Question about Kitchen Ranges
Have a Maytag microwave (over the range) JMC8127DD/JMC8130DD that has the light turn on when you push start, but it doesn't heat up or the turntable does not turn. Any thoughts would be greatly appreciated. Thanks ~
    Brigadier General:
  • 3,917 Answers
Hi
It is most probably shorted high voltage rectifier diode or a bad magnetron, or a loose and possibly corroded connection on the magnetron's terminal.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
Check the bellow link to have an in-depth knowledge about your problem
http://www.gallawa.com/microtech/diode.html
http://www.gallawa.com/microtech/mag_test.html
Thanks for contacting fixya.com
Posted on Feb 02, 2010
GE spacemaker XL1400
what problem do you have mention ? attached is there a list please indicate. God bless you
    No Lights or Power, Unit seems Dead The voltage to the unit is good.Lights come on, but can not program unit, Touchpad dead
    Microwave Runs, but no Heat Turntable rotates, acts like it is heating but doesn't. This is the big one, many possibilities.
    Microwave Runs, Heats, but turntable does not move
    Microwave is arcing
    Microwave Vent Hood is not working Over The Range(OTR) Models.
    Microwave Stove Light not Working OTR models, light bulbs good.
    Microwave overheats and keeps turning off
Oct 01, 2012 | Microwave Ovens
Microwave lights up doesn't turn on
The part of the oven called the "magnetron" (this part is what creates/generates the microwave energy that heats the food or liquid) is burned out, the cost to repair is more this part is more than the cost to replace with the cost of Microwaves so depressed by the stagnant economy.
Jan 31, 2012 | GE Spacemaker 1.7 Cu. Ft. Over-the-Range...
The turntable will not turn and will not heat up everything else is working
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Sep 25, 2011 | Maytag Appliances Over-the-Range Microwave...
MMV5100AAB Over the Range 1500 watts 3amps -turntable does not turn -does not heat -light works- unit makes loud running noise but will not turn off -must open door or unplug to turn it off. Never any...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
heatman101
Sep 10, 2010 | Maytag Microwave Ovens
My Maytag microwave stopped heating. Everything
Generally the magnetron (the part that heats the food) is the cause if everything else still works. Unfortunately replacing the magnetron is barely cheaper than buying a new microwave though you can check out repairclinic.com to decide whether you want to attempt replacing the part.
Let me know how this works out for you.
Benjamin
May 24, 2010 | Maytag 2.0 Cu. Ft. Over-the-Range...
Microwave will not heat. The light comes on the turntable turns
Basic Microwave Oven TroubleshootingTips
heatman101/./,/,
May 16, 2010 | Maytag MMV4205 Microwave Oven
Have GE JVM2050 over the range microwave, which stopped heating food and water since this morning. All other functions including light, key pad, clock, turntable work normal. The magnetron sound also
if everything works except the heating, it is most likely the mag tube is on its way out.........that is the most common reason for it not too cook.......since the microwave is a GE and it is 3.5 years old, i would say you are better off buying a new microwave, the mag tube starts at around $70.00 and up + the labor it costs too have a service person put it in........around another $60.00
May 02, 2009 | GE JVM2050 Microwave Oven
Kitchen Ranges Logo
15 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
