Question about OKI C5400tn Laser Printer
OKI Laser Printer 918 fatal error what does this mean, many thanks
  • 97 Answers
SOURCE: 980: Fatal Error
From the Service Manual:
*Service call
980:Error
*Error by media
clinging to the fuser
*Media has clung to the fuser.
*Power OFF
Replace the fuser unit.
Suggestion -
Before you replace the fuser, take it out and check for a piece of stuck label, paper, etc. You can spin the fuser roller by turning the gear on the side.
Posted on Apr 07, 2008
SOURCE: does anyone know what is
According to the Oki service manual that problem is related to the fuser. The reference is that there's some media stuck in the unit, they recommend replacing the fuser but it's possible just reseating it with power off will allow it to clear the code.
Posted on Apr 21, 2008
  • 78 Answers
SOURCE: fatal error 917 on an Oki C9600 printer
A fatal error 917 means there is a problem regarding the belt **** sensor.
Usually it means the printer can't see the transfer belt rotating.
First thing to try is to remove and re install the transfer belt, if that does not work you should replace the transfer belt.
Posted on Jan 07, 2009
SOURCE: fatal error 980 OKI C5500 printer
I had a paper jam and removed the jammed papers. The paper jam cleared and then the Fatal Error 980 appeared. OKI C5500 printer
Posted on Feb 25, 2010
SOURCE: OKi C5800ldn 231: fatal error 03
I have the Oki 5650 which had been great for about 18 months. Then found that the C cartridge was showing error as 'not installed'. After much fiddling about with it and checking on the internet I can now rectify this by either pushing down on the top of the printer while it boots up, or removing the small chip on the left top of the toner (make sure you have 'earthed' yourself to prevent any static damaging the chip when you handle it!) and taping securly onto the top of the cartridge above the chips proper slot. This now has been working OK for 6 months. Strange how this only affects the C cartridge (which has also been replaced and had the same problem). I suspect that the printers RFID chip reader for the C cartridge is having problems reading the chip and moving the chip closer to the reader by either taping to the cartridge top of puching on the top cover while printer boots up resolves the problem (for now anyway!) This can also trigger the 'service call 231 fatal error 03' message which also disappears if you follow the above procedure.
Hope this helps you.
Posted on Jul 27, 2010
Oki
231 means RFID reader I/F error. 03 means Communication error
between the RFID reader and the tag chip. The remedial measure is to check for normal connection of the antenna cable.
May 06, 2014 | Oki Electric Industry C830DTN Laser...
Error 030 fatal error
ecblank.gif What does "Fatal Error" mean? ecblank.gif ecblank.gif ecblank.gif ecblank.gif
ecblank.gif ecblank.gif Summary: Printer has displayed a "Fatal Error" message. This simply means a problem has occurred requiring you to take action. It does NOT mean that your printer has "died". ecblank.gif ecblank.gif ecblank.gif ecblank.gif
ecblank.gif ecblank.gif Your printer display or status monitor may read "Fatal Error". This simply means a problem has occurred requiring action to clear.
A "Fatal Error" does not mean your printer will "die". Fatal Error explanations are not usually found in the User's Guide or Handy Reference Guide.
RECOMMENDED NEXT STEP: First, try turning off your printer then turning it back on. If this does not clear the message or remedy the problem, check to see if your printer is on a power strip (or not plugged directly into the wall). For testing purposes, be sure the printer is plugged directly into the wall. Often, the issue is power-related.
Second, if the issue persists after this, write down the message (including the 3-digit error code number) and email us at "support@okidata.com" or call Oki Data Customer Support (1-800-654-3282) for assistance.
NOTE: If you see a series of letters and numbers(scrolling across the display) after the 3-digit error code, be sure to write these down also and report them when call or emailing Customer Support.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
May 25, 2011 | OKI C5200n Laser Printer
Error message: Service Call 980 - Fatal Error
It means a call to OKI will be necessary. Typically, fatal errors are related to internal ROM, or board components that effect the boot process of the printer. When it can't boot - you get this type of message.
Dec 31, 2010 | OKI Electric Industry B4545 Laser Printer
Oki c5650, fatal error
tengo una impresora oki y me muestra error fatal en la pantalla que debo hacer para quitarle ese error de mi impresora
Apr 26, 2010 | OKI C5650n LED Laser Printer
How do i solve fatal error 980
i got that error on the first day i got my oki c5950 it was a result of a paper jam in the fuser unit, i removed the jamed paper but the error was still there, i contacted oki support and got a detailed explanation on how to fix this error with a patch file, so if u or anyone out there r still having that problem send me a mail on ecks80@hotmail.com and i will forward u the info.
good luck
Sep 14, 2009 | OKI C5500n Laser Printer
Oki c 5600 980 fatal error
The error means that the media is wrapped around the heat roller of the fuser. The only way to reset this error is to replace the fuser unit.
Jul 20, 2009 | OKI C5500n Laser Printer
Fatal error 122 on a oki c5200 printer
YOUR DRIVER CD IS CURREPTED.ANOTHER DRIVER CD USE.
Jun 23, 2009 | OKI C5200n Laser Printer
Fatal error 980 OKI C5500 printer
Mar 15, 2009 | OKI C5100n Laser Printer
Fatal error 917 on an Oki C9600 printer. What does this mean and how can I resolve the problem. Many thanks James
Jan 07, 2009 | OKI C9600hdn Laser Printer
Fatal error
Fatal Error K (for BLACK) - Black toner or drum problem, Drum life exceeded? Display would of said black drum near life before failing.
May 15, 2007 | OKI C5100n Laser Printer
OKI C5400tn Laser Printer Logo
487 people viewed this question
Top OKI Office Equipment & Supplies Experts
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
