 2010 | Dell Inspiron 9300 Notebook
Dell Inspiron 6000 won't charge
Since you have already replaced the battery and the laptop works with the AC charger, then probably the charge circuit in the system board (mother board) is bad. I have rarely seen an AC charger that will power the laptop but not charge the battery. 99% of the time, if it is not the battery, it is the system board.
May 05, 2010 | Dell Inspiron 6000 Notebook
Dear Sir, My Dell Inspiron 6400 have problem with power unable to switch on as when Adaptor is plug into my computer. senario: 1)Try to unplug and adaptor indicator is lights on. 2) when plug in into...
Hi your AC adaptor might be the problem. I repaired about 7 adaptor charger and I can you that this is the problem. Lot of time this unit is always be drop and the enternal parts such as transformer wiring solder to a little board are all broken off and no connection to the transformer or to the board. Just buy or order it to dell web site and cost is depending to the model of your laptop. I believe the cost is under $100.00.
Aug 22, 2009 | Dell Inspiron E1505 Notebook
Inspiron 1520 Power Fault?
dead motherboard, highly likely to be fine if the battery is full
Aug 01, 2009 | Dell Inspiron 1525 Notebook
Dell 5160 Won't start up or charge battery
I have the dell inspiron 5160 works great a little slow but no big deal. The problem I have as of Monday the power cord will not stay in and now will not charge. Is it the power port? Can this be fixed?
Jun 27, 2009 | Dell Inspiron 5160 Notebook
Laptop AC Adaptor
look here the problem can be of two types,,first the problem can be of the adapter or the port in the computer where the adapter pluggs in the computer,,look for any friends or relatives using the same computer with the same good adapter,,plugg it into the computer,,if u dnt c the problem then prob with the adapter or else prob with motherboard
best of luck,,keep me posted,,giv agood rating
May 26, 2009 | Dell Inspiron 6000 Notebook
Keeps powering on and off.
Keep in mind since you cleaned it out, only have the AC adaptor hooked up to rule the battery out. If the laptop stays on with only the ac adaptor hooked up and doesn't shut off then you know that the battery is faulty. If it still shuts off even with just the ac adaptor hooked up then it could be the ac adaptor.
Also check one more thing, with only the ac adaptor hooked up, wiggle the cord where it plugs into the laptop and see if the laptop shuts off, if it does then the dc jack on the motherboard is loose and needs to be resoldered back into place so it stays put.
May 13, 2009 | Dell Computers & Internet
Can I use ther Targus Adaptor for Inspiron 1525
On the long term, a power adapter with a bigger amperage can damage battery and battery charger.
Better to get an adapter with same specs as the 65/70W one , or an original replacemant:
Dell Inspiron 1525 New AC Power Adapter Supply $14.29 - Buy.com Dell Inspiron 1525 65 Watt Original AC Adapter $25.00 - parts4nb.com Dell Inspiron 1525 Power Cord PA-12 $16.95 - AmeriMax Advance
DELL Inspiron 1525 DC Power Laptop Adapter ... £25.23 - B2C Shopping UK DELL Inspiron 1525 Laptop AC Adapter power adapter £38.99 - Very Good Battery Dell Inspiron 1525 Ac Adapter Charger Power ... £16.50 - eBay UK
AU/NZ - DELL INSPIRON 1505 E1405 E1505 AC Adapter Power Supply
Dell : Lind Electronics 70-Watt DC Power Adapter for Dell Inspiron
Apr 22, 2009 | Dell Inspiron 1501 Notebook
Dell inspiron 6400-runs slow on AC power but not on battery
uninstall any energy management software provided by dell and then check.if the issue is not resolved then the issue is with the converter board as it is heating up.
Jan 29, 2009 | Dell Inspiron 6400 Notebook
Dell inspiron b130
check if the ac adapter or charger has a green light on it. if not, replace the charger. for dell chargers, it should have a green light to indicate that the charger is getting power from the wall outlet. if the ac adapter is good, then you might need to replace the mother board as the ac port is integrated.
hope this resolves your problem.
Nov 12, 2007 | Dell INSPIRON 6000 CENTRINO...
Dell Inspiron B130 Notebook Logo
Alun Cox
