Question about Whirlpool Duet GHW9150P Front Load Washer
Clean the washer using the AFFRESH wipe down after use and when we wash again the washer puts out a smell what up?
    Habit-Forming:
  • 84 Answers
The smell comes from the fabric softener people use,put the machine through a hot water cycle and use CLR in the detergent dish,and after your done the wash always leave your door open on your front load so it can get air
Posted on Feb 06, 2010
I cleaned my washer with affresh and it still smells very sour
dump a box a baking soda in it and run empty . see if it helps your problem
Jun 22, 2016 | Whirlpool WTW6400SW Cabrio Washer
Moldy smell in clothes, especially towels
need to clean the bellow ( rubber around door). theres a tablet you can buy called "Affresh". It will help to remove the moldy smell. just throw it in washer and run through a regular wash cycle. no clothes, just the tablet. If there is a clean cycle on the machine then use that cycle. Whenever you're finished washing, you should leave the door open for about 20-30 minutes so unit can air out. Also you should wipe around the glass and bellow after each use.
Mar 19, 2011 | Whirlpool Duet GHW9150P Front Load Washer
I have a foul smell coming from my washer everytime I use it...It almost smells like sewer gas...HELP!!!
you probably just need to clean the bellow. Thats the rubber that goes around the tub and door. f not cleaned, it will get moldy and smelly. Theres a tablet that you can buy called affresh. just put the machine on a regular cycle if it doesn't have a clean or sanitize cycle, and put the tablet in. Let the machine complete the cycle. (without clothes). You can even try wiping the bellow out with vinegar. after each wash i suggest you wipe the machine out, drying the bellow and glass. Leave it open for about half an hour, to let it air out.
Feb 12, 2011 | Frigidaire Affinity ATF7000E Front Load...
How to get rid of the stale smell from the atf8000 front loader washing machine
first things first we need to purchase a cleaning tablet from local grocery store called affresh tablets in your laundry detergent aisle ,
then clean out filter sump assymbly in bottom corner of washer som washers have an axcess panel in the bottom righ or left hand corber uncrew filter cap and drain in to bucket or a shop vac .
clean debris out of filter and reinstall the filter screw cap in tightly ..
check your console for a clean cycle option in your wash cycles an select put one affresh tablet inside of washer drum and run cycle..
if you dont have a clean cycle thats ok select your hotest water wash cycle or sanitary cycle put one affresh tablet inside washer drum and run cycle ...
after cycle completes always leave waher door cracked open when washer is not in use ,,, reccomend running an affresh cycle once every month or if u notice stagnant water smell the more often you wash with hot water the less chances of smell
Jan 24, 2011 | Washing Machines
The smell that comes from this machine is terrible. My clothes also smell bad. I wipe out the seals rubber around door and leave the door open for at least 30 min. After each wash. I also take clothes out...
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Hope your filter is clean. Don’t wait for the machine to jam to look into your filter.
You can use Affresh to clean your front loader. Deposits of soap and other such things can be stuck around the inside tub of your washer. Try this product, it works great on all front loaders. Use very hot water with the Affresh pellet with no clothes and run the machine through a cycle. Also helps with any stagnant water smells. Put the Affresh pellet inside the machine, not in the soap dispenser.
You can give me a ‘very helpful’ rating for the free help, can't you. Thanks.
Jun 19, 2010 | Samsung WF337AA Front Load Washer
Clothes stink
May 13, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Washer smells bad - musty
smell are normally due to 3 culprits
low temp wash , liquid soap , moisture
affresh washer cleaner may be worth a try
video
May 07, 2010 | LG WM0642H Front Load
My water has been smelling of sulfur. The clothes I was end up smelling of BO after being worn for only a short time. It isnt that the person is smell it is the clothing. Is there something to be added to...
I found that WasherFresh worked better then the Affresh.  What I really did not like is you cannot touch the Affresh tablets, WasherFresh is contained in a pouch and is not harmful to touch, because of the disolving pouch containing the chemicals.  Also after reading the package the chemicals are not harmful to the environment.
WasherFresh removed the odor causing buildup and I now use it monthly as a preventive maintenance.
Sep 30, 2008 | Estate TAWX700JQ Top Load Washer
Smelly washer
Try Putting Lemons in the washer once you done the washing gets rid of the smelly oder
Jul 19, 2008 | Whirlpool Washing Machines
Lg tromm front load washer machine
Try using www.affresh.com, in the wash using hot water. If your unit has a tub clean cycle use it. Leave the door open after using the unit to allow it to breath and wipe down the gasket. Use HE detergent and you don't have to use too much. That goes for the fabric softener as well.
Sgt 48
Jun 07, 2008 | Washing Machines
Whirlpool Duet GHW9150P Front Load Washer Logo
41 people viewed this question
Dan Webster
Dan Webster
Sal De
