Question about Black & Decker (050876530606)
Where can I buy a 36TMH01 561886 L135-20C S0746
Where can I buy a 36TMH01 561886 L135-20C S0746 Thermo control switch
1996 yamaha waveraider 700 Thermo Switch Assy what dose it do?
Yamaha 60E-82560-A1-00 Thermo Switch ASSEMBLY ...
? 2:22
www.youtube.com/watch?v=n2DMKPy8mys
Jul 15, 2013 - Uploaded by PartsPak6
Buy Yamaha 60E-82560-A1-00 Thermo Switch ASSEMBLY at: http://www.PartsPak.com/ProductCart/pc ...
Jun 07, 2014 | Yamaha 12V Air Pump
MY MAGIC CHEF, CONCEPT SERIES, W/MAGIC CONTROL CENTER DOESN'T LIGHT.
I have a Magic Chief Concept Series oven - Replaced the Thermo-coupler and the control switch. I now have a pilot light but the thermo-coupler doesn't get hot enough to light the burner, But if I take a lighter and put it on the thermo-coupler it will but when I take if off it shuts off after a few seconds. Could you please give me Ideas of what could be wrong
Dec 18, 2012 | Magic Chef Ovens
Skytech-3001 Thermo won't work
I am having some trouble! Mine became unconnected and I don't know how to reconnect. There is two wire, red and white, a box that sits inside the fireplace that has an on/off sitch and a box that sits outside the fireplace with a off/remore/on switch. How do I connect it back? Please help!
Jan 28, 2012 | Skytech 3301 Thermostatic Gas Fireplace &...
Volkswagon POLO 2001 Manual Problem: thermo fan not working. Hi all, I have since ordered and replaced the fan with a another fan and the fan still does not work!! Could it be the fuse? Initial...
CHECK TO SEE IF POWER GOING TO COOLANT FAN AND COOLANT FAN THERMO SWITCH.THERMO SWITCH LOCATED BOTTOM OF RADIATOR ON THE LEFT HAND SIDE.IF POWER GOING TO THERMO SWITCH THEN SWITCH IS FAULTY.IF NO POWER GOING TO THERMO SWITCH OR COOLING FAN.CHECK LARGE FAN FUSE IN THE ENGINE COMPARTMENT AND YOU HAVE FUSE 16 IN FUSE HOLDER.IF FUSES GOOD YOU HAVE SHORT IN THE FAN WIRE OR FAULTY FAN CONTROL MODULE.SHAKE FAN WIRES IF FAN WORKS PROBLEM IN THE FAN WIRES YOU HAVE A SHORT IN THE WIRES..
Jan 12, 2011 | 1996 Volkswagen Golf
Cooling fans on radiator will not run. Voltage in plug at block thermostat is 5.4.this therm provides an earth switch. Bypassed the thermo to earth and fan relay engages momentarily only. Relay is ok....
The fan control thermo switch should be either "off" or "on".
Voltage should measure either +12 or 0V, depending on coolant temperature.
Replacing it should fix your problem.
Jun 20, 2009 | 2000 Daewoo Nubira
Auxiallry fans on radiator dont seem to come on. how do they work
Hi, They are controled by a thermo-fan switch, when coolant reaches a certain temperture fan switch turns on radiator fans and brings temperture back down. Thermo-Fan switch is located bottom of radiator.
Dec 03, 2008 | 1990 Subaru Legacy
The ventilation fan of my power inverter wont shut off
This is hard without knowing the specifics, but these fans can be wired to be on all the time, or controlled by the thermo-switch, or even electrically controlled by a logic board. You may have a stuck Thermo-switch or a bad logic board, since to fail shorted is the standard failure mode (for a Triac).
Nov 16, 2008 | Electronics - Others
Ducted gas hetaing keeps tripping the thermo fan switch. We seem to have plenty of air flow out of the vents and have replaced 75% of the ducting
It seems that you are saying the thermo fan stops first, thenfotre the safety limit switch shouts off the gas. This would mean the thermo fan motor is bad. It is overheating, which cuts out the thermo fan switch. The gas only shouts off because the thermo fan motor is bad.
Jul 23, 2008 | Heating & Cooling
Black & Decker (050876530606) Logo
933 people viewed this question
Top Black & Decker Coffee Makers & Espresso Machines Experts
eyecam
iandunn_tms
Henry  Thomas
Henry Thomas
Are you a Black & Decker Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
